Russell griffiths Posted September 14, 2020 Posted September 14, 2020 Morning two part question, I have a vented cylinder that is heated just with an immersion heater, a couple of days ago the cylinder boiled and expanded into the loft tank, so I fitted a new immersion thermostat. What should be the hot water temperature at the tap, I think there is a set temp to stop nasty bugs breeding, it was previously bloody hot, so it’s a bit more user friendly now, however it’s affecting our mixer shower, so I want to start at one point and work out where to go from. Cheers.
ToughButterCup Posted September 14, 2020 Posted September 14, 2020 40 is the safe temperature set in our Hansgrohe iBox. That's the German setting so the UK one must be higher... ?
scottishjohn Posted September 14, 2020 Posted September 14, 2020 (edited) On 14/09/2020 at 06:27, Russell griffiths said: What should be the hot water temperature at the tap, Expand that will depend on size of your tank -if you have to add cold water to it--then maybe its too hot ,but if tank is small then will need to set hotter and add cold at point of use I set my hot water form my solar tank to exit at 45c - I did this fitting a mixer at tank exit so i could get best temp gain from my panels when available most normal days water in tank would be 80c+ at top where dhw was pulled from lower down where UFH coil was30-40c due to size of tank 300litres If there is a next time then much bigger tank and store at lower temp .but still with mixer at outlet. I still hope I can use solar thermal for allm ywater heating needs inc UFH --but canot do any more planning untill I have a fixed house design and heat loss calcs I have a 5000litre tank i made up 10years ago with input +out put colis fitted --a GRP ex chemcial pressure tank my guess is that sunk in a dry hole surrounded with concrete and PIr might be big enough --time and costings will tell Edited September 14, 2020 by scottishjohn
SteamyTea Posted September 14, 2020 Posted September 14, 2020 I had my cylinder set at 50°C, but have recently lowered it to reduce losses. It needs to be as low as possible, but still needs to deliver enough hot water. In a way, only you can answer that. If you feel it is too hot, turn it down. I don't have a thermostatically controlled shower, it is just a basic valve that blends the hot and cold, worked well for the last 15 years.
Russell griffiths Posted September 14, 2020 Author Posted September 14, 2020 Is there not a temperature setting that it needs to be to kill of legionnaires disease.
ma9mwah Posted September 14, 2020 Posted September 14, 2020 I think the thought is that for anti-legionnaire then a vented system is should be >=60c. For unvented then the risk is much smaller that you can run to 45c (good for ASHP people)
joe90 Posted September 14, 2020 Posted September 14, 2020 The consensus over the years on this forum is that legionnaires occurrence in domestic circumstances are almost zero So many of us only heat to about 45-48’. I would set as low as possible and slowly increase it if it’s needed. The lower the tank temp the lower the standing losses.
SteamyTea Posted September 14, 2020 Posted September 14, 2020 On 14/09/2020 at 09:54, joe90 said: consensus over the years on this forum is that legionnaires occurrence in domestic circumstances are almost zero Expand Yes, it is a rather specific, and unique set of circumstances. Why it generally a problem with old cooling systems, and not DHW. On 14/09/2020 at 09:54, joe90 said: set as low as possible and slowly increase it if it’s needed Expand What I do when I have guests. 20 seconds with a small screwdriver.
PeterW Posted September 14, 2020 Posted September 14, 2020 On 14/09/2020 at 09:54, joe90 said: The consensus over the years on this forum is that legionnaires occurrence in domestic circumstances are almost zero So many of us only heat to about 45-48’. I would set as low as possible and slowly increase it if it’s needed. The lower the tank temp the lower the standing losses. Expand That is for unvented cylinders On 14/09/2020 at 09:31, Russell griffiths said: Is there not a temperature setting that it needs to be to kill of legionnaires disease. Expand For a vented cylinder it is 65c periodically but ideally you should have some sort of blending with cold prior to stop scalding. I run a vented tank at 53c on gas and occasionally push the immersion to take it to 65c
joe90 Posted September 14, 2020 Posted September 14, 2020 On 14/09/2020 at 10:02, PeterW said: That is for unvented cylinders Expand Ah, didn’t read post properly ?
ProDave Posted September 14, 2020 Posted September 14, 2020 Yes it was agreed for an unvented cylinder fed with treated mains water there was no legionairs risk, but you cannot say that for a vented tank fed cylinder so it would be wise to regularly heat it to 60 degees or more.
Russell griffiths Posted September 15, 2020 Author Posted September 15, 2020 Ok back to my water problems. I decided to go and get a thermometer so we can get some figures to work from. The temperature at the hot tap is 56 so knowing the risk of legionaries is low in a domestic situation then that is probably fine. However this is lower than the scalding temperature it was previously and that has had a knock on effect on the thermostatic mixer shower. The temperature at the shower head is 37 which we find too cold. So a couple of things Anybody know what sort of temperature these mixer valves are set too it’s a reasonable expensive MIRA one as recommended by @Nickfromwales 3 years ago. If the input from the tank is 59 why is the mixer mixing it down to 37 when previously it was hotter. Are these mixers adjustable, I remember when it came there was a funny blue spanner thing with it for some sort of maintenance. I will need to dig out the manual and have a look, but it’s easier asking you lot from the comfort of the sofa than having to deal with the mess I call an office. Cheers russ.
ToughButterCup Posted September 15, 2020 Posted September 15, 2020 I've used Hansgrohe iBox. It has a 'settable ' default temperature (40).
dpmiller Posted September 15, 2020 Posted September 15, 2020 Is the cold water tankfed too or is it at a different pressure to the hot? Might be the valve is a little unbalanced at the lower temp...
