the pipes will stretch and perhaps even slip a bit when pulled by the tiny movement. Using frequent joints, controlling the water content (low) and keeping the concrete wet while curing, the induced cracks will be small and insignificant. OR, if it is all going to be covered then you don't necessarily need the crack inducers and can let it do its own thing with millions of micro-cracks.
Welcome. Explain in what regard please? Are you sure? Id have thought for big plots then yes, bigger developers will have it. But on a small plot, the builder will only pay enough to retain profit after all costs including interest, selling and legal fees etc, and there is always risk. For self build you may be prepared to pay a bit more IFFFFFF the site is very much to your liking. You do not make money on a self build unless you are highly skilled yourself and do a lot of the work, whether design, management or physical...so maybe you have that.
Or undertighten. Actually I found that the clamping lug screws had to be surprisingly tight to ensure their seals.
That is what they look like. But I think it should be on the outside of the tightened screw for full contact with the pan. Let's see the pan and thr fixings that came off, for certainty. Btw I'm only expert in this through getting this wrong, then right... if any proper plumbers want to correct me that's fine.
Pretty well any cistern should do. It is a very primitive connection... just an open pipe below the cistern into the hole in the pan. That connection is likely the problem anyway so look at the rubber seal that came off with it as homework... does it look distorted or perished? The new cistern probably won't have this seal so you need a new one, and should change the screw fixings too. I messed up this connection the last time I changed one and had to start again, ( the seal ring wasn't neatly on the cistern outlet). so check it all fits neatly without clashes with fixings, threads etc on both parts.
It's all pricey. Block and beam is a good option and not esp costly. Where you say slab, it's probably a screed. Miles cheaper than a structural raft.
Only if you have real doubts about competence. Without full reading back, you are on virgin clay? No fill? So it's straight forward and my decision would be in comparing a structural raft to traditional build of footings and slab. Beware, that the term raft is often misused, being applied to normal groundbearing floor slabs ( to make it sound fancier?)
It's all free online by NHBC if you want to do your own assessment.
Fair enough. It is not clear in the regs so it is interpretation. Neither is there anything to stop a neighbour planting an oak close to your house (I think there should be) , so at least this is on the safe side. The thorns aren't an issue but maple is. It's an easy assessment off a graph. Sometimes a designer will work from the closest distance tree to house and specify that depth all round.but it could be shallower at the opposite faces.
No, I hadn't seen the skirt before and it does look useful. The first UFH I was involved with was 20 years ago and the PIR all floated up even with concrete , not screed. Poor taping I think. An exciting day. Hence I take this very seriously.
OK found it easily enough. £1/m for 100mm.They all seem to call it expansion strip but it isn't. It's for containing the edge and free contraction in curing and as a thermal break. If screeds expanded and shrank significantly in everyday use, there would be a lot of broken tile and rumpled vinyl flooring. Our project has about 200m of internal edging, so I think this product will be worthwhile. We have to use something and this will be easy and provide a little thermal benefit. So thanks for the exercise!
Against the internal stud walls you don't need much insulation. Heat is 'leaking' into the wall from both sides. But you are then losing heat from the wall down into the slab. Timber is low conduction but not ideal. But stuff the stud with insulation and I think it is sorted. But you do need an edging to contain the screed. You can use the foam board as suggested and it will insulate between screed and timber where there would be some heat loss. In summary for best insulation, use that edging board and also stuff the lower cavity. Caveat: I have somehow missed the edging board in years of being interested and doing 3 heated screeds. What is it called and is it expensive?
SIP experienced contractor
saveasteading replied to Sabine's topic in Structural Insulated Panels (SIPs)
I can see the logic of choosing it along with a contractor experienced in it. But otherwise I'd use whatever is normal locally The basement is not building but Civil Engineering so both SE and contractor need to be expert. By piling I assume you mean sheet piling to retain the earth while digging and building. What structure are you allowing for the basement?- 8 replies
- sip
- contractor
(and 6 more)
Being wider (deeper?) Using a board cut to size would make it easy to cut and fit to the finished level as your screeding line. OK so that stops the floating. So I'm guessing the product is supplied as a standard width, then you slice off any that's above the finished screed. Seems quite complex. Is it expensive?
It is an edge to the screed , otherwise it runs into your wall spaces. That could as easily be hardboard or osb or dpc. Screed shrinks so it isn't for expansion, but does provide a clean edge and some freedom to move and limit cracking. If it is against block then an insulating material is advisable. But in the pic above, heat moves into the wall void then through the timber so it would be prudent to stuff the space with fibreglass or similar. In that picture they have not (yet?) taped the pir to the perimeter so grout will get under and it may float. I don't know what the polythene is for, or why it is being taped down. Anybody?
I think you have a good point. If built as your first picture, then the heat is travelling from the screed horizontally through that thin isolation strip, and into a masonry wall. That block wall presumably sits directly on a footing in the ground. So increase the heat resistance of the strip by thickness and choice of material. Eg 25mm of PIR instead of the thin strip of something as shown. On the other hand, the surface area of screed to wall is minor as compared to the lower face of the screed. And heat loss through to earth is much less than with exposed surfaces.
And colour , inside and out. It can be a long process from enquiry to order and it's easy for errors to creep in. Also check for the correct VAT % according to the circumstances.
Rear extension into a garden with a swimming pool
saveasteading replied to Sidd's topic in House Extensions & Conservatories
In Engineering terms this isn't as worrying as you might think. Water in the pool weighs 1t/m3. The ground around it is heavier. I would expect the new foundations NOT to be deep so that the pool is unaffected. Are there technical drawings of the pool walls? But construction is the issue, and the need to not damage the pool. So standard or shallow foundations would be the aim.* Keep the extension design simple, such that it can all be carried or barrowed. Excavation may have to be manual. The very biggest concern would be that any future issue with the pool would be blamed on this work. But if the pool is your own, then that isn't a worry to you. An SE will handle this readily, and will also advise on how to build it so the pool is unaffected. Your builder has to be careful. @Gus Potter may agree or disagree. * loads do not disperse at 45° but it's a decent rule of thumb. If you know where the pool footing is, and draw 45° out from there, then do the same for your extension, if neither line cuts through the other structure then it's looking OK in Very, very approximate terms. -
A quality window contractor will minimise the gap, and the amount of filler/ foam needed to fill it. Even the best builder will have wobbles and variations in the opening, and that quality window contractor will insist on measuring. They will also use expanding tape to get a good closure that will move with the building , not squirt stuff in after.
That's why I would have ply on both faces, and it can't twist. Ahh. This is news to me... we had best look at the spec and any options. Even if the proposed timber assembly is strong enough, it might distort over time. Perhaps a thin steel plate within the assembly? For tiny issues over the long term, are these doors adjustable?
Your proposal for the equivalent term for England? The regs are much the same but the big difference is needing complete submission and sign-off before commencement. A very good thing in such cases, avoiding false starts What we are missing is any drawings; so it's impossible to advise on fire requirements.
That's my point though. Definitely? It is definitely very easy to use a steel without further thought. I'm looking at it as one of these but with ply screwed to both faces to avoid twisting. These will span up to 8m as house load joists, at 450 deep (I have done that on a commercial project where depth was not an obstacle) . I'm looking at at least that depth but double the flange timber so very strong. Plus the ply can continue past the supports for extra stiffness. AND a sliding or bifold door slides away from the centre where stress is most significant and towards the supports where it is much less. It might save me £500, and then the rest of the world can follow suit. Once upon a time I used to work these out from first principles but it would take me 3 days to get my head round the principles again. I'm not expecting one of the SEs on here to do this sum for nothing... I was seeking, and have received useful experience that nobody's has deflected and got stuck, and that everyone has a steel.. Overdesigned or just right, is another matter. Thanks for listening.
I dont know this product. But it looks to me as something that controls the spread of flame but doesn't render the timber non-flammable. ie flames licking over it won't spread fire along it, but severe heat could. so it depends on many issues and your situation. Are you not required to protect it from the inside as well? ie to stop your fire spreading to neighbours. Don't experiment with fire engineering. in principle though, timber would be good for you as you have the skill, and a little more timber depth increases strength but not labour. Plus it is very adaptable. Steel for anything bigger.
Thanks, I will look into this. So the tops are simply guides and taking wind load, not the weight? I've only seem them top hung, with the advantage of the bottom being less critical of grit etc. Thats where Im coming from . My career is largely based on removing overspec as a designer precaution at client expense. I'm all too well aware. Even an inaccurate level can be used for precision if you know how. Too many builders assume they are accurate and don't really understand. We subsequently realised there is an option 3 which is to use thin steel plate instead of ply. It isn't cheap to buy though and detailing might be messy. Also 4: we have some recovered and some new angle steels which could maybe be screwed to the timber.
