Everything posted by Marvin
Calculating for the use of sand for a thermal store.
Marvin replied to Marvin's topic in Boffin's Corner
I hope to find out. We require (but for us the figures may be different from others) about 500kWh for the winter -
Right, thanks @onoff. Specific heat recovery! sorry. Hi @SteamyTea I have looked at air and its a lot of bottles to produce 400kW and also the increase of pressure requires more energy to produce -
Yes, but not as a single property storage for heating over the winter being supplied by excess PV power. (as far as I can find). -
Yes, one of the things that confuses me is the rate of heat loss difference between a tubular shape and a square shape with the same volume and same thickness of thermally resistant material. 🙂 I'm looking at a tubular shape... -
I need to keep the heat for at least 2 months, which is possible, but is it practical. -
A luton vaN 18tons?? I think the tyres would burst -
store spare energy during the summer for use over the winter (for heating only). -
Yes if you need winter heat and you have summer power this is the challenge.... -
True, but this will lessen the cost effectiveness. -
Thanks for this. Yes this is fun but for me I need about a 4m3 storage that will last for months. -
Helium. I think any sealed tank causes massive expansion risks. increases the cost, now instead of an old steel bin I have to use a pressurised tank! no this has to be cheap low risk and make a saving. -
Yes but this ups the cost and complexity -
what is SHC? -
Hi @Iceverge Not as much space or where needed! However I calculate we have about 2000kWh available. This is at present a feasibility study. I have done studies for our home for energy from wind and rain and cannot make them sensibly work. Yes I need a pay back window and if I can't end up with a sensible one it's not going to be worth it. M -
Aerogel is good but expensive with a 650C melting point (being made from the same sort of thing as sand (silica)? What is it? about £10 a square foot 10mm thick? Comparative thickness of mineral wool 40mm? this might blow the budget... -
What temperature will VIPs withstand? -
Could add the warm air to the MVHR inlet. -
Hmm. What volume of air would you need to produce the potential of 1kWh of heat? -
Hi @SteamyTea It's good to have someone capable to review my workings. I double checked because I thought you might. Present theory: 1. From centre of store to outside: Sand, steel container, mineral wool, external weather protection. 2. Electric energy, to heat air, to heat sand. Heated sand to heated air to building. Storage capacity, thermal loss over time and building requirement are the next hurdles... -
Is this right? Dry sand density between 1520-1680 kg/m3 (say 1500 in the calculation below) Course sand, dry, specific heat capacity is about 800 Joules per kg per degree of temperature change. Course sand, dry, thermal conductivity 0.25 W/m K 1kWh equals 3,600,000 joules And therefore, ignoring all factoring of energy loss due to energy conversion etc(what I call "in theory"): Heating up 1kg of dry course sand would be: 450 degrees temperature change times 800 specific heat capacity times 1kg in weight, divided by the amount of joules in one kWh: 450 x 800 x 1000 / 3,600,000 = 1 kWh.
Ditto.
I @SteamyTea It obvious to me from the graph that you are running at bottom power whilst still living! Do you have a hand bell at the front door? The thermal efficiency of your property and or the inside temperature seem to be the only things where there is room for manoeuvre. Like the windows ideas! We lose about 30% of the heat out of our windows. Had thought of insulated secondary demountable covers, but would have to convince SWMBO! I would try and mould the panels to the profile of the window opening by fixing a coat of plastic to the window and reveals cutting a bit of insulation the the right hight and width and then foaming one side of it a squishing onto the plastic. God help me if I make a mess of the carpet....
Reading the original post first I would like to clarify: If the aim is a prediction for the next 3 hours I can't help. If your looking for general predictions of daily sunlight over a month I can do this. Predicting sunlight is easy on fully cloudy days and completely clear sky days otherwise good luck! The value of any information can only be decided when the purpose is confirmed. If I was anal about needing the house to respond to sunlight I would use sensors. If it was solar gain deflection I would use sensors. If it was to calculate solar gain or PV output this can be done. If you want to know exactly how long sunlight hits a particular spot on your building you can install a 12PV panel obscured to only produce enough power when lit by sunlight (or add a relay that need a minimum voltage to start the meter)and a ayron JR-HM001 Snap in Mechanical Hour Meter Rectangular Hour Meter for DC 6V to 80V and an appliance to use up the power produced. Hope this helps someone. We live on a windy island, where expected hit and miss weather days are frequently wrong. M
Hi @dnb Can I ask what the info is for. We live at the bottom of the island. If you require detailed info for calculation PV generation or solar gain I have no quick answers but have some suggestions. Marvin
Plus one for @SteamyTea's comment about stuff in the loft.
