Ferdinand
    41
  1. I did a "layering up reno" on a 1970 bungalow in 2017 ("Little Brown Bungalow"), which has many similarities and a couple of differences (mainly suspended floor, and I did not use overlay ufh *this* time - I will do so next time as I have enough answers now to give me confidence), that we chatted about on here. But let me make like Eric Morecambe and answer all your questions, but not necessarily in the right order.. For ufh imo there are two things: the overall output is modest, and you lose a lot of heat downwards. For it to be effective and affordable, you need a house with decent quality fabric, and that must specifically include the floor. If you have not got those, then you either need to mitigate, not bother, or accept a potentially cold house and / or high bills. The target I adopted was current new building regs standard for the fabric, and accepting that I would need to compromise so would still hopefully be better than renovation regs standard. My compromise was that I accepted the existing walls with a poor u-value of 0.55 (=brick with cavity insulation), but did better on the roof, floor and windows.` 1 - You need to consider how far you can "profile up". I discovered that doors with trimming margins of more than 65mm are hard to find without going custom, and I still have a 1m high stack of 50mm celotex sheets to remind me. You need to work to 50-55mm in your spec, not 65mm, unless you have doors I did not find or have solid wood originals that can be cut back more. In addition to your extra floor, you need an opening / ventilation gap, and also a trimming contingency for eg if your carpet is fluffier then expected. If not you could be up a gum tree without a kangaroo, with your doors disintegrating because you had to cut off too much. My doors came from Todd Doors; other suppliers are mentioned on the forum. I had to trim an extra 5mm of 2 of mine, due to higher quality underlay and carpet than planned. There are ways to make floor surfaces thinner, but you may need eg something over your ufh system before you put a carpet on it. Will leave that for another post. 2 - Will you personally fit your lower ceilings etc? My doorways ended up as 1.92m, reduced from 1.98, but I am only 1.75m so it is OK. If you happen to be 1.93m, then you will be doing in a policeman's bob everytime you go through a door, which is not OK. Similarly ceilings - mine came down to 8ft exactly, but eg 7'6" would only work in a cottage. 3 - IMO 30mm of Celotex is not enough. You want something more like 75-100mm or equivalent. But there are alternatives. These are all dependant on having decent insulation everywhere else. a - Use a product like 25-30mm of aerogel, say Spacetherm or ThermaSlim. But that will cost at least £75 per sqm. How much do you like ufh? b - Raise the height of your door frames by one course of bricks if your ceiling heights can take it, and have enough insulation. c - Use "perimeter insulation" - installed as a 18" to 2ft deep ring outside your walls. That will cause the heat to stay under your house, and act like more insulation as the ground is warmer 2" down. d - Accept that the ufh is background and that you will lose 30-40% of your heat downwards, and fit eg a log burner for winter. e - Fit rads. (I would do these in order bacde or bcade depending on the project.) 4 - It sounds as though you should take a look at the other thermal elements - wall, floor, windows. 5 - Whatever you do, thorough attention to airtightness detail (and appropriate ventilation) is important. Also consider what will be done when you have to move on from Gas. 6 - Recommend that you thermally model it using the @JSHarris spreadsheet. In summary - yes you can make it work, but if your fabric is going to be largely unimproved then perhaps go for oversized rads. But it is worth doing the fabric properly if you plan to stay. My opinion is aim for an EPC of C (=75-80) or better. The two threads that might be useful, which include before and after photos on the LBB, and also my actual floor buildup, and the one I would use for ufh, are: Ferdinand
  2. So what is a roof with "gutter cutter" (aka Half Dormer) windows called ?? F
  3. Can somebody give me a quick definition of the difference there?
  4. Read this thread. I linked a couple of long lists on there. https://forum.buildhub.org.uk/topic/9921-self-build-mortgage/ At a Self Build event last month, Penrith BS told me that they allow you to borrow against land value ... will probably need PP in place ... and consider the whole country excl. Northern Ireland. The devil is, however, in the detail. So homework to be done. Ferdinand
  5. You need to be on Houzz or Pinterest for that one, I think. Or for the kitchen, this is OK - but she is a bit keen on brands. https://www.madaboutthehouse.com/how-to-plan-the-perfect-kitchen/
  6. It says: "The results displayed are based on the Homebuilding & Renovating Build Cost Calculator." https://www.jewson.co.uk/working-with-you/for-self-builders/preliminary-planning/calculators/build-cost-calculator/ Not sure of the significance of that. I tend to use the calculators at whatprice.co.uk. F
  7. You would use the GIA - gross internal floor area - of your house. That is the dimensions inside the external walls, but includes all habitable floors, Though the tolerances on this calculation will be so huge depending on circumstances that it is really a very wide ballpark figure.
  8. Welcome.
  9. @Anitha TBH I think this is now back to you. The project looks doable, but I actually question whether you need to extend at all - depending on what real size things are on an accurate plan. Certainly, if budget is that tight, I would do it without an extension initially as a risk-control measure, and probably leaving nearly all walls in place. The immediate thing you need is kids in separate bedrooms. I think you may find it beneficial to look at the BBC prog "Your Home Made Perfect", where they focused on gains from reconfiguring spaces as much as they did on extending, and on limited budgets. BBC site here (lots of clips): https://www.bbc.co.uk/programmes/m00048xh Copies of Ep 1 and 2 here on dailymotion. Good for giving you knowledge of possibilities. In accordance with the law of sod, the best one about bungalows is Ep 3, which is not online. They are also looking for participants, and make their series quickly. That might work for you, as they seem to be a more genuine programme than most of the others. But the way I would do this low risk version to get the bed and a better space at far less than your budget is 0 - You will need to consider Electrics, Underfloor insulation, wall fabric etc before you start. And be ready to have these things done as and when needed. Also get an informed opinion on whether there may be asbestos in the building before you get mentally committed to buying it; for me that would likely be a showstopper. If it is less than say 30 years old you are very likely not to have it. This low risk version would be OK, but the bigger version could be tricky and need expensive professionals. 1 - Move your existing kitchen into the dining. Make the new arrangement such that it will not prejudice anything you *might* want to do. 2 - Make old kitchen into suitable bedroom, but you will use it as your temp. lounge. Keep kids in current bedroom. 3 - Turn Loo and laundry into family bathroom. 4 - Do whatever you will do to lounge, if necessary sealing off archway whilst doing it. 5 - Unblock archway and reoccupy lounge. Move kids into separate bedrooms. 6 - Have a garden party. That gives you your basic requirements and then you can do all the rest over time. Could be 15-20k and only 2-3 months. As you add on bits eg extension or knocking lounge into hall or removing ceiling each will add more cost and time. Or you could do this and take a breather for a year and then have a new push. The other way to approach this would be to do the "building" work first in a similar order eg extend at front whilst you are in the temp. lounge, and do finishes and interiors later. Avoids another lot of major disruption later, but is higher risk. Do you feel lucky? Or the above could be modified to do bits now, depending on scope, vision and budget materialising etc. Project Management is critical for tight control. Execution needs to be quick whilst your house is a minor building site. Over to you. Ferdinand
  10. ? You can park that one until you start building it, unless your planners are control freaks. Ignore mischevious people stirring. (Unless you think that the door surround porch wall should really be a different colour too ?.) TBH I do not think you can judge this from the picture so there is IMO no point in trying.
  11. So I would view this as a solid first step that may lead to more later, and your kitchen extension will give you the opportunity to think some more. F
  12. WE WANT FLOOR PLANS. WE WANT FLOOR PLANS. ?
  13. But - colour can come later, if it is not going to be a material. It could be the door. Or you could treat the porch as basic plus cladding. So for now have a Fog Cutter cocktail to celebrate getting through the Design Fog, and relax for a couple of days. F
  14. I think it looks great. And in 5 months. I think that shows the value of taking *some* time, but not enough to go beyond the short term. On March 7th you nearly promised us a sight of the plans of the inside. Come'on - show and tell , F
  15. I would add in schemes to encourage renovation, though I am not clear how to avoid the problems associated with centralised schemes - which can double costs through overheads. Though the current third party insulation schemes seem efficient. The escalator came back in after a few years. IIRC it started at +3% over inflation, then +5%, then TB made it +6%, then they protested when it was maintained when oil prices started shooting up. I think that could be called cackhanded politics rather than a fundamental failure. However it worked. Also remember the CO2 banded road tax that had to be replaced with the current scheme because more than half of cars were in the <£30 bands within about 10 years? (https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/716075/vehicle-licensing-statistics-2017-revised.pdf) Give it enough time, and the impact will be significant. For energy I might suggest 1-2% per year, with strategic improvement schemes funded thereby. It would be critical that golden-goose-killing pillocks be kept in their matchboxes. And that it be done gradually over perhaps 15-25 years. Given that the LL schemes are now happening after 7-8 years warning, we have a way of judging. Ferdinand
  16. Not sure. For landlords renting out too poor properties in England you can get a Civil Penalty of up to 4k. Plus there may be routes through H&S regs, which apply to occupants as well as the fabric. They tend to be handled differently in different areas of the law and I am not reading the 110 page document to find out, but normally a Civil Penalty is the Council as Policeman, Lawyer, Judge, Jury and Executioner. And they get to keep the cash. Potentially this could be forced into Landlord Selective Licences in England, which are already full of God-knows-what (Nottingham tried to force LLs to supply an EPC for rooms in a HMO, which do not even exist in EPC definitions!), and Banning Orders etc. No idea if it would go that far - though it has already in the Tenant Fees Bill dog's breakfast, so who knows... I would do it like the Ecology, with the carrot/stick of higher SDLT, and perhaps a rebate on energy bills. F
  17. I think 1 is the wrong question. In this I would support a Pigouvian tax (designed to change behaviour - not my normal view), though I would argue for a single carbon tax applied to everything. The fuel duty escalator did not kill us. I think increases depend how it is done ... pushing prices over a generation would be doable. F
  18. That is good to see. The last I heard it was 2040 and they were still consulting. https://www.gov.scot/publications/energy-efficient-scotland-consultation/pages/4/ F
  19. My take on this would be to put the insulation in, even at the cost of a compromise somewhere else, because 1 - Even though the calcs may say 20-30 year payback, at some stage house values WILL reflect the insulating quality of the fabric. 2 - This may happen sooner than expected, because we are within about a year or two of owner occupied becoming quite obviously the slum sector for energy efficiency as shown in government data due to regulation of Landlords by EPC. 3 - Domestic energy prices are too low, and probably need to double or treble. That will have an impact on your calculations. 4 - It is the right thing to do. Obviously look for a cost effective way of doing it. Personally I would like to see the fuel duty escalator as applied to petrol and diesel put onto domestic fuel. The escalator is one reason why approx 40 million uk road vehicles in 2018 emitted fewer Greenhouse gases in total than did a little over 20 million in 1990. https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/790626/2018-provisional-emissions-statistics-report.pdf Transport is well on the way to fundamental and mass change; resi is not. With significant carbon reduction targets in place, someone will be coming knocking on all our owner occupied doors before long. That will transform your calculations. So I say put it in as far as you humanly can. F
  20. Bet you are glad you did the risk management. The first 5 minutes of the video are frightening. Him - "I have taken an all-in bet on Audrey". Ouch.
  21. Something I ran across today, relating to Grand Designs S 12 Ep 6 - the conversion of a Recording Studio in W11 (Holland Park). The full programme is embedded below. The project was done in around 2008/9-2011 (ie probably before the recession) by a couple who are a fairly senior City Trader, and an Interior Designer, Jeff and Audrey Lovelock. They bought a ground floor studio flat in Holland Park, which came with a 3000-4000 sqft ish basement, including an .. er .. squash court. They bought the place for under £2 million, and spent at least as much again on conversion. I estimate that it was actually rather more eg the kitchen worktops were made of something called Leathered Granite which was probably getting on for £400-500 per sq metre. Here is the 2015 photoset on Zoopla. This is what happened when they tried to sell it. May 2013 in the Sunday Times: Followed by: Fortunately, City Boys can afford it, if with some cost of pain and loss of reputation. As it was described in the press: There is a fuller account of the renovation here. I have some sympathy, though tinged with a little bemusement. I certainly think they were slightly ambitious (verging on reckless) in trying to develop a "superprime" quality flat in the cheapest-per-square-foot area of Central London, so it was marginal anyway, and did not have parking or security as would be required. But the unpredictable thing that really hurt it was that George Osborne whacked an extra 5% of Stamp Duty on it, plus +3% for anyone for whom it was a second property, plus an Annual "Enveloped Property" tax of £100k+ per annum on rpoperty in certain forms of ownership valued at over over £10m. The economics of that are that ... for a property with a rental yield of perhaps £15k per month (ie 1-2% yield on the perceived price), just the Stamp Duty on this thing would pay to rent it for 6-8 years, and the potential ATED Tax would double that length of time. And so much of the potential market evaporated. And it eventually sold for less than half of the initial asking price. Which brings us to the famous quote "Events, dear boy, events..", said by Sir Harold MacMillan when asked what would be most likely to blow a government off course. Someone should perhaps now be nicknamed "Icarus". Lots of lessons to be learnt for us relative minnows.
  22. No one on BH can give a clear answer to that, as the values are so close that it is hard to separate and the true deciding factors need to be what will make you all happy, rather than a few 10s of k in 10 years time, when external events could have changed it all anyway. If one of the houses is tired, then you may spend 40-50k in the first 5 years bringing it to be what you want. What value do you place on hubby and child getting an extra 15-20 minutes a day at home rather than walking to work / school? OTOH, what value do you place on avoiding the disruption of a project? And do you prefer houses or bungalows? Will you actually get 3 good doubles to fit a desk in too from your bungalow? Both houses compromise on bedroom size for bed 3 and bed 4. So - your decision, I am afraid ! Things you can do - Get Estate Agents in to value your current bungalow as if you were selling. Is it worth 400k? - Work out the costs to the LL of you leaving. Refresh + find new tenants will cost him 5-6k after a few years of a single tenant. Refresh + selling it will cost him the same. Plus hassle. Should be worth 10k off the price. Plus the "we have been good tenants for x years; give us some consideration" line. - Make up a big list of pros and cons for each option, and split them into "Showstoppers, major and minor" to help get a feel for your decision. But to my eye House 2 with added John Lewis is better than House 1, because 1 looks more basic. Could you work in that house 1 kitchen with that cheap tap, gas hob not induction, and that top built in oven at head height? Or would you need a new kitchen? But what way does house 2 garden face? In a good area good houses should always be in demand. Ferdinand
  23. Interesting - that does not chime with me personally, despite one of my favourite themes being simple modern styles with exposed materials. I think that for me it is neither one thing nor tother. That is too many materials all trying to be themselves such that none of them get the space to be their best, so it comes across to *me* as a bit too "smorgasboard", almost "tartan". If I was to live with the busy grain from the ply, I would want the rest to be very quiet. So I might have gone eg for simple black doors. Not a criticism; more a different perspective. I have perhaps been conditioned by medieval church interiors in England stripped to stone and plaster having visited so many; if you put me somewhere like the Pugin Gothic Revival Roman Catholic church in Cheadle I find it impossibly busy: Ferdinand
  24. I would try a different type of fixing. You could perhaps rout a "picture rail" groove into it, or attach something industrial-looking to do the same job? I posted a piccie recently of a scaffold plank feature wall being used by my Lettings Agent in a decor scheme from a professional HMO in Nottingham. I am still undecided, but it is an attractive option as the surface is not pure. Now seems to have vanished as presumably the room is rented, but like this: For hanging things or posters etc, I have never done better than the cork tiles I used for a whole wall once. They included partially black cork, so it was a texture. Ferdinand
