Recommendations for the silicone sealer I should have to hand by the dozen? And the current iteration of Snibbo ? Being more specific: I need to change the failed mastic to a shower tray. Something that stays white, doesn't get mouldy and stays sealed. If it can be easy to handle for this amateur then that's a big plus.
Long time reader(years of), first post!
saveasteading replied to Pete89's topic in Introduce Yourself
Agreed. But it does show up some 'never agains', and 'what I'd do different another time'. There is a lot to be said for first time self builders using a kit. It removes many interfaces,that are most likely to go wrong and reduces teams required. You reduce risk. BUT try to use proven models in shape and style or you lose some of the advantage. Also if really depends on what you want. eg some systems don't suit big open spaces. Few of these kit suppliers target the construction industry. Why not? Because the experts don't need the ease of the system and the cost attached. Eg look at new housing estates.. see any eps systems? So I'm not against but do look at options. Also, the people you meet at self build exhibitions are selling. Of course they don't tell you there are options. -
That's Scotland's entire population served.
saveasteading replied to saveasteading's topic in Wind Generation
They are not expensive to hire. We once put in about 150m of duct across a field and I think it only took a day. I wasn't there that day so haven't seen it done, but our op, who was used to driving a digger, said it was easy. -
Have you considered a plough type cable/ pipe laying machine? -
No. But don't reinvent the wheel. Fire rating requirements are published, as are material performances. Eg sometimes 2 layers of grey is enough. People often use the pink board unnecessarily. Means of escape and detectors too. The bco will want a proposal and it's in your interest to get it agreed ASAP.
road planings --experience of them over time AS
saveasteading replied to scottishjohn's topic in Driveways
Soaking would dissolve the bitumen content and lose the stickiness. I couldn't vouch for a coating of solvent between the old and the new but it might work.. it's your own surface so you can try. -
Properly laid Type1 is basically returned to nearly solid stone density, just not glued together. Good planings are the same but do stick together. Yes clean out the hole to see stone. It might be worth painting it with pitch or bitumen to get some bond. -
Berwick Bank wind farm in the outer Firth of Forth with up to 307 turbines generating enough electricity to power up to six million homes. So that supplies all Scotlands needs when the wind is blowing. Meters on the cables to England and Scandinavia and the Holyrood budget will benefit hugely.
Advice needed on Turnkey Project new build
saveasteading replied to CourierTheBold's topic in Introduce Yourself
It's normally better to buy a finished house where you miss out the years of problems and the risks. Value wise, turnkey will be expensive too, and seldom any saving compared to buying a finished property to move into and enjoy. Self build and diy may reduce the cost but increase the risk. -
Fire Stop Locations for Timber frame with external cladding
saveasteading replied to HanleeHouse's topic in Timber Frame
We had wasps somehow getting through a 2mm local gap between overlapping weatherboards. They then chewed the stud behind to make paper for a nest. So mesh needs to be very small. Someone will have studied this I hope. Overlapping messages. That mesh looks fine. -
150mm Composite deck screed alternative
saveasteading replied to bmj1's topic in General Structural Issues
Steel will be the answer. It covers big spaces economically. My rule of thumb is that adding an internal column under a portal frame will reduce that frame by 1/3 in tonnes and cost. What width of building do you intend? You don't want a column in the middle of your space I'm sure, so make this a fundamental requirement, and accept the cost. OK, so they should be able to look after you, and will be charging. So anything we say on here might concern them as distrust. Have you given them a budget? Would any of them know how to achieve it? -
It doesn't have to be fancy special stuff. It is stopping fire from spreading through a cavity so even wood will usually be suitable. -
I've done a few of these, design and construction, including a church, with the starting point being 'someone says you will be able to half the price we've had from tenders'.ie it's not a cathedral and so funds are tight. It is complex, based on the use, or variable uses, of the facility, and also the size. Ventilation can be a huge issue as is means of escape , if the numbers are large. Even which inclination of church and their procedures can make a difference to performance and choices. But to start with I don't know what you mean by a Composite deck screed. Does that mean your own steering group, or are there professionals advising? -
it would be consistent with what is there already, but not really proper. It would be quite easy to redirect the round pipe to the grille with use of a hacksaw and a new connecting piece.
Understood. The square shoe isn't quite long enough and the round pipe misses slightly. If you can rotate the round one at any of the joints to be over the grille, that should sort it. For the square you need the tiniest length of pipe. Temporarily cut a detergent bottle to make a channel and slide it under, but leave the bottom on to make it flow the right way onto the grille.
I have a similar but worse situation where the grille is set 100mm below concrete so fills with leaves. It is an unpleasant chore to remove them. So I have made a chicken wire cage to hold the leaves back a bit more. It's not pretty. But I have also bought a small, battery powered leaf blower and am pleased with it. It makes it quick, and not unpleasant, to shift these leaves and others nearby. It is very battery hungry but OK for a 10 minute job even with wet leaves.
What width is exposed?
Floor slab insulation. Test my logic please?
saveasteading replied to saveasteading's topic in Barn Conversions
Per board or m2? At present my best price for 100mm white eps is just over £15/ board of 2.4 x 1.2. -
Depends on the "STUFF". If it's a 1mm sheet of metal then water and air will get through so special screws have special washers that bind to the thread. A screw into timber might allow damp but not air through...so perhaps a smear of mastic is worthwhile. Yes through wood has been compressed so is tight, but could get damp. If you look at screws into cedar you can see that damp has got in.
It's BASF so not likely to be untrue. I've found a thing saying the eps nodules work identically, being bubbles of air, but the conduction route over the bubbles' convoluted path is less conductive because infra red gets mirrored back whence it came. Hmmm. Anyway its quoted insulation is 10 % better than white eps, but I think the publushed cost is double, and I wouldn't expect so much discount. -
I'd have to check the facts but I recall that there was more than one factor, one being that a fire test sample was 'adapted' to perform better. -
I wonder if it is hyped the same way as Multifoil, ie tested in a particular context then sold in another. A reflective surface only works if there is somewhere to reflect it to. "Graphite is a good electrical and thermal conductor". -
Internal Roof truss has split 😳
saveasteading replied to Andy62's topic in Roofing, Tiling & Slating
I had completely misread that photo. I've now got it on a big screen without reflections. Forget what I've said and I will start again The crack is slightly concerning and may need repairing. So I suggest you ask an SE to advise. I think an over-plate of ply will do the trick but it needs to be seen in context and up close. -
For other readers, it is indeed a real and a very bad possibility. I have been there when it happened. Our subcontractor didn't tape the joints properly. Our plumber had insisted on doing everything from insulation up. and it was the only time ever that we relinquished control of the slab concrete. It must have been 20 years ago and he insisted he was experienced and that it was fundamental that he had the package. I became wiser on that day, The pump-mix concrete got under the PIR which floated up to the surface. Suddenly I became the only person with a clue what to do, and I had them 1. stop pumping. 2. bring in concrete blocks, tread the pir down and lay the blocks on them. after about an hour the blocks came out and levelling continued. There will still be a skin of concrete under that pir, but it all turned out ok. In hindsight I think they taped the joints in the dpm but either not properly or the concrete was spouted at an overlap and forced it off. Plus there wasn't an edge detail (the edging under discussion here, did not then exist). it was potentially very horrible, and the need for sealed laps and careful pouring was demonstrated. Thus I will supervise and inspect. Maybe I will do the first room myself to test for any difficulties. Any recommendations for a good sticky tape?
