Kelvin
Everything posted by Kelvin
Does anybody remember the game SimCity2000?
Kelvin replied to Adsibob's topic in General Alternative Energy Issues
The flight from FF is going to have to consider every possible option including this. It wasn’t possible until we had reusable rockets with big payloads which we now have. Whether it make’s commercial sense vs terrestrial PV solutions is to be determined. Everything based in space is hard and costly and that isn’t going to change much. -
Builders merchants feeling the pinch
Kelvin replied to nod's topic in General Self Build & DIY Discussion
Businesses everywhere behave like this. Supply and demand. It’s not great but you pay when demand is high and benefit when demand is low. I am rather hoping we’ll benefit as our build starts at the beginning of April. -
It’s above the front door in our case. But it depends what’s beneath it I guess
Yep. The gutters were full of moss so I thought it was but still doing it after I cleaned them. Only happens with very heavy rain. The guttering is quite narrow though which doesn’t help.
I’m not necessarily seeing much change in Perthshire yet. -
The farmhouse we rent has exactly what you propose and heavy rain launches off the roof as described
Yes our plant room is designed to be quite central for this reason but it does mean all the MVHR ducting has to be threaded through the ceiling.
Critique of new new build design, please!
Kelvin replied to LnP's topic in New House & Self Build Design
Yes can see why it’s there. -
The problem with balconies is that they seem like a good idea and something you think you’ll use but ends up being something you rarely/never actually use. -
Discharges in Groundwater Source Protection Zone 1
Kelvin replied to Drellingore's topic in Building Regulations
If there’s anything I’ve learned about digging big deep holes use a machine. Done in minutes as opposed to hours. I dug a 21m trench for the electricity ducting to go in. I did have someone coming with a digger to do it for me but it was only a few days before SSEN came to lay the cable so I didn’t want to risk any delays. Took me days to dig it by hand largely because of big stones under the beautiful top soil. Do you know anyone with a digger that could come along for a few quid? When I had a percolation test done they dug multiple biggish holes all around the plot where a soakaway might go (so away from the house) It was surprising how different the results were between the trial pits. -
Planning permission subject to having a S106 Agreement costs?
Kelvin replied to PXR5's topic in Planning Permission
Yes it’s cost us over £1000 here and there for reports we’ve not really needed. Very frustrating. -
Now I’ve looked at your plans you’re probably ok at 950mm as you have double doors across most of the width to give you access.
Ours is 3.6m x 1.2m. I’d say yours is too narrow. What I did is get the measurements for the plant and drew it in the room to get a feel for the space. Assuming it’s monobloc ASHP the exchanger is outside and the only thing inside is the hot water tank and associated components. You might have buffer cylinder too. Our MVHR is in the plant room too as we don’t have a loft.
We had them in a previous house. Out of 5 loos 3 failed (same fault) within 5 years. I had real trouble finding replacement parts and eventually got a box of 5 units from a building company liquidation. Replacing them wasn’t terribly easy either as the space through hole was just big enough for the part and my hand.
We’ve ended up with a similar problem due to some challenges fitting a 4m triple glazed sliding door. Attached to this was a 1m coupling tilt and turn window that could be used as a door as direct exit from the kitchen. In the end we’ve had to reduce the slider to a 3.6m triple glazed slider. The problem this caused is the tilt and turn window is now 1.4m wide and inward opening only so blocks the stairs when open or clashes with the island. It also creates a slight unevenness as the two other tilt and turn windows on this elevation are 1m wide. Our options are fit a fixed light window instead and give up on the door. However, practically I think we’ll use a door more often to exit on to the patio for morning coffee etc than we’ll use the slider so I really want it still to be a door. Our solution is to fit 1.4m wide French doors. Although I believe our window supplier only do them as inward opening. The reason I mention all of this is to test if you are more likely to use a normal door to exit onto the patio than slide open either slider for the morning coffee etc. We felt for us doors would be more practical for daily use. That said, having two sliders would create a very open feel so of all your options 4 is probably best but I’d definitely think through how you think you’ll best use the exit. The renders are really nice. What are they done in?
I made offers on a few plots in the SE. All went for considerably more than I wanted to pay using the thirds guideline. One half acre plot went for £450k and I offered £250k and it wasn’t a great plot. This was also 9 years ago.
The above is a good point. We’re building a modified kit house and it’s designed to minimise the need for a lot of steel supporting the structure -
Self build...built in blinds in windows query
Kelvin replied to Drumlinruby's topic in Introduce Yourself
I have a friend with them. Nothing but trouble. His are accessible for maintenance and he’s thinking of removing the blind completely. It’s just one example of course. That said I’ve been in plenty of offices that have them and seen plenty that are knackered. -
I like it. It’s quite big for just the two of you although I understand your point about your development schedule. Why split the boot room and utility room? I’d remove the wall and have one big room. The size of the plant room is an interesting point as we’ve had that challenge too but I think I’ve solved it. Having looked at all the stuff going in ours it does need to be a reasonable size. -
Got approval letter today. Just wanted to share! Groundswork company lined up to start. It all feels real now!
I asked our window supplier (NorDan) if the glass doors could open outward and they said they only do inward opening doors including the French doors.
Another valuable self build learning experience
Kelvin replied to SimonD's topic in General Self Build & DIY Discussion
Well done on getting the gas safe certification. Due to similar stories I am considering doing similar with some of the trades for our self-build. My dad taught himself every trade as he didn’t trust anyone in our house 😂 -
Like a few others on here I am anti log burners and we aren’t fitting one in our build. That took some ‘negotiating’ with my wife however. Hypocritically though we do have one in the rental and have been using it but are just burning trees that have fallen in the large garden that we seasoned plus the gorse logs I pulled out of our plot last year I have principles and if you don’t like them I have others. 😂 It has underlined how much I don’t like the things though.
