Pride or shame. To encourage the others.
NMA rejected on basis it would breach condition x
saveasteading replied to flanagaj's topic in Planning Permission
I dont like green roofs. Had to do one once and that convinced me. I suggest you propose deleting the green roof but substituting an alternative. I've done that successfully.** Logic. A green roof is very heavy when wet, and requires much more structure...which has a carbon cost. It needs special membranes...lots of carbon issues. It needs maintenance. Safety issues. How are you going to access it, not fall off etc Preventable risks should be designed out. It prevents rain going elsewhere more useful, incl your water butts which overflow to Eg a pond or into the ground. So you must propose something better for nature. Pond, meadow, log piles etc. And no rain must reach the drains. * in recent drought, any rain would soak into the roofing cover and not reach your butts, garden , pond. So it's a bad thing. ** planner stated that this all surprised him but made sense. I've got the letters to say I'm an expert, which helps, but go for it. If you haven't enough land that might be more tricky. -
Oddly this is a building where these little screw piles might be appropriate. Ie as no regs. As wrongly assumed earlier. Screw in piles, then timbers spanning them, then joists. There would be a void underneath. For clarity i only mean these, not big time proper piling. At b&q for patios I expect. Prob best get longer stronger ones than these.
The sun room could be fairly cheap. Assuming all diy. Concrete 20m3 or a lot of mixing. Hardcore from demo company. mesh has to be bought Timber £1,000 or look for reclaimed. Windows second hand on Facebook or ask a window company ( they take old units out) . Felt, fixings etc Got a trailer or mate with truck? Buy used mixer, hire roller etc Anyway, with lots of time and bargains, £5k target but prob more.
Standing seam metal profile roof
saveasteading replied to Sam B's topic in Roofing, Tiling & Slating
Modern metal cladding needs a repaint at some stage, depending on spec and exposure. 30 years? It will last much longer but is best kept maintained, as any product. The main hindrance to longevity is bad workmanship. Misplaced screws or fillers. Scratches from tools or boots removing the surface. Older technologies were poorer. Paint would peel or erode (like a car) and plastisol had cut end peel. I've been on old roofs (60 years) that had life in them, and new ones that were failing through damage. Cross fingers but my projects total about 50,000m2 and I believe are all OK. I would worry about damage or bad detailing during solar panel installation. Detail is important too. Avoid ledges and upstands (eg velux) that can hold dirt and encourage nests. And NEVER have internal gutters.- 12 replies
- standing seam roof
- standing seam metal roof
- (and 2 more)
I think it's kingspan quadcore LSR1000, 140 thick, grey colour plastisol. That's a profiled panel, not flat. On the walls we're having flat panel 100 thick, black.- 12 replies
- (and 2 more)
Begging your pardon. I'd misunderstood your intro. I now see that the extension is for another time. This is a small building in the garden. SO: the tree will affect it. The ground will shrink in summer and expand in winter by 10mm or so. Does that matter? I'd say you live with that and any minor damage it might cause. So you can use 1m deep footings and not much damage should occur. I'd say that is OTT for this building. Or slab with 400mm downstands and accept a bit more risk. so go with your 600 depth, and 400 wide if you can fit in it. To minimise ground shrinkage make sure the rainwater off the roof is dispersed very adjacent so the tree gets it.
Yes as it is part of the house. Make it separate and it isn't. Says who? Or do you mean you haven't contacted them? Perhaps make it an outbuilding with a passageway link. I think I'd regard that as not affecting the house.
That was one of the questions I put. They knew nothing. Such screws are a possibility for a garden room, especially if you want it raised. Also for a temporary building eg a beachfront shack. For an extension it must perform the same way as the house. It needs building regulations, thus an SE. Tell us more. What type of tree and the distance? Is the ground clay or what? It would be interesting though to get more info from these screw suppliers.
@Jadhacha what Are they charging for these screws? I agree with @Nickfromwales unless these are £20 each. I've had a chat with a screw supplier at a construction show. . They didn't appear to know anything so I think were franchisees.
Can't connect the SWA cable. Practical help please.
saveasteading replied to saveasteading's topic in Power Circuits
That's so simple and now seems obvious. Ta. No brilliant idea on the hockey stick. It's all training for me I tell myself. -
so should i turn off that rcd, and/or the one in the consumer unit, before doing any more? I have stupidly forgotten to put the cable through the hockey stick. So not a lot achieved! If it was a straight pipe i might slice the length and insert the cable, but that wont work with the bend. -
Basics question. I turned off the circuit yesterday at the local switch in the house, and the relevant circuit at the consumer unit... I think it only supplies this one cable. I disconnected the box to change to a better one. That went well, and the metal gland is solid. No sparks or drama from the now exposed cable. Meanwhile, the primary rcd tripped in the house. How can that happen if the power is off? -
What to do with an old softwood floor?
saveasteading replied to Racheljane's topic in Wood & Laminate Flooring
Would it not be much less disruptive to either hire an insitu sander machine, or get it done? A big push-along one for £50/ day. Or a specialist would be quicker and better esp around the edges. -
For interest. I've found this connection box in my stores. It seems to be very classy with 3 screw-in sleeves with integral and tightening seals. The box back is completely in one piece of moulding, and the holes are made by tightening in the sleeves, whence the knockouts break off. Also a connector block. It is made by els Spelsberg, and also labelled Attema. New names to me but the build quality (and attention to detail) is astounding. There are also 2 sealing grommets stuck to the front plate, presumably to seal the screw holes. I cannot figure out what the rubber strip joining these grommets and extending to the rim seal is for? PS. Ive found it is available at SF for £8.99. But it is described as "unbranded". -
DIY MHVR as total newbie
saveasteading replied to Silly Man's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Would the cost be much? I haven't looked. The delay is an issue. But you've got the existing PP and could get started on preliminaries. If memory serves me though you don't start on claiming the vat benefit part way through. 20% can be a lot. -
Posi joist - This install feels rubbish, thoughts?
saveasteading replied to boxrick's topic in Roofing, Tiling & Slating
I'm pretty sure it is worse than that. It's knowing and understanding so little that they are unaware of their own ignorance or other people's skills. What other horrors lie in their previous jobs? -
You must not delay this. What if he starts to cover that work up? Or the worst scenario is he does a runner. It is probably all sortable but for a few£k. Removing and replacing much more than that. Ask him politely how he is going to sort it. And instruct him to adapt the scaffolding. -
Steel framed Portal building
saveasteading replied to Kevan Marshall's topic in Plastering & Rendering
They are not as flat or planar as might be assumed. I would still fit battens horizontally. Render isn't my preference for this structure really as it is likely to crack. A steel portal frame is designed to withstand the wind but permitted to move quite a lot. OR you tell the designer and they make it stiffer at your cost. Timber cladding would move with the building. Self supported or using the columns? if the latter they have to be designed for it now. -
In which case it is totally unacceptable. 1. The beam's web should not be load-bearing onto the support. 2..The beam is completely compromised and is now understrength. 3. It needs a padstone. @boxrick the works must stop immediately. Remedying this is likely to be complex and costly. Who is involved professionally other than the builder? do you have a contractual position with any of them? A formal complaint must be registered with your builder, in plain English with pictures attached, or with technicalities if you have an advisor. remember that the BCO is not a quality control manager, and will have constraints on what he can say. Who engaged the BCO anyway, You or the builder? If you, then I would still have a word with them. BTW That knot is massive and compromises this timber... I'm surprised this got sold. Web on block. -
The circuit/ fuseboard/ RCD etc were all replaced professionally when we moved in. However this cable is off an existing internal circuit. When the old cable that I am replacing used to cause cuts in wet weather, presumably a fault underground it could trip at any one of three trips. This tripped at the RCD which carries the whole house circuitry. I could take pics if that helps, and avoids me using the wrong terminology. That is not the plan. If I can get this to work as is, then I will proceed and change the old cable within 2 weeks. New cable in trunking , up into the dry and spacious attic and do a new box connection there. The existing cable I assume to be sound where it is indoors. I am now thinking that @ProDave 's point of the old cable shorting, and likely to be caused by the bend I've put on it (it was all working except in very wet weather). So for now perhaps to just replace a couple of feet with new bendy cable, and keep the old one straight. I should say that I did ask a couple of electricians to do this, but they have been 'too busy' for 6 months now. For obvious reasons they'd rather do new, clean work than this sort of thing. All decent small contractors are fully booked and turning work down in the SE. Any that are available will likely be as good as me but less interested. -
Its not completely clear on the photos. It looks as if the beam isn't a beam any more, reduced to a T, almost to a plate and all the load is sitting on the web. But perhaps back where the beam remains complete, that part is sitting on a wall or plate? In which case the remaining part has become an oversail and not structural. Even then, it should probably be on a pad or plate. Is there a side picture of that? -
Yes I've even got the conduit ready. The existing cable ran underground for 25m then up a pole to a 500W. That must have been pushing its capacity. floodlight. I changed that to 30W. It now supplies an electric gate which is quite low power. I'm thinking an outside socket would be a sensible addition for gardening but perhaps also car charging..... slow only. So I'm thinking the cable should be bigger than smaller. 2.5mm T&E ? -
I am. I thought I'd do it in stages. For my education, why is T & E wrong in principle? -
This is the old cable, coming from the attic, then was into the conduit bottom left. It did feel a bit stiff as I bent it around, but attributed that to many layers of gloss paint. BTW I am aware that the wall needs painting and the corner needs a new block. The sun is doing a good job in exposing an ancient layer that was painted over dirt, well over 30 years ago i think, so I'm letting it. The cladding was about 1930 and still has a resinous smell when cut. It's been overpainted thrice in my time here. The first by professionals who i think only prepped when being watched.. some failed in a few years. The second time by 3 steel cladders waiting for the next job... lasted well. Third by me in lockdown... and that has stayed put too. I'd like to make the corner with 2 splays out of one block of wood, rather than rectangular with 2 wedges added. But it would be a big lump of wood and I'm not sure I have the skill. Hence years of not getting round to it.
