I've been getting my bits from WUNDA and wondered ( ? ) if their floor probes (aka Thermostat sensor) are any good? Being something that gets cast into the screed I can't change my mind later.
Also, in terms of placement within the room. Should they be placed near the start of a floors circuit (B) or mid circuit (A)? Near the start makes sense to me as the purpose of the sensor is to protect floor finishes and so the hottest point needs to be detected, but I may be missing something.
Finally, I also assume that the Thermostats can only take one temperature sensor input.
@Nickfromwales Is the doctor in session?
you don't cast them in, you cast in a short length of pipe with a closed end (or similar) and feed the prove into this thermopocket.
Cool, that allows fixing them if they break which is good. Can you recommend a type of pipe to use?
See the lone, 16mm, pex-al-pex  pipe with the taped over end, thats where my floor probe runs to:
SAM_3349
Peter gave it to me years ago...it's still not connected to anything but then neither is the UFH!
Mine comes up through the slab and exits just outside the bathroom in what is now a slim services "cupboard":
20161213_222459
SAM_3349
Easy when you know how!
I'll have to avoid crossing  over like you have as I don't have the mesh, but where I have serpentine pattern I can just go between two loops.
I see you have put your sensor at the hottest point (B from my original post)
Edited by MortarThePoint
55 minutes ago, MortarThePoint said:
Looks good and very neat PIR insulation
Just a pity it's not all connected and working! ? SWMBO seems to have a mental block on me now digging up the adjacent room in the last photo.
In addition to one under the slab, in the ground to all intents, and a couple in the middle of the zones I placed one sensor, pocket pipes anyway, In the floor about 1m back from the windows. It struck me that I might like to know if the sun is doing its job before it gets ahead of us and to allow me to move heat from zones getting sun to zones not getting sun. I swither about this being a good idea or not, when I put them in I am sure I had a way of determining a control schema but I cannot for the life of me find my notes and right now, in response to this thread, I am struggling to work out what the plan was.
Things like this usually get added to the growing stack of "good ideas", and fall to the wayside when you realise that life is too short to worry about things as minor ( even more so when there is an ever-growing list of things far more major to tend to ).....
A good idea to put the offcut UFH pipes in as conduits, and simply run them to a single back box with a blank plate on, and a Cat 5/6 back to a plant / data location for 'Justin'.
Most stats use something like a 10K Ohm NTC probe. These are readily available for a £few so you don't really need to spend silly money for the ones from the UFH company if you decide to buy spares.
  • 1 year later...
any idea where to source longer (say 8m) 10k NTC sensors please?
I bought a remote probe, thought it was a good idea at the time.  Found in a box the other day - full of other good ideas at the time. Where I was going to install I removed the thermostat, didn't need it.
Do you need them - no, unless you embed as a high temp cut off to protect a delicate floor covering.
NTC sensor + 8m of cable = profit.
/ in other words, just extend the cable...
11 hours ago, Radian said:
It's a minefield for sure. How to spot a fake DS18B20
Yes, but not as much as trying to find a website that gives the correct advice.
Seems every site has a different opinion about how to spot a fake.
I just buy them, then calibrate them to see if the readings are sensible.
