Creating Visual Block before Planning App
Ferdinand replied to Ferdinand's topic in Landscaping, Decking & Patios
Cheers @A_L What do you think is realistic, and do you have any good alternative or modified suggestions? Cheers Ferdinand -
This is a spinoff from Jeremy's privacy thread. What are the best methods of creating a visual block quickly to disarm some potential "overlooking" objections from ground floor windows into neighbouring gardens, if it needs to look permanent by the time Planning is applied for? 1 - The classic would be a hard landscape feature - say a brick wall, or a 2m closeboard fence, which can then be conditioned to remain. Problem: pricey at approximately £40-£70+ per metre run for the fence and fitting, or perhaps at least £150-£200 per metre run for a decent 2m wall. 2 - Tightly cropped Lleyandii 2m hedge. How long? Does it take about 3 years to grow and be dense clipped to 2m from planting if planted at a tight staggered spacing in a double row? 3 - Are there alternatives to Lleylandii for the similar job? 4 - A fedge? (ie Living fence). These tend to be made from willow and later become thugs unless kept under constant tight control, 5 - Thinking around the box, plant something a little slower and propose a condition that first occupation not be allowed until a dense 2m visual barrier exists? That does not completely disarm the objection. I think my *strategy* would be a quick grower as above, but plan to remove it later and plant something else in front which will be more attractive. The con of that approach is the effective loss of garden when the initial block hedge us removed. Has anyone done this? Thoughts and comments are welcome.
Thanks. If I had the money to build that, I would not have regretted a loss vs inflation for that experience.
Or wasn't there a successful Grand Designs when a Scottish supplier of potatoes to chip-shops built his house *over* a private lake? http://www.dailymail.co.uk/property/article-1218678/Were-cashing-chips-selling-Grand-Design.html GD Episode: http://www.channel4.com/programmes/grand-designs/on-demand/38275-008 Could you shunt it forward or to the right and cantilever or balcony over the lake? Would that be a different response to the site restrictions? Lesson to the wise. Build cost was about a million in 2005. That Mail article has it priced at £1.9m in 2009. Around 2012 Rghtmove had it under offer at £1.25m. (To be fair they haven't lost money and the adventure sounds well worth it). Depending on the specifics, perhaps a classic approach for a constrained plot - build nearly to the edge of the plot and use the most attractive area as something you *look* at. Wonder what @caliwag thinks?
What are the laws about recovering ground? Can you build a mini-polder into the lake if it is your lake? Even 5m on all round would be a huge difference. Flood protection, innit. Serious question.
Seems to be a quite good selection, @JSHarris. Big hollies are beautiful My comment would be to be sure that you have the correct mix of holly trees to get berrys, should you want them. I like the thing about Western Red Cedars that they can have boats made from them by carving planks out of the living tree, due to the self-preservative nature of the wood. Your future purchasers will be able to continue your boat-building tradition if they wait long enough and let the tree go. Ferdinand
- 103 replies
TBH I agree with you. In that model the new one looks very dominant. It would be a surprise to me if It helps in that form. However your Planning Consultant is the local expert and their opinion is far more weighty than mine. I think if presented with that as a Councillor on Planning Committee or as a potential local objector, I would be concerned enough to ask some awkward questions. I think you need to communicate that the house is in a far larger context than that shown on this model, so the extra space is really a very very minor overall change. One way to do that might be to have a small scale model of the landscape showing how small it is in the context of your 19 acres and umpteen lakes, then a model showing the detailed house and no landscape, demonstrating the high quality of the design - so the change is de-emphasised and the old size vs new size is not discussed in the same breath. I might be tempted to get the latter one 3D printed and dismantleable by layer. If you have to have one of house plus some landscape, then I would suggest putting enough landscape in to place it properly in context, and I would turn eg all that brown into green. If the lake moves then I would perhaps model it with the water lower eg in high summer. Never show the two side by side in the form imo. If you make sure to call it an "'illustrative" model In the definitive places even if you call it just a "model" elsewhere, then you cannot be formally bound by it. I would use it as a prop to your presentations rather than something you let people take away. Ferdinand
Intestng, I am doing my kitchen splashback and windowsill using sliced up 600x600 porcelain floor tiles in a contrast colour to a fairly monochrome kitchen.
I think you need to look at the two edges, white and brown, then use the colour that will mask the more uneven of them. So you get to create a new straight visual divide with the edge of your perfectly straight silicon bead if necessary using plasterer's tape or your preternaturally excellent silicone skills ! From the piccie, the brown looks less straight, so I would do it in brown to de-emphasise that wavy line and move the perceived colour join to the bottom of the skirting.
What is the windowsill treatment? In my bathroom for the LBB I am running Multipanel up to the pvcu frame using external corners round the opening.
I would probably use clear silicone as flush as possible or a quadrant, or silicone to stick the quadrant in place. Two considerations imo (?) ... airtight and aesthetic.
Or a slightly smaller one in the range, more used, for about £300. https://www.ebay.co.uk/itm/Rubi-DC-250-850-Electric-Tile-Cutter-Zero-Dust-110v/162727653896?hash=item25e352f208:g:JXQAAOSwZlZZ82Pa Might be worth it for someone.
Same model. EBay about £550-600 finishing tomorrow. https://www.ebay.co.uk/itm/Rubi-dc-250-tile-cuter-wet-saw-very-good-condition/263277528759?hash=item3d4c9046b7:g:MlYAAOSwBp1Z43sR One too far for me this time. I only have a splashback and a windowsill still to do.
Gravity Fed heating system drain-down
Ferdinand replied to ToughButterCup's topic in Central Heating (Radiators)
I may even have run it to outside, coming out under gravel.- 16 replies
- drain down
- drain-down
(and 5 more)
Has anyone done the heat loss math for one of these DMEVs vs a Lo Carbon Tempra, or taken thermal pics from outside? I guess the Centra is really a hitech, well-controlled trickle vent. I install the Tempras as a default in rentals, but not in bathrooms, and I would be interested. Yes, they do look quite phallic in thinner walls, particularly the extended length version the handyman installed in a normal wall the other day as the only one in stock. Ferdinand
Welcome. Are you buying coatings etc? Might it nit be a good idea to wait for at least Outline to be approved? Just in case... Or did you mean costings and got mugged by automisspell? Edit. Just like I did.
Good price ... who was the supplier?
Bookcase Systems (ideally Oak finish) - anyone with experience?
Ferdinand replied to Fallingditch's topic in General Joinery
OT. FOUR hinges on the door? Wow. I am just putting in some of those and have gone for 3 x 3" ball-bearing hinges. My doors are 30kg - how much do those Firedoors weigh? F -
Good condition Billy's are often available for a song on Ebay. As ever, the way will probably be to buy somebody else's entire study. -
Presumably for a Campavan you drive it on then declare SORN (?), to save a few hundred £££.
I think the negotiations and checks will take at least a year :-)
And ... are there bats.
