j_s
Everything posted by j_s
Vaillant Ecotec plus 630 system boiler efficiency on controller
j_s replied to j_s's topic in Boilers & Hot Water Tanks
@burgessl It's in the My Vaillant mobile app under energy info , you select it in the bottom right once the app is opened. Looking at it again I should have clicked on the big obvious info button on the energy efficiency box 🙄 -
I will try and get it done but no promises as need to get a load of diy stuff done, not so fun with these cold temps currently. I'm not sure how to change the settings or see the return temps, modulation, pump speed etc.
JohnMo, yes aware of condensing mode thanks. I had read that this is what makes boilers run in the 90 to 95% efficiency range and also why so many households are not getting the most out of their boilers as not setup correctly. I run mine between high 20s and high 30s flow temps using weather compensation but will take internal temperature into consideration and switch off. It is range rated but modulates down to minimum it will go most of the time anyway. John Carroll, yes it is the latest Vaillant Ecotec 630, not looked into the hydraulic modes but will see what I can find. So the efficiency is Vaillant's interpretation and a certain point of view rather than the true efficiency. -
Does anyone know why my Vaillant would be reporting the efficiency as 107% ? This is for central heating and perhaps less so for the Newark heatgeeks cylinder but hot water shows as around 103 or 104 most of the time. This is surely impossible as I'd be lucky hitting the max efficiency of above 90% although would like to think it's up there. Heat curve is 0.6. Ultimately it's not an issue just interested how it could come up with that. All controls are Vaillant and installed in late September with the latest wireless Sensocomfort that I believe is a very recent release. Thanks.
It'll come down to how much it annoys you. I had aluminium windows (I forget the actual frame manufacturer now but well known) fitted 12 years ago in my 2006 build. They looked nice but some were ice cold feeling inside. The glazing was as good as you can get for double glazing. We had awful condensation on the lower part of the frames on anything remotely approaching colder days and in November when it was humid and damp outside and the temperature also dropped a bit. I had an extension fitted in 2018 which was the catalyst to gutting nearly every room in the house back to block to reveal the usual bodges a sorry excuse for a construction company would make. I also decided to start again with most of the windows and put in triple glazing with Warmcore windows (uPVC inner with I think an insulated foam, with aluminium attached on outside and in but is still structural, definitely different to how they normally thermally break aluminium windows). I stupidly left in several of the old aluminium windows but changed more and more of them apart from 3 that would mean ripping out the redone reveals that had new cavity closers, windows were also airtight taped in as well as the bespoke coated ply window boards were fixed in with L shaped brackets behind the plasterboard further down the wall. I can't bring myself to rip the entire reveals out again to put the new windows in with the likelihood of cracking the celcon lightweight aerated block work. Guess which windows still get condensation on. This is with mvhr too. Luckily it's now only an issue when the temperature drops to -1 or below. The other thing to note is that all 3 of the windows that get condensation were closer to the outer brickwork and not properly sitting off the brickwork with packers. All my redone triple glazed units are on packers and sit in as far as I can at around 50mm to 60mm from the outside edge of the brickwork. Sorry for the long post, in a nutshell, you can either accept it and get some microfiber cloths and wipe it down daily or rip it out at a reasonable expense and get it fitted the right way. That's not to say you will eliminate the condensation as the aluminium door frame might still be an issue if it's not a great design.
- 18 replies
- condensation
- windows
(and 2 more)
Vaillant Ecotec plus 630 system boiler random heating coming on
j_s replied to j_s's topic in Central Heating (Radiators)
Hi Lofty. thanks for getting back to me. I've figured it out now thanks to a follow up call with Vaillant. Room temp mod was set to inactive. From what I understand this will ignore the scheduled desired temp completely when reached, this seems to be the case as per reading https://protonsforbreakfast.wordpress.com/2024/10/18/vaillant-heat-pump-controls-part-2-room-temperature-modulation/ I have radiators throughout in 1 zone only for whole house. Unvented Newark "Heatgeek" cylinder set to priority I believe, that is scheduled for 5pm daily to 48c with a legionella cycle every Friday at 5am. I have now set room temp mod to expanded and this has got the system running to how I want. I've notified the installer of this. I have the setback temp higher now at night and leave the daytime time set to what I want for the entire day. The house is never going to be super efficient unfortunately, but a lot of time and effort has been made by me to get it performing to the best it can, Triple glazing, mvhr, airtight in most places with 2 rooms remaining to be worked on but both have the window reveals properly sorted now so thermal bridging is much reduced. -
Current and very new setup is Vaillant EcoTEC Plus 630 System Boiler Controls Vaillant Senso Comfort RF Pack (10036826) Vaillant VR940F / MyVaillant Connect (10037346) Vaillant weather comp module Had some weird teething issues with it in that a while back when we had a cold day or 2 in September the heating came on when the wireless Sensocomfort control had heating set to off. It didn't do it after the outside temps went up again so I thought nothing of it, did mention it to installer but he has assured me it's all fitted as per instructions. Fast forward to the last couple of weeks and now it's more heating season, the heating is overshooting the set temperature by up to 4c and heating is still on and off after that. Heating goes off when it reaches the end of the schedule at night and appears to be off over night, rads are cold when I go to bed late anyway and I have randomly checked the boiler if it's on or not. I spoke to Vaillant today and they don't seem to know why apart from told me to get installer back but he is adamant it is set up correctly, Vaillant told me to change the external temperature switch off to 99c which makes no sense to me so doesn't fill me with confidence. It did seem to stop the heating within seconds of that but then came on a while later. I've then switched heating to off via the Sensocomfort which turned it off for the last 5 hours but it's come on again just now and internal temperature is still 3.5c above the desired set temperature. I've got a 0.7 heat curve on it and the flow temps are inline with the curve. There doesn't seem to be a way of seeing what triggers the boiler and it is in heating mode. All settings seem to be as they should be but something is triggering the heating and I'm at a loss as to working out what is. If I go in to the installation menu on the boiler itself there is nothing there in terms of settings without triggering a setup wizard which I'm staying away from. Don't get me wrong it's a nice very warm house but it's a complete waste of energy and money, I prefer it cooler then dial it up if needed. Thank you.
Gate intercom systems
j_s replied to Russell griffiths's topic in General Self Build & DIY Discussion
Mobile sim card so pick the mobile carrier you prefer and try and get the cheapest deal you can. -
I've just had my GSM intercom replaced with a Hikvision intercom which is poe (power over ethernet). It means it's both networked and powered via the cat5e or 6 ethernet cable when connected to a poe network switch. Mine has a camera, microphone, number pad and proximity tags we can give to family to get in. It also comes with a monitor you fit in the house where it's programed etc. I have an app on my phone as does my other half which allows us to answer and open the gate anywhere we have a data connection. The issue you may have is distance in terms of using ethernet as traditionally it is up to 100m before needing a repeater or switch. The GSM intercom might be an option but there are traditional intercoms I believe that are likely to have some sort of Internet addon. -
I'm planning on a 210l cylinder which matches up with the chart exactly, got 2 bathrooms and 4 bedrooms but 3 of us in the house. Thank you 🙂
Hi guys Might be a silly question, can I use a heat pump unvented cylinder with a gas boiler? Was thinking about being heat pump ready in the future. Was looking at Newark Cylinders. Thanks James
Had various trades in over the years for this house and the willful ignorance is off the scale with some of them. Ranging from a house needs to breath so draughts are fine etc to horrendous bodges that I have had to get remedied at huge expense. I'm just lucky that I have a builder who is amazing that has helped fix most of these things. Problem is, he is starting to get on a bit with a few health issues cropping up too and I really do worry who to go to in the future when he retires 🙁
Brilliant idea Mike. Is this why the likes of internorm etc glue the glazing ( I think) in the frames? As per internorm site: I-tec glazing ensures maximum security and safety for your home! The glass pane is fitted into the frame precisely. The remaining gap between glass and window frame is filled with adhesive and afterwards, the glue joint is concealed beneath the cover bead. This creates all around fixing without any gaps, this optimises the, thermally insulated and soundproofed window.
Ply box all round the reveal?
Update. Yes it's taken me this long to get round to it. Removed excess Dritherm insulation. Cut back plastic pipe very carefully with a dremel. Tescon airtight tape around all incoming pipes sealed to plastic protection pipe (stop copper from touching mortar), first used rubber amalgamating tape over cold water feed as the close proximity of me was causing it to get wet from condensation, not much, just enough to stop tape from adhering well. I cut 25mm pir board as best as I could around the pipes and cables. Cut it in 2 to make it easier to fit. Using loads of airtight foam to then fix them in place, including the boards to each other. Let it harden and then foam up all gaps. Trimmed excess foam. Tape pir board joins. Used sticks like **** to fill more likely hairline gaps. Finally, blowerproof airtight paint over everything. Result, draughts gone. I hesitate to say but I reckon it isn't far off airtight there now. Sitting on the dining room we always had a draught feeling as it's open to the hallway where this hole was before. Now, we don't even with the windy weather recently. True test will be when it gets colder of course.
Absolutely brilliant and makes so much sense in the wasted space of some doorways. I wonder if you could somehow make a fire door version. Storage in the utility room and then access to the garage.
Taping plasterboard for MVHR
j_s replied to Navron's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I would use an airtight paint on the block work before the plasterboard is attached. A full perimeter of board adhesive on each board as well as top to bottom and left to right in a plus shape on each board. This way the plasterboard and skim are cosmetic and a backup airtight layer. That is if your builder or plasterer plan to dot and dab. I would use an airtight expanding foam like illbruck fm330 or soudal sws airtight foam at the wall to floor junction. This is what I have done in my recent renovations. -
Adhesive for attaching stainless steel to concrete
j_s replied to j_s's topic in General Self Build & DIY Discussion
Can anyone suggest a good primer please? -
Cheers all. I will get a concrete primer too, would Tescon primer do it as I have a new can for other required internal work. Edit: It's the s primer spray that I have. If not, any recommendations please for a primer? -
Going to be finishing a garage concrete floor edge, it will be covering the external part of the concrete you see when the garage door shuts. It will also be screwed down too. Any advice on an adhesive to use please? Ct1 was a thought but someone on here might suggest something much better. We are keeping the screws to a minimum due to the possibility of stones in the concrete deflecting the drill bit and making the screw not sit nicely in the countersunk hole. This is a renovation, not a new build a d the concrete edge is not great hence being covered by the stainless trim. A car will drive over the trim eventually. No water will be sitting on it as it will drain to an aco hex drain currently being refitted. Cheers James
If youve got scaffolding up, can you remove/push up the first row of tiles and fix the entire perimeter of wallplate to ceiling junction and cavity to loft insulation join. I did this when we were replacing the soffits and facias. Hell of a job but worth it. I taped and used airtight expanding foam between wall plate and plasterboard. We then added Dritherm 32 cavity batts to the cavity where it was missing as well as enough to over lap the wall plate. We used wall ties to hold the insulation tight in those areas. In the hard to insulate areas where the hip sat on the wall plate I added pir board and foamed it in. We took all the plasterboard off the external walls and used airtight paint and foam from below and overboarded the ceiling. All made a massive difference.
Bought a reolink camera (battery and solar)
j_s replied to CalvinHobbes's topic in General Self Build & DIY Discussion
Was looking at reolink poe cameras for my place as now have a cat 5 feed to garage and a separate one on front fence. -
Here is, an example of our ply window boards. I cant remember the name of the white coating but its tough stuff.
Consider also adding insulated plasterboard after you have insulated between the timbers?
I also went for anthracite on all windows, in hindsight I should have gone white internal but oh well. Got a black front door though 😁 I've kept the grey colour scheme for soffits and facias so gone all in. If it's dated its dated but I liked it the first time I saw it years ago and still like it now.
