Hi All,
Couple of questions about Joist hangers, (joists butted up to steel beam with timber infill)
1. Joist hangers, nailed or screwed (or both) - I have got twisted nails at the ready but I have always favoured screws over nails.
2. I have been advised to fit noggins between the joists to stop twist - how close to the hangers should they be and should they be the same depth as the joists and can I stagger them so they are easy to fix.
Thank Wozza.
Nail them.
Nails for shear loads, screws for tensile.
And dwangs/noggins should either be full depth or criss-crossed.
But if you are gluing and screwing the flooring down, that will stiffen everything up a lot too.
2 hours ago, Adrian Walker said:
I'm working on a new build and the Building Inspected told me to nail every hole on the hanger that I still have access to. Crazy
No, why?
thats what there designed for.
6 minutes ago, Adrian Walker said:
50+ nails per end?
Why don’t you check with manufacturer, that does seem a lot. Every hole, that’s what they designed them for, that’s how they will be load tested.
Are you using a jiffy hanger, the bendy ones, if so nail the full height of the joist and bend the top over and chop off with snips.
Edited by Russell griffiths
5 minutes ago, Adrian Walker said:
50+ nails per end?
Never seen that many. Do you have a link to the hangers you are using?
