Our build has quite a lot of decorative cladding - the brown bits in the pictures (the white bits are brick). Our architect has specified aluminum cladding here but it seems very expensive and not DIY friendly. I'm considering switching to corten steel sheets instead with visible screw fixings and a gap between the sheets for expansion.
I've attached the architect spec for the wall build up for aluminium cladding. Basically it is fixed to 18mm ply on batons to give a cavity behind. Does anyone have an equivalent spec if I use corten sheets instead? In particular, does it need the ply backing or can I fix it straight to batons? How do I fix it - should the screw holes be oversized for expansion, how many fixings, how much gap between each sheet, should the gap be filled with anything like rubber gaskets, etc.
Also what thickness of sheet is appropriate. 1.5mm and 2mm seem common. I'd like it as light and easy to work as possible but don't want any crinkles or dents.
And finally is this a good idea or am I missing something?  All thoughts appreciated ?
Yes, that has crossed my mind. If the drips drop down I think the run off can be managed to avoid the bricks. But if they are blown around in the rain and streak sideways then yes it's going to be an issue. My fallback plan is to hose the bricks down but am not sure if that will remove the stains.
It's a very good point.
Our architect has been great but has also been paid so she isn't keen on changing the design, especially for free. But she recommended the Kingspan corten cladding solution. I'm pretty sure this comes in stable sheets of corten wrapped around insulation. I'm going on their installers training course next week to find out more. But my gut feeling is that it will work out far more expensive than plain sheets.
I also went on the Tata Steel Colorcoat-Urban course for painted steel cladding. It was impressive, easy to fix, belt and braces watertight and in budget. But the panels fitted quite loosely and didn't give a flat, smooth finish. Also the colour palette is very limited for small orders.
Thanks for the rust advice, it has put me off a lot. The question is what cladding to use instead. I tried to get PPC aluminum cladding quotes based on our plans but the only company who seemed to consider the job properly came back with a quote of nearly £20k. Nothing came in under £12k. Colorcoat Urban came in at £4k which is in budget but like I say, we didn't like the product for our house. Black timber cladding is to our taste and might be where we end up. It's also a possibility to have elements of corten in areas well away from the brickwork such as around the staircase.
Decisions decisions.
I live near the GD "Rusty House".  I have not noticed any streaks but I think this risk was largely designed out.  They have even done boundary fencing in the same stuff.  I they have perforated panels.  I think it was expensive.
I am not very keen on the look.  The guy who installed it found it a pain to work with.  I have read that the material can sometimes suffer from premature failure due to corrosion.
Love the idea, and think it will look stunning in corten!
Have you spoken to the house on Wood Crescent who already have that in place mixed with black timber cladding?
No, it will not, you will have rusty staining on everything it touches. Once the layer or protective rust has set up it certainly stops, but by that time it is too late for the materials it has stained.
Google New York Corten Steel road staining - I remember it was used on a job years ago, and there were a lot of concerns about the staining, and someone produced a photo of a whole road in New York that was rusty coloured from a new building. It was there for years!
Nice in the right situation, but needs managed.
58 minutes ago, Russell griffiths said:
Have you looked at a product called rockpanel
we are looking at it for a couple of elements of our place. 3781486E-D2E6-4F5E-9C34-EF0F57421B98.thumb.png.3d09264bc43b3fbd8c852a0e0d522d4d.png
That's exactly what I thought of. I got some samples and one of them basically looks like rusted steel. I'd guess much easier to work with and install than the steel. I've had the samples outside for over a year now, and they look perfect. Great material, I'll be using if for my soffits and fascia. Would like to use more of it, but can't as we're in a conservation area.
15 hours ago, Sensus said:
I'm pretty sure it won't: I've had to deal with the removal of rust stains from brickwork for developers, where non-stainless fixings were used for timber cladding. We had to use oxalic acid to get rid of it (and they weren't white bricks).
had the same problem where  an aerial pole was  attached to my feature fyfe stone exterior chimney structure on end of house
 anyway
years on and the clamps that were used for aerial pole were not S/S ,by this time i was on sky so pole had gone --but the stains remained
asked many builders  how to get rid of stains and tried acids etc
---end of the story
 i got a sandblasting attachment for my karcher power washer and a bag of kiln dryed silver sand
blasted it all and it took it out --but  watch out for the over spray
I should have covered it  even though it was  not that close
i have an upstairs slightly sand blasted window   now,  LOL.
Do you have any idea of the price and whether they sell direct rather than through installers. I've gone through my samples pile and found some and it might work.
Would Equitone tectiva Sahara be an alternative? Durable, no staining & can be face or secret fixed. We are using their Pictura as an alternative to render.
Nope, just got a sample.
Maybe... I've ordered some samples thanks
  • 1 year later...
Did you end up going for the corten? I have a build specified in corten cladding and I am looking at fixing and purchasing information. I am too concerned about the staining? Thanks
  • 4 months later...
  • 2 years later...
Any of those that comment run with Corten?  Looking for advise on a new build.  I have been told you need minimum 6mm sheets to prevent them simply rusting away?  Often seeing people say theirs is 1.5 to 2mm - how are they holding up?  Cheers
>>> minimum 6mm sheets
Steel is properly heavy - about 3x the density of aluminium. You would need quite a a serious structure to support a 6mm steel skin - each m^2 on 6mm would weight about 50Kg. Or make the corten steel itself structural, weld and support by say a steel frame.
I'm not sure why the OP decided aluminium was not DIY friendly. You can get custom cut and custom powder coated panels made fairly easily. Aluminium is soft, so you need to be careful fixing to avoid dents and creases, but I would think aluminium shingles would be v DIY friendly.
