Tom
Everything posted by Tom
  1. I had a very similar issue recently (speed to desktop fine, television very slow or non-existent) which was solved with some help on here when I switched our router from IPv6 to IPv4. See if you can do the same. I'm afraid I can't give any more details than that, I have no idea what either IPv6 or IPv4 are, and probably only a light grasp of what a router is - but it worked for us!
  2. Well, it is the plant room...
  3. Thanks, John. I guess the loops in the corridor and plant room can always be switched off though - better to have the option, no? Harder to add the pipes later when the screed is down!
  4. Thanks all for your input. Attached are the revised plans from Wunda - I've kept the loop in the corridor as there is a chance if the bedrooms aren't occupied (when children fly the nest etc), there might not be much of a flow going through to those loops. Anywho, will go for the attached unless there is anything else we could change? Thanks all 05054 Tom PIPE LAYOUT - REV A - A1 .pdf
  5. We've just built with Nudura XR35 blocks which are thicker than the standard, same width of concrete core. Probably fell in to the U-value trap when deciding on these over the standard block, but they were certainly very solid to build with and we didn't get any blow-outs.
  6. Got a quote back to do the roof in SIPS (200mm deep): £72K + VAT ?
  7. That's what I'm looking at, but as seconds they don't come with all the certification. Exactly the same stuff though, just not certified.
  8. Has anyone experienced any isses with using reused/reclaimed building materials eg PIR? I'm just thinking it won't come with certification for fire safety etc. Any problems with sign-off/buildings insurance etc?
  9. Thanks for your input both. I guess the issue with the I beams is I don't really need a big span (max 5m) - and they're going to come in more expensive than normal timber. If I go for the composite panels on purlins at the moment that seems cheaper than I-beam/timber rafters - and I've immediately already got a U value of about 0.17 with the 120mm PIR in them. Then I would fill the void created by the Z-purlins with say 150mm-200mm mineral wool and the U-value would be down close to 0.10. Tell me if I'm talking absolute bollocks!
  10. Got some more info on the composite panels that I can ghet for £15/m: its Tata Trimapanel, which is a flat composite panel actually designed for walls it seems. As I'll be covering with another layer of wriggly tin I guess they would be usable on the roof. Anyway, SE looking at it now.
  11. Thanks Russel. The roofs have a maximum span from wall to ridge of 5m, with angles of 14, 22 and 23 degrees for the three different roofs. Floor plans attached to show how they are arranged, the largest and smallest "barns" on the right and left respectively have their ridges running vertically up the page, the middle barn has it running horizontally - hipped where it meets the larger barn, and gable end and valley gutter where it meets the smaller barn. It's all single storey with vaulted ceilings.
  12. Thanks all. Trussed roof not an option unfortunately. Hadn't thought of the I-joist/posi rafters. Essentially the costs would be similar to the standard cut roof as a whole I guess, except more for the joists themselves - online it seems like they are approx £10/m? Are they worth the extra? What makes them outperform traditional timber? We're not so bothered about routing cables etc as ductwork will be external.
  13. Hi all. So, finally, the jokers who put our Nudura walls up have finished and I have a really good builder lined up to start the roof in about 4 weeks. The problem is I need to finalise exactly what structure the roof will be. The building has 3 large elements to it, all single storey with a total of approx 360sqm of roof. It has been designed as a cut roof with insulation of mineral wool, the final covering will be corrugated metal. It is designed with steel ridge beams ( two steel rafters to split the longest of the 3 roofs) and lots of rafters in 8"x2" timber. The reason I'm waivering is over the cost in materials and man hours to do this and of course factor this against achievable U-value, and the builder we have lined up has lots of experience with industrial builds and is recommending going down the composite panel route. The options I can see we have so far are as follows: 1. Cut roof. Costs: approx 900 linear metres of 8x2" at approx £4.50/m (from TP) = £4000 mineral wool - 200mm thick approx £5400 for 360sqm 18mm ply sarking - £30/sheet would be £3,750 battens and counter battens membrane corrugated steel at approx £20/m = £7,200 a lot of man hours to cut and fit joists (total approx 190 timber joists) probably a lot of scaffolding U value? 200mm woool probably not enough 2. Composite panels. Costs: redesign of roofing steels to incorporate a few extra steel rafters and Z purlins composite panel seconds that my builder can get at £15/sqm (120mm thick PIR)-= £5,400 approx, these are in box section, so would need to cover roof with ... battens corrugated steel at approx £20/m = £7,200 fewer man hours, could potentially be done in the building with a scissor lift rather than scaffolding U value: 120mm PIR plus 175mm wool 3. SIPS Same costs for the steels, purlins etc as composite panels, still awaiting a quote for the panels again, much fewer man hours, less scaffolding etc 4. Thermoroof self-supporting EPS panels Same cost for the steels and purlins as the above two options quote received of approx £25k for supply of 360sqm - which makes it about £70/sqm, quite a bit more expensive than the composite panels at £15/sqm! Another cost to factor in would be how the internal finish would be done. Cut roof can have vapour barrier then just PB or even a thin layer of PIR taped to add more insulation and act as a barrier. The composite panels would need some internal timbers fixed to the purlins to board on to I guess. I know there will be lots of other costs I must be missing, but I just wanted to get something down in writing and out of my head. Hopefully then I'll be able to sleep tonight - and hopefully I can invite some comments/voices of reason to help me see a way through this. Can anyone give any advice re the above?
  14. Long shot I know, but does anyone have an off-cut of this going spare? I need a 250mmx250mmx20mm piece to go under a steel column, but there is a £100 minimum order from them! Thanks all...
  15. Paid by BACS a short while ago, then just now got a text from HSBC saying that if I don't verify the transfer they will assume it's fraudulent and recover my money! Wish they would do that with my council tax...
  16. Can't pay anything by credit card unless they take credit card payments Long way to go until I get in to my overdraught...? lol
  17. OK, thanks all for the above. Will stump up the dough. As an aside, I'm about to pay the deposit for our sliders and I want to pay part of this by credit card so that I am covered under section 75 - but they will only accept payment by BACS or cheque annoyingly. Am trying to confirm with HSBC whether I can send a BACS payment from my online credit card account...
  18. Hi all, our front door supplier (supply only) is insisting on charging VAT, saying I can just reclaim at the end. It was my understanding that they are legally obliged to zero rate if this is a new build though. Fine, I guess, if we can reclaim at the end - but could there be a problem if we try to do this?
  19. ...and the manufacturer adds a nice mark-up. Firm handshakes all round and guess who pays...
  20. That's useful to hear your experiences, thanks Ian. It does sound like it could be an issue, but I suppose I'm erring on the side of without, as I'd prefer not to look through tinted glass and rely on removable things eg shutters or the venetians you suggest, to use as and when needed. I guess the external film is removable? So could put this on for a few months then remove for the rest of the year?
  21. Aha, good point ?
  22. We will be putting in a long run of sliding doors in a south/south-east elevation - total length 10m x 2.4m high. How important is solar control glass? I was about to pull the trigger on a quote and noticed this wasn't included and am now in two minds whether to pay for the extra. The room where these are is quite large - 18mx9m with a vaulted ceiling up to approx 5m. What factors are important here? We plan to have sliding shutters on the outside of these doors (like timber-clad barn doors) to help with the solar gain. Looks like visible light is reduced by 30% too which isn't great. If the consensus is equivocal I'd probably go without, but given the amount of glazing I'm having second thoughts. Any views? Thanks all
  23. I've always blunted nails with a tap from the hammer before using tbh, can't remember where I picked up the habit but good to hear I'm not the only one!
