July 15, 20188 yr Author 4 minutes ago, Nickfromwales said: Sock bin? Gonna need an MVHR extract in there Yep, did think about linking to the pan extract somehow. Or at least a louvre top and bottom of the door. I imagine the cupboard will be shelved for bottles & potions.
July 29, 20188 yr Author Pressure testing the towel radiator loop with my silly mains pressure! Holding at 8bar.
July 29, 20188 yr On 15/07/2018 at 11:12, Onoff said: Yep, did think about linking to the pan extract somehow. Or at least a louvre top and bottom of the door. I imagine the cupboard will be shelved for bottles & potions. “ bottles and potions “? ; beer and magic ??? ?
July 29, 20188 yr Author 19 minutes ago, pocster said: “ bottles and potions “? ; beer and magic ??? ? Magic potions likely seeing that the missus is a witch...
July 29, 20188 yr 2 minutes ago, Onoff said: seeing that the missus is a witch... Probably only when you're being an arse
July 29, 20188 yr 9 minutes ago, Onoff said: Magic potions likely seeing that the missus is a witch... Best include a broomstick store as well then. I built a tall slot in the utility room airing cupboard, designed to take an ironing board, hidden, out of the way and secured so it couldn't try and open itself and fall over. SWMBO was not amused when she saw it, asked what the tall slot was for, and I jokingly replied that it was a dedicated storage space for her broomstick...
July 29, 20188 yr Author 23 minutes ago, JSHarris said: Best include a broomstick store as well then. I built a tall slot in the utility room airing cupboard, designed to take an ironing board, hidden, out of the way and secured so it couldn't try and open itself and fall over. SWMBO was not amused when she saw it, asked what the tall slot was for, and I jokingly replied that it was a dedicated storage space for her broomstick... I lad I knew walked into his MIL's kitchen to find her standing there holding a broom. "What's up Maureen, can't start it?" said he.
July 29, 20188 yr Author Finally got the old incoming mains re-routed to feed the Geberit cistern! Not sure still how I'm going to finish off the back of this cupboard! Isolation via a decent Pegler valve: And good access from the back of the cupboard: I need to hack off the old incoming iron pipe below the concrete and infill that bit...angle grinder straight through? Do I need to "cap" the iron once cut? It goes nowhere, just out under the footings, about 700mm down where it's happily rotting away. Ta.
July 30, 20188 yr Author 2 hours ago, Nickfromwales said: Load of pink grip and a metal dowel banged in will suffice as a cap end. Might have to be whatever generic (Sticks Like, No More etc) one I have kicking around here. Must put a screen up so I don't shower the bath with sparks!
July 30, 20188 yr Author 14 hours ago, Onoff said: I lad I knew walked into his MIL's kitchen to find her standing there holding a broom. "What's up Maureen, can't start it?" said he. EX MiL I should have mentioned, don't think she was on his side when the marriage went t!ts up!
July 30, 20188 yr Author Anything to put off this tanking! I filled the floor void at the back of the cupboard. Wetted the void with 5:1 SBR then 4:1 concrete made with the same SBR mix: Made a start on drilling thru for the bath cabling. Some frpb in the little cupboard outside the bathroom where the relocated bath controls will sit at a convenient height (they were strapped u/side the bath originally). The black plastic things come off of heat shrink reels I use at work and fit into a 50mm Starrett cut hole a treat: Tapered the pockets too with tile adhesive. Running out of excuses. Need to do a beer run so I can think straight!
July 30, 20188 yr Author Pressure testing the towel radiator loop over the last 24hrs and it's dropped by a bar. Can't see any leaks though, at least at the testing end or 6 elbows! There's one hidden elbow on the RHS in the wall that's straight onto Pex-Al-Pex. Nothing on the floor though. Ambient has dropped massively though. Could that be it? I bled it pretty well I thought too. Via the drain valve one end of the loop until it ran bubble free. Edited July 30, 20188 yr by Onoff
July 30, 20188 yr Temp does have a big affect on pressure, so could well be that. Chill. Tanking wasnt as bad as I thought it would be - just a bit slow with a brush / roller combo. Ive got tiling to do next - putting it off but need to man up now really.
July 30, 20188 yr Author Interesting that the label on the membrane container says that Everbuild 503 SBR Bond can be used as a primer if the actual Aqua Seal primer isn't available:
July 30, 20188 yr Author 18 minutes ago, CC45 said: Temp does have a big affect on pressure, so could well be that. Chill. Tanking wasnt as bad as I thought it would be - just a bit slow with a brush / roller combo. Ive got tiling to do next - putting it off but need to man up now really. How did you apply the primer and did it go far enough?
July 31, 20188 yr I used a brush for the primer. A roller would work fine. I then used this https://www.toolstation.com/shop/Painting+%26+Decorating/d150/Tile+Adhesive+%26+Grout/sd3107/Mapei+Shower+Waterproofing+Kit/p71005 Cheaper than screwy. This kit is a cheap way of getting the tape. When the tanking solution ran out I then bought this to finish the job https://www.screwfix.com/p/mapei-aquadefense-waterproofing-membrane-7-5kg/8531D?tc=BT3&ds_kid=92700030932191871&ds_rl=1245250&ds_rl=1249484&gclid=EAIaIQobChMI4MXP-ZnK3AIVRbDtCh0UggmVEAQYAyABEgKYbfD_BwE&gclsrc=aw.ds&dclid=CJyg0PuZytwCFfQW0wodoDkFGg If you need more tape then you may find the 1st one is the cheap way of getting 10m of it - the rest of the stuff is effectively free. Go for it. Primer does more surface than the kit tanking membrane will. Edited July 31, 20188 yr by CC45 addition
July 31, 20188 yr Author 11 minutes ago, CC45 said: I used a brush for the primer. A roller would work fine. I then used this https://www.toolstation.com/shop/Painting+%26+Decorating/d150/Tile+Adhesive+%26+Grout/sd3107/Mapei+Shower+Waterproofing+Kit/p71005 Cheaper than screwy. This kit is a cheap way of getting the tape. When the tanking solution ran out I then bought this to finish the job https://www.screwfix.com/p/mapei-aquadefense-waterproofing-membrane-7-5kg/8531D?tc=BT3&ds_kid=92700030932191871&ds_rl=1245250&ds_rl=1249484&gclid=EAIaIQobChMI4MXP-ZnK3AIVRbDtCh0UggmVEAQYAyABEgKYbfD_BwE&gclsrc=aw.ds&dclid=CJyg0PuZytwCFfQW0wodoDkFGg If you need more tape then you may find the 1st one is the cheap way of getting 10m of it - the rest of the stuff is effectively free. Go for it. Primer does more surface than the kit tanking membrane will. Ta. A few pics over on my Tanking thread. Slowed a bit waiting for the wall drain inbuilt membrane to dry. Bought a second kit off Amazon. Should have got the Mapei one you linked tbh to save waiting for the sake of a fiver. Can't see Aquaseal/Mapei not being compatible. https://www.amazon.co.uk/dp/B006FTESLW/ref=pe_3187911_185740111_TE_item Edited July 31, 20188 yr by Onoff
July 31, 20188 yr 6 hours ago, Onoff said: Wtf? I can't see a leak anywhere! Dropped a little more maybe? At 7 bar you will see even the smallest temperature fluctuations ..! Ever considered your cheapo gauge is letting by.....??
August 1, 20188 yr Author Looks like I've got to extend just one screened cable, result! Has anyone seen the bath control box? Seriously, wtf did I put it??? Edit: It appears SWMBO has "tidied it up"! "Grey thing with grommets and a black lead?" she said... She's now looking, I'm now drinking! Edited August 1, 20188 yr by Onoff
August 3, 20188 yr Author Not acheived much today...too flamin' hot! Each 12V deck around the bath has its own 25mm duct so replacing should be a doddle. All connections are outside the bathroom in an accessible cupboard/ riser:
August 3, 20188 yr Author Well we have lights and bubbles! All off a plug top at the mo but I want to check for leaks before closing the bath in. Hot and cold ran out before I could fill above the jet line...it's just about on it. Light on/off works fine but jets are either full whack or off...what I think is the jet control does nothing... Found one snapped wire on a pcb connector, no surprise there seeing how long it's been sat! Going to sit down with a beer now and read the instructions!
