What would a "proper" plumber do?
2018-05-22_09-37-05
Solder the joints in situ or off the backing board then clip back on?  (It's marine ply btw). I don't want to burn the wood. Got my protective mat, random sheets of metal etc.
Figure if I lose the pipe clips nearest the elbow/T/elbow I won't melt them! Obviously I've to add short lengths up for the supply and the long drops of the bottom valves.
Edited by Onoff
you will need to solder the T piece at the same time as the elbows. Personally I'd take it off and lay down on a flat surface then solder & lift back unless you are doing a shape that needs to be help in position to get an accurate fit.  No chance of burning wood or melting the clips then.
+1
Half, or less, of what you've done so far..............if you were lucky. ;)
"Keep fighting the good fight, Sir" ??
I'm not happy with the symmetry in that last picture :( Going to mirror the hot so it matches the cold. The whole board will probably have to drop later anyway as the upstairs en suite mixer is way too high up the wall in the enclosure. Also has a naff BLUE plastic tray about 6" high which will be replaced...along with the Artex ceiling, non P5, "ordinary" chipboard floor, 3/8" pb walls etc :)
Edited by Onoff
You
will
never
see
it..........
just solder it up and get on with the next job ..!
5 hours ago, PeterW said:
You
will
never
see
it..........
He will see it !
In his mind it will always be there ; non symmetrical; taunting everyday and every night . @Onoff ; you know your fate , you know your destiny young sky walker . Make them symmetrical or have no peace
Me and plumbing...nah! :( Started late tonight, playing Dad's taxi etc. Flexis will transfer to the two lengths of 15mm. A quick bend in copper should sort the valve to the ensuite shower cold and get rid of the white push fits. Probably have to do a saddle to sort the feed to the hot:
20180523_222929
Down lower where the feeds go off to the downstairs shower. I'll need to joint them:
20180523_222945
Poxy original waste :
20180523_223022
Edited by Onoff
Gotta get this finished if I want a shower tonight! Working in a hot loft I need one too! :)
Ready for soldering. Some cloaking board off cuts to protect the ply:
20180527_144807
A lick of paint and a polish up:
20180527_160510
TF for the olive splitter!  :ph34r:
20180527_164452
Getting there. I'll probably put the flexis higher up so straighter:
20180527_171633
Got to take off the ensuite bar mixer now and add a couple of bends to get it back up and running.
59 minutes ago, Nickfromwales said:
It's a thing of beauty.
You took the words right out of my mouth :) It's taken all f**ing day mind. No wonder plumbers get  paid so much! And yes, the bend and double one both done in one:
20180527_191603
20180527_191620
20180527_191642
Edit: Got to be bloody careful not to open any of these valves as the sh!tty gate valves the other end are letting by! :(
Edited by Onoff
NOT so pretty the other side! :( Cracked tile and holes filled with "silicon":
20180527_200329
Not sure whether to CT1 or Sikaflex EBT these plates back on?
20180527_200358
It's ALL coming out eventually right back to studs/joists so ceiling, walls and floor will be re "boarded".
Edit: CT1'd it all. Next time I touch it it'll all hopefully be coming out in favour of one of those 22mm thick tray things!
Edited by Onoff
B@LLOCKS! :(
I swear I didn't go mad getting this off but it was a vice job to separate it from the back plate. It is knackered and I need a new one. Thread is stripped & it's split up the thin wall bit where the wrench flats are. Guessing I might have to buy a complete new bar mixer!
20180527_211946
20180527_212006
20180527_212021
20180527_212030
Off to have a peruse thru the Screwy's etc catalogue & online.
22 minutes ago, Nickfromwales said:
The back to wall kits are in SFx.
Link
Yep just looking at those in the catalogue. Don't suppose you recognise the bar mixer?
2018-05-27_10-19-35
The bit I need is less than a fiver online for a pair! :(
https://m.ebay.co.uk/itm/Exposed-Thermostatic-Shower-Bar-Valve-Easy-Fit-Shower-Fixing-Kit-Pair-EFK001/311067821140?hash=item486d164454:g:4nMAAOSwVtZaQ4ti
Edited by Onoff
Don't recognise that tbh, but there's so many of them it's hard to keep track. Cheap enough on eBay for a no name bar mixer.
For tonight, two ballofixes and a spray handset on the end. Bit of balancing and away you go.
1 hour ago, ProDave said:
No shower tonight then......
I had a nice bath with Christina Novelli!
@Hecateh did you know who she was or look it up?
If the former then well impressed!
fd2c587db682188197abd7084852ea48--never-too-old-techno.jpg.3d820105a0d21cec2c8982537dd80209.jpg
Edited by Onoff
I knew the name (through my kids though)
But what made me smile was the predictable unpredictability of your response ?  ?
My youngest is very into Panic At The Disco. Surprisingly good.
You've intrigued me enough to visit Youtube.  It's certainly a lot more listenable than the techno stuff my son listened to in his teens (he's 41 now.  I generally only heard a less than rythmic thumping through the floor.
I liked Kraftwerk, OMD which I guess were early techno (Yes? No?)
Kraftwerk, now you're talking. Got loads on vinyl. On my bucket list to see them live. Amazing how many modern artists sample them. There's was a good article about Chris Martin from Coldplay approaching them to use Computer Love on "Talk". He said he was already starstruck and in awe of them plus dreading they would refuse permission.
Can’t warm to techno at all. Suggest something that might convert me. Not a lover of rap either. Give me something like The Clash any day!
