Kelvin
Everything posted by Kelvin
This is very true. I used to drum this into my team at work. Occasionally the decision comes back to haunt you later of course 😂
I watched a Danwood go up just near Blairgowrie and it was impressively quick from the foundation to up and rendered. Nice little bungalow.
You’re never going to notice it. If you think you do then a bit of soft landscaping will address it. I suggest you’re probably overthinking it.
Have you looked here: https://www.bracketfinder.co.uk/tv-wall-bracket-info/tv-size/tv/40/filters=_cat_273__10__53
I could have told you this would happen some day....
Kelvin replied to ProDave's topic in General Alternative Energy Issues
When it was less than 13p / kWh few people would have cared that much either.
This week has been particularly cold so a real test for your system. Milder weather is due next week. We rent a farmhouse with no cavity wall insulation. Even with the oil fired boiler on all day the peak temp in the house is 15oC. The only room we can get it higher is the living room which has a wood burning stove. It’s so cold in the kitchen all the olive oil solidified 😂 🥶
Out of curiosity if it’s a new house built with an oil fired boiler why have you changed it to an ASHP so soon? In any event, you can’t just swap an oil/gas boiler for an ASHP and leave everything else the same. ASHPs operate most effectively at lower temps pumping the heat into a large surface area hence why under floor heating and a big concrete slab works really well. It’s harder to replicate this with rads but you can get much bigger rads or fit an ASHP that runs at a higher temp. Personally I don’t think I’d fit an ASHP into a house without UFH for at least the downstairs.
Can i leave out part of my planning permission?
Kelvin replied to Post and beam's topic in Planning Permission
Same here. I’m going ahead with the garage but have gone through several design iterations to get there to reduce the cost. We’re going with a insulated steel building. Still not the cheapest way to do it but for about £30k including founds we’ll get a 63m2 garage. It’s the first thing going up so can use it as storage etc -
Your ‘Greens are Putins best friend’ comment is a somewhat daft argument against renewables. You can easily make the same point by saying an over reliance on FF plays to Putin. FF aren’t ubiquitous and are controlled by a small number of countries. This gives them significant leverage and control over everyone else. The situation we are currently in was probably always going to happen at some point but the war has accelerated it. -
It’s been widely reported that UK houses are poorly insulated compared to many European houses. Looking at the graphic overall, rather than the absolute numbers, the countries that are the best are the countries many of us would guess to be the best. Even just taking 3G many Northern European countries typically only supply it rather than 2G.
Depends how you organise things. Our design is 202m2 and two bedrooms. Upstairs was designed as two bedrooms but we’ve changed that to a bedroom and an open plan sitting/dressing area (open plan from the stairs) Downstairs there’s a guest room and shower room. There’s a study as well that could be used as a bedroom in the future.
Yep. If I’ve learnt anything this last 8 months check absolutely everything that the professionals send to you or do on-site. I’ve spotted numerous errors and omissions. The architect has been the worst culprit for this.
Our groundswork guy brings someone in to do the setting out.
Stupidly we allowed the design to have a zinc roof
Kelvin replied to CalvinHobbes's topic in Roofing, Tiling & Slating
Architects love zinc. They must be trading in it. I started with zinc but we are now fitting a Catnic Urban metal standing seam roof. I got a quote for Greencoat but it was much dearer than Catnic. Can you not getting a change of material? Most of our warrant says blah blah material or equivalent. -
https://forum.buildhub.org.uk/search/?q="Build costs"&updated_after=any&sortby=relevancy&search_and_or=and
You’re miles out I’m afraid even if you were doing all the labour yourself and plus your costs are a bit all over the place. There are no costs for windows or a kitchen/util room for example. What about MVHR? There are plenty of posts on here about build costs so have a search. Right now build costs have probably never been higher for certain materials albeit some material costs are reducing. If you went with £2500/m2 you would be in a better ballpark figure but there are so many variables.
Should I go with an MVHR?
Kelvin replied to anonymous's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Worth a read. https://www.enhabit.uk.com/2020/07/08/is-mvhr-suitable-for-all-homes/ -
There’s definitely a lot of sympathy. I imagine most self-builders on here will have some story to tell of problems with their build and lessons learnt either from their own experience or the experience of others. If they have frozen it’s likely they will still be frozen unless the temperature has changed significantly or is changing significantly from daytime to nighttime. Therefore why would it still be leaking water?
The plumber couldn’t predict winter was coming and it gets cold possibly below freezing? He’s taking the piss.
What a pia. It’s something that seems wholly avoidable though which is even more of a pia as you’d expect a competent plumber to account for it.
I grew up working on a farm and currently live on a farm. When I was 17 I fell through a roof into an open slurry tank although fortunately it was empty. 😂 I also got kicked in the plums by a calf. The vet was debudding the horns and asked me and another guy to hold on to it. I’d helped the vet a lot so knew what to do. The other guy was a first timer so didn’t realise how the horns are debudded (gas tong things) As as the vet started the other guy immediately let go of the front end and the back end hoofed me right in the stones.
Being told to go and get a proper job doesn’t tend to always be the best approach.
