scottishjohn Posted June 7, 2019 Posted June 7, 2019 this looks is very interesting development in TF construction --
Simplysimon Posted June 7, 2019 Posted June 7, 2019 progress, they'll get there in the end...... just use an i beam ?
Russell griffiths Posted June 8, 2019 Posted June 8, 2019 I did watch that the other night and thought that the yanks had gone about this in a strange way, i joist and celotex would do exactly the same.
Ed Davies Posted June 8, 2019 Posted June 8, 2019 10 hours ago, Simplysimon said: progress, they'll get there in the end...... just use an i beam With a lot of labour and some thermal bridging for the blocking which I-beams need.
PeterW Posted June 8, 2019 Posted June 8, 2019 I did wonder about the strength in the dowel system that they used as it seemed a bit “rustic”....
Ferdinand Posted June 8, 2019 Posted June 8, 2019 (edited) Need help here. Can someone convert an R20 wall into European for me? It seems to be a US terminology that is rarely explained. I have never made the calculations quite work as straight R values. 2.25 inches of foam insulation does not seem like a lot, and he suggested that that removed the need for anything else. Thanks Ferdinand Edited June 8, 2019 by Ferdinand
andyscotland Posted June 8, 2019 Posted June 8, 2019 (edited) R is 1/u and vice versa. So R20 is a u value of 0.05 (against 0.13 for standard timber). I don't think he was saying that's all you need, you still have e.g. wool between studs at 0.039 but the studs form much less of a thermal bridge. So you can get a good overall wall u-value without having a secondary continuous layer of insulation in front of / behind the studs. Edit: this post is nonsense but I'm leaving it as an example of what happens if you come on here before your morning coffee. Edited June 8, 2019 by andyscotland Incorrect information
Jeremy Harris Posted June 8, 2019 Posted June 8, 2019 23 minutes ago, andyscotland said: R is 1/u and vice versa. So R20 is a u value of 0.05 (against 0.13 for standard timber). I don't think he was saying that's all you need, you still have e.g. wool between studs at 0.039 but the studs form much less of a thermal bridge. So you can get a good overall wall u-value without having a secondary continuous layer of insulation in front of / behind the studs. Bear in mind that video is from the USA, so the R value is in US units, not metric. The U value is definitely not 0.05 W/m².K, it's more like 0.24 W/m².K.
andyscotland Posted June 8, 2019 Posted June 8, 2019 @JSHarris ahhhh thanks - I had no idea the US R values were different! Though of course it makes total sense that they are...?♂️
Ferdinand Posted June 8, 2019 Posted June 8, 2019 (edited) 43 minutes ago, andyscotland said: R is 1/u and vice versa. So R20 is a u value of 0.05 (against 0.13 for standard timber). I don't think he was saying that's all you need, you still have e.g. wool between studs at 0.039 but the studs form much less of a thermal bridge. So you can get a good overall wall u-value without having a secondary continuous layer of insulation in front of / behind the studs. Was working on this. There is no way his wall with 55mm of foam has a u value of 0.05, which is half of the u value of one of our walls with 150mm of celotex, and about twice as good as required by passive. And he was talking about R30, nevermind R20. When I renovate a solid 9” brick wall I roughly need 75mm of PIR to get under 0.25 for the u-value. So .. is there a rule of thumb for getting to grips with these USA units? Cheers Ferdinand Edited June 8, 2019 by Ferdinand
Jeremy Harris Posted June 8, 2019 Posted June 8, 2019 15 minutes ago, andyscotland said: @JSHarris ahhhh thanks - I had no idea the US R values were different! Though of course it makes total sense that they are...?♂️ The US use °F·ft2·h/BTU for R values, whereas we use K·m2/W .
andyscotland Posted June 8, 2019 Posted June 8, 2019 1 minute ago, JSHarris said: The US use °F·ft2·h/BTU for R values, whereas we use K·m2/W . That's basically an entire sequence of units I have no concept of apart from the hours! And perhaps the ft2 if I picture it as a ruler by a ruler ?
Ferdinand Posted June 8, 2019 Posted June 8, 2019 1 minute ago, JSHarris said: The US use °F·ft2·h/BTU for R values, whereas we use K·m2/W . If I wear a stove pipe hat like Mr Brunel, will it teleport be far enough back in time to do an appropriate Mindwarp? Let’s do the mind warp again... 1
andyscotland Posted June 8, 2019 Posted June 8, 2019 6 minutes ago, Ferdinand said: Was working on this. There is no way his wall with 55mm of foam has a u value of 0.05, which is half of one of our walls with 125mm of celotex, and about twice as good as required by passive. And he was talking about R30, nevermind R20. When I renovate a solid 9” brick wall I roughly need 75mm of PIR to get under 0.25 for the u-value. So .. is there a rule of thumb for getting to grips with these USA units? Cheers Ferdinand Indeed. My post was mince from start to finish, with the possible exception of the bit that it just makes the timber good enough to avoid it being a thermal bridge through the surrounding wool. 1
Ferdinand Posted June 8, 2019 Posted June 8, 2019 8 minutes ago, JSHarris said: The US use °F·ft2·h/BTU for R values, whereas we use K·m2/W . So based on 9/5 F = 1 C, 10.74 square feet = 1 square metre, and 1W = 3.5 BTU/hr, my fiddle factor for converting a USA R value into a European R Value is about 5.5 as a ratio with no dimensions. Which means that his R20 wall has an R Value of around 3.6, or a U-Value of around 0.28. If I call 5.5 to be 5 to within an engineering approximation, that is 4 and 0.25 for those numbers. And that is near enough for me to think with on the fly, so I am happy. Cheers Ferdinand 1
scottishjohn Posted June 8, 2019 Author Posted June 8, 2019 2 hours ago, Russell griffiths said: I did watch that the other night and thought that the yanks had gone about this in a strange way, i joist and celotex would do exactly the same. not convinced you will ever get celotex packed in an i-joist or anything as well as this integrated stud. you could of course use your I-joist and spray foam them ,but a different way and no metal in wall
A_L Posted June 8, 2019 Posted June 8, 2019 31 minutes ago, Ferdinand said: So based on 9/5 F = 1 C, 10.74 square feet = 1 square metre, and 1W = 3.5 BTU/hr, my fiddle factor for converting a USA R value into a European R Value is about 5.5 as a ratio with no dimensions. Which means that his R20 wall has an R Value of around 3.6, or a U-Value of around 0.28. If I call 5.5 to be 5 to within an engineering approximation, that is 4 and 0.25 for those numbers. And that is near enough for me to think with on the fly, so I am happy. @Ferdinand , you would be better using 6 rather than 5 as the correct value is 5.678.
Ferdinand Posted June 8, 2019 Posted June 8, 2019 (edited) 15 minutes ago, A_L said: @Ferdinand , you would be better using 6 rather than 5 as the correct value is 5.678. Yes, but for intermediate calcs when doing approximations I tend to work in 5s and 10s then adjust by multiples of 10% at the end. And here I am just after something better than a guesstimate. That is growing up with Countdown. So 6 would be 5 plus 10% twice. But thanks. 5.678 is a nice one to remember. No idea how other people do this. I have a mate who counts indetermine numbers of ‘things’ by mentally arranging them into dominoes. And this is also why I will personally put out a contract on any politician who sets VAT to a Prime Number. Do people who grew up with LSD work in 12s and 6s? Which does actually fit with dice and dominoes. F Edited June 8, 2019 by Ferdinand
Jeremy Harris Posted June 8, 2019 Posted June 8, 2019 5 hours ago, Ferdinand said: Do people who grew up with LSD work in 12s and 6s? Which does actually fit with dice and dominoes. Not really, I just think of psychedelic patterns and things moving when they shouldn't...
Simplysimon Posted June 8, 2019 Posted June 8, 2019 5 hours ago, Ferdinand said: Do people who grew up with LSD work in 12s and 6s? Which does actually fit with dice and dominoes. F can't remember, i keep getting flashbacks
