I have a couple of commercial dehumidifiers, potentially for drying out tenants' houses should a roof or pipe leak. Has never happened again after the first occurrence, perhaps as I educate and have SureStop fitted everywhere, with encouragement to use it. But i think DH's would not generate enough water. I also have a portable heat pump I am using for gas-bill-control during solar hours this winter, which generates a surprising amount of residue water, but nor enough for this. I think that will be the option (other than perhaps @PeterW's in line ion-exchange, as the plot is to have a IBC fed watering setup for container plants, which would be pump fed from the IBC. May be suitable for repurposing for windows / roof - and the pump feed in the tank would be wearing tights or similar. Various options to try. One thing I have not mentioned is that at some stage I plan to run CuSO4 solution (see previous threads about lichen and roofs) through the detergent feed once a year or so to keep the solar clear. It will need careful cleaning afterwards but the Nilfisk long lance has a feeding head with a mesh-filter that you just drop into the bucket of detergent. Will need thorough cleaning afterwards with clean water, which is not a problem. The solar hosting roof goes to a different gutter-downpipe than the rainwater collecting roof. F
- 19 replies
- clean windows
- hard water
(and 2 more)
Ok. First test done. Using hose water rather than rainwater, and no detergent. Very happy with the Nilfisk slightly expensive (£90) 4.2m extended lance and nozzle - clearly a bit of kit that will work well if not abused. Though even without the detergent feed being used (a separate tube) there is much rats' nest potential in the various feeds once the into and out of the pressure washer are in place. Careful tube managent required, and adequate space in front of the facade with the target windows helps considerably. However, washing of two bats and 3-4 upstairs windows took 5 minutes once the kit was assembled. I think I need a tighter set of hose-clock-joints though, as there was a bit of water leakage. So far so tolerable. Still waiting the Nilfisk roof-brush, and planning to have a go at the solar once that arrives.
- 19 replies
- clean windows
- hard water
(and 2 more)
Can we have a site and orientation plan, with indications of how your rear elevation and the area outside there is shaded? A Google Maps satellite photo would help, or perhaps Bing as they are usually clearer. My 'fat at the back' extension (there when I bought the house) faces North, and is therefore quite shaded. It is sometimes rather gloomy, but the extension I have is two storey (it's a bungalow extended up, back and sideways), so no roof windows. Instead I have a conservatory at the side. Peter is right about roof windows, but if you have shown us your full plot width interfaces with neighbours and access for roof etc maintenance become important. You may be better with a door at one side and a picture window from say knee height, perhaps with a window seat. As soon as you have a huge galumphing bifold wall you end up either keeping it clear and nowhere to put anything, or not keeping it clear and never using it. I'm wondering is where is that garage on your plot? If you have extra width more than the house width itself, then there may be something to be said for eg going a little sideways to get some sunlight into the kitchen diner where you spend your weekends. I think one big issue you have not addressed is storage and utilities - where are washing machine etc going? I'd suggest partitioning off your washer and dryer if needed, and also consider having a wall of storage somewhere. F
Thanks all. Most useful.
- 19 replies
- clean windows
- hard water
(and 2 more)
That's actually what my window cleaner has been doing since 2015 or os when they invested in a new van, pole and machinery, and it is fine if done regularly. The extending pole comes with a tube for adding detergent, which can be set to 5%, 10% or 16% with a filter on the input. That sounds like a sales tactic for Nilfisk to sell loadsa roof detergent, but I can put it into an already diluted bucket of washing up liquid - and plug the input hose into the pumped outlet from the 1000l gardening water butt (once it exists. I'm also thinking about Cleaning solar panels once a year, of which I have 35 at present. But it seems to all meet the need. F
- 19 replies
- clean windows
- hard water
(and 2 more)
Certainly happy to post a vid.
- 19 replies
- clean windows
- hard water
(and 2 more)
😉 The stuff on the shower is enough to worry me a little; I will *not* like working at height if I have to get it off afterwards. Unfortnately my house was not subject to Scottish "windows washable from inside" building regs.
- 19 replies
- clean windows
- hard water
(and 2 more)
Just after a bit of advice from people who do their own upstairs windows. I have just purchased a roof cleaning accessory for my Nilfisk pressure washer. The max length is 4.2m, and seems fine. It is also suitable for windows. My local tap water is moderately hard, to the extent that I need to pay attention to the shower screen regularly. I do not want that on my upstairs windows, and I do not have a water softening system in the house (can get one if needed, perhaps, when I extend my utility room). I will, however, have a rainwater storage setup for watering the container plants. Q: Is this rainwater suitable for window washing, without leaving any noticeable residue on the windows? Thanks for any thoughts. Ferdinand
- 19 replies
- clean windows
- hard water
(and 2 more)
Zinc always makes me think of Edward Lear - Z was once a piece of Zinc. Yes there alternatives, including Alu or Steel, and there are systems which I think have been used by one or two here, if you look. Apologies if you have already done all this. eg Some conversation in the comments on this post by @AliMcLeod: Ferdinand
Arched brick lintels: is builder being reasonable ?
Ferdinand replied to bmj1's topic in Brick & Block
Good comments. The link to various forms of arch is good. https://www.ibstockbrick.co.uk/arches/ I think the tapered bricks are specialised rather than custom. In Georgian arches are these called "rubbers"? There are other ways to do this - take a look around eg very modest 1870-1930-ish hosues when they were trying to reproduce Georgian/Victorian effects with mass-produced materials. See what is vernacular for your area. One is to have a triangular 'keystone' in the middle, which makes all the other mortar joints parallel using straight-sided bricks. Another is to use a triangular central element with cut bricks, which saves cutting all of them. They are everywhere in trad semis and terraces. The architect diagram is clearly tapered bricks. Have a chat with your brickie about how he can give you the sharp effect you want. Buying modules is perhaps an option. The Ibstock ones look interesting: https://www.ibstockbrick.co.uk/arches/ And there is an organisation called the Brick Development Association, best known for their magazine Brick Bulletin, who have all kinds of stuff on their website. Including a possibly useful information sheet: https://www.brick.org.uk/admin/resources/d-brick-arch.pdf I'd say they would advise you, though you will perhaps need to exhibit your innate enthusiastiasm about bricks and brickwork (which you seem to have). Personally, I love the stuff. https://www.brick.org.uk/about/contact-us I'd say this prominent element is a place to spend a reasonable amount of money, as if it is wrong you will be irritated every week. And that working with your brickie positively is important. Keep any blame perception on yourself, and take the small financial hit. Make it "I want it a bit different" not "this is crap". If it turns out great, remember that people like BDA issue prizes and commendations for good jobs, which beats "Kevin McCloud modelled my house in Garibaldi biscuits." F -
Late comment. If you are on Wordpress (or indeed Buildhub Blogs) you can set dates into the past, so rearrange everything. (You can also - and on BH - set dates into the future, as a kind of draft system for posts. Just don't forget.)
Late to this. I have just purchased a roof cleaning accessory for my Nilfisk pressure washer. The pole is 4.2m, and seems fine. I'll be starting a thread about type of water to use, as I know what my shower looks like after a period with routine cleaning, or steam clean of the glass. My area I moderately hard water. It can take detergent, but I will probably try using the detergent system for CuSO4 for the semi-under-tree solar panels once a year. My former window cleaner used deionised water from a tank in their van and no detergent. F
Experiment with pumping porridge round corners.
I can't see what gubbins you have to hide, but what about (say) offsetting the loo slightly to one side, and having say a 150mm deep by x by y enclosure on the other side which simply lifts off completely? F
I hate DIY plumbing, I'm afraid. 'Orrible, nasty, wet and cold. And it could turn into plumbing reverse-Jenga. I won't let the door hit my Rs on the way out ! ATB. 🙂
How much water do you use - Is my water usage high?
Ferdinand replied to Adsibob's topic in General Plumbing
I'd say your shower will not be using 15l a minute throughout, and that quite a bit comes from elsewhere rather than showers. I was thinking of a similar thread, so thanks for this. Average usage for Thames is I think around 145l per person per day, so on that metric you are not doing badly on crude arithmetic. For Jan-June this year, I used 160l per day. I currently live on my own in a 200 sqm house. But I did use some in the garden, and I divide general overheads by one not five. The best numbers in northern Europe are I think Denmark, which uses 104l per person per day. There's a target. You can probably save some water by using a dishwasher not washing up by hand. Someone will give you a flow reducer for your shower if you ask. Cups of tea lol - how many football pitches is it? Ferdinand -
Submitting Objections- templates / best practice
Ferdinand replied to Conor's topic in Planning Permission
You may find that objections are not considered until they are all in and after the closing date. That is how mine operate. I have found value in an early phone call to the Planning Officer, perhaps ostensibly to ask how to object so as to avoid wasting their time with fluff and outrage buses. But if you know of policy contraventions it is also an opportunity to help write the POs agenda before they have read objections, or perhaps even looked in detail at the plans and perhaps without breaking cover if you don't want to (you don't seem worried about that). If things come up after the closure date, you can submit further material and it has to be considered if it is before a decision is made. Get your LPA's list of "relevant planning matters", and get as familiar as you can with their polIcies. These are their boudnaries to define "not relevant". The point about habitable rooms is well observed - make sure the LPA know where your habitable rooms are if relevant. You may get things like obscured glass or a clerestory. Be short, focused, well-researched, and polite. Whose hedge is it? Can you trim it to 1.8m? Ferdinand -
Welcome. Have you tried old episodes of Grand Designs for suitable inspiration? There have been a number of practical (ie less upbutt than sometimes happens on GD) designs based around farms - I recall a couple who built one so they could move out and let their children have the main farmhouse with the farm. Farmers normally have their feet on the ground, especially when it comes to trebling the value of a small piece of land and getting a forever-house to boot. Rather like a several hundred £k detached Grannexe shaped like a farm building, and with practicalities such as a North Side pantry. May be worth a look. If i have time I'll do a peruse for a few episodes. Ferdinand
I think squirrels would look better, personally.
Building a Block Workshop - ADVICE NEEDED!
Ferdinand replied to stunotch's topic in General Self Build & DIY Discussion
What happens to a 4m shed with a 2 sided mansard roof, and a flat centre on top? (He asked helpfully) -
Neighbour selling without Planning Permission
Ferdinand replied to Becks1974's topic in Planning Permission
Yes - unauthorised work to an LB is criminal. Can get expensive. There are strange corners to the law, such as if an 'orrible 1970s conservatory was on the building when listed it is protected. And their tend to be fewer as you go N in England, aiui as Pevsner was more hurried up there and he was used as a bit of a guide. -
If he's the other side of the sale property and you do that, he'll still be your neighbour 😛. -
When did he last sell something? These days solicitors are far keener on checking paperwork. Part of this sound OK wrt Planning and Building Control, some not. One option is to let them sell it if you want rid of the project next door. Another one is to ring up the Conservation Officer, Planning Office or BCO with an innocent "is this OK" query. Probably useful to query something that can be seen from the road. You need to reflect very carefully on whether you want to do this. -
At the end of week one, these are the import and export numbers: An average export price of something like 25p per unit, and import prices rising from 27p to 33p suggests a approximate break even on electricity in real time at this point. It is still better to use than export, however the payment is around 4.5x the FIT export rate for me. Unit rate (per kWh) Sep 50.866p Oct 33.018p There's work to do on the panels, and hopefully on a questionable tree obscuring a large chunk of my panels. Should be able to do better than that number.
- 8 replies
- octopus
- outgoing tariff
(and 2 more)
Not urgent. I was just trying to make my next @Onoffcharacter assassination gentle wind-up was a stiletto not a bludgeon. Now I'll get off Zoot's thread.
