I know there are quite a few on here who have had treatment plants installed and I am looking to recommend one for a neighbour, I am really wanting to know how often people have had them emptied in real life - not what the packet tells you. I’m only interested in ones that have not provided problems. Some people come to mind @ProDave @Stones but there must be others. Would be good to get a top 3 so that I can pass the info on. Thanks
I had ours emptied after 18 months (plant serving family of four).
Tanker driver whose judgement I think has some weight, suggested emptying every two years, so that's what I've settled on.
I'm interested in this as well, as my tricel saga is continuing.
Would a variable be how well you treat your tank?
Not just the servicing but whether you look after the bacteria?
Is that classed as for 6?
This table has come up before on BH/
https://www.wte-ltd.co.uk/choose_wastewater_treatment_plant.html
I expect so as it’s the same for a septic tank, treat it well and it can be years between emptying......
Yes, although 8 person capacity could apparently be achieved by increasing air flow rate.
Ours is the Conder. The plant is sized for 6 people (BR says 5 for the number of bedrooms so 6 was the closest) but only used by 3.
It has been in use for 2 1/6 years and not emptied yet. It was on my "to do" list but I missed my window * so I plan now to get it done in the spring.
*Our plot has a seasonally high water table. I prefer to get the tank emptied in a period or low water so as not to tempt fate and "test" how well it is concreted in, and it turned wet before I got around to it this year.
We have a BioPure (looks near-identical to @ProDave's Condor).  The recommended service interval is two to three years, depending on how heavily loaded it is.
When looking around I quickly decided to ignore all the units with mechanical moving parts in the tank, as they looked like a nightmare to service or repair.  The air blower units all seem similar, and the conical shaped ones, with an integral clarification tank, seem simpler than any of the others.
I think it's worth locating the air  pump away from the unit, both so it can be put in a sound proof enclosure (in a very quiet area the hum is noticeable).  It also makes servicing the pump simpler and easier if it's in an easy to access remote box.  I mounted ours in a stone box, with an insulated, hinged lid, and just ran the air pipe down to the unit.  This also makes servicing the unit easier, as the pump doesn't need to be disconnected and lifted out before the treatment plant lid can be removed.
Ours I installed myself with no previous experience
Really easy to install
There are two of us in a five bed three bath So had to have a 8 pop
The company MD told me check it after 3 years If the water is free of debris leave it another year and check She thought five or six would be about right
I told her the tank guy who emptied the neighbours recommended each year
She laughed and said I wonder why he would say that
I new so little about the treatment plants I nearly bought some of the bacteria tabs off eBay
Again she said leave a poo a week and there will be plenty of bacteria
She did say that she had heard of people hanging a dead chicken in there
Not sure about that
17 minutes ago, Cpd said:
@nod what type please?
Sorry Bio v
1-7 pop
Looking at the leaflet
3-5 years emptying
96% efficient
anyone got any suggestions for a sloping percolation field ,as looking at tech dat they all want a flat area --which is going to be hard to find ,
no water courses -ground is mostly bedrock
1 hour ago, nod said:
Sorry Bio v
1-7 pop
3-5 years emptying
96% efficient
Just a point to make with the installation
All the companies I spoke to would make the tank to order Inlet and outlet at what ever height I needed
I was having difficulty gauging accurately where the inlet outlet needed to be As I had to fit a tank to our neighbours existing drains
So decided to do both before the foundations went in
Neighbours easy ours best guess
The local tank company said keep it low and they would fabricate a neck extension at a later date
£100
Adding a 220 mil neck extension 18 months later made life so much easier
We have a self installed WPL Diamond DMS2 which supposedly has four year emptying. After two and a half years the diaphragm in the Secoh air pump split due to the back pressure from trying to pump through the sludge so we had it emptied. We decided it would probably last two years but we actually have it emptied once a year which is done in the summer. This is for two adults occupying 24/7. Edit: I notice their website now says up to three years for emptying.
Edited by PeterStarck
good info
I installed a Vortex myself, built for 6 but only 2 of us, been In use less than a year, will look next summer to see how it’s doing. With regard “looking after” your plant I guess that means being careful with what you put in it (bleach etc).
What is the air diffuser like? Is it just a perforated tube?
Our Solido Smart has a double-wall diffuser, the outer is a perforated silicone material which balloons out slightly when pressure is applied, allegedly making it self-cleaning...
TBH I can't remember exactly. I installed it nine years ago and I think it's quite basic, just a metal tube that the air comes out at the bottom.
20 hours ago, nod said:
Sorry Bio v
1-7 pop
3-5 years emptying
96% efficient
sorry to be a bore @nod but could you give me a but more detail on the make / model as when I type in bio v I don’t get far on googol......thanks
No problem
if you look on eBay at Bio-pure
The top search is identical to ours
1-7
