Tom
Everything posted by Tom
  1. Hmmm, yeah, I feel I need to check everything though. Especially since they built a wall in the wrong place.... We have no other options unfortunately, we're building in Nudura and there are no other builders free with any experience with this. We're at the stage of the walls going up now, so hopefully we can see things through to a watertight shell then part company.
  2. ...and applying retrospectively, contrary to the prior agreement? Hmmm, no.... ?. More of a "my word's my bond, mate".
  3. Evening Ladies and Gents So, my builder pulled me to one side today and said that they are thinking of quitting the build - either that or they want more money. The current deal is I am paying them an hourly rate (I know, I know, this was the only way...) and then 10% on any materials that go through their trade account. This was with the caveat that I could source my own materials and buy them myself if cheaper. This I have done on a couple of big items (eg floor insulation 5k, rebar mesh 10k). Now they are saying they want to take 10% on all materials, whether through their account or bought by myself AND apply this retrospectively to the insulation and mesh. I was willing to renegotiate, and said so - but TBH it sticks in the throat a bit that they are now wanting to apply new terms retrospectively. I'm of the view that if the terms they agreed at the start have not worked out, then that's on their head, and they'll know for next time. A renoegotiatin of our agreement going forward is OK with me. What's your view?
  4. We're using mars bars for our pour on to EPS: https://tzursteel.co.uk/products/concrete-square-bar?variant=31227315028026 Then these deck chairs between the two layers of mesh: https://tzursteel.co.uk/products/continuous-wire-chair-2m-lengths-each-spacer-from-50mm-to?variant=27962143571991
  5. Thanks mate, it's all been passed by our LABC. The ground has been compacted well. A few mm drop would not be enough for convection currents, esp as it's all sealed, and the air gap might even improve U values!
  6. The ground isn't going to settle now, we've built back up and compacted well, there will be no possibility of ventilation under the slab either, so I'm sure it'll be fine. I think that's a good idea re keeping boxouts around the pipes. I think we'll do that when we pour the lab so we have greater scope for adjustment later on.
  7. Ha, yes it was top of the design brief... No, the floor was designed like that due to the nature of the ground. I's an agricultural site, made ground etc. As it was, we ended up digging out most of the made ground down to original ground level so could have made everything back up to spec and had a ground bearing slab. Hey ho, you live and learn I guess. Anyway, we are where we are so will be having this mental floor make up. Not yet. How critical is positioning of the shower waste pipe at this stage though? How much bodging-room do you have to play with if you have a 75mm screed to alter/shutter/hack out? If I'm T-ing in to the 110mm stack with the shower waste as indicated in my diagram above, how can I be certain it won't empty the shower trap/gurgle etc? Are there rules of thumb with regards the design of this? Found this: https://www.marleyplumbinganddrainage.com/support/installation-advice-and-help/design-advice/soil-and-waste-design-advice/ which seems to indicate my proposed design should be OK.
  8. Thanks mate. I was initially confused a bit by the proposed floor make up but it is a suspended floor as you describe above, in that it is supported on the perimeter by blockwork. The slab itself is spec'd to have two layers of A393 rebar mesh in it. It is designed to take internal blockwork walls laid directly on it with no need for extra footings etc underneath. The EPS is the lowest compressive strength available (EPS70) as it will not be taking any of the load from the slab. We went down this route as the ground we are building on is pretty much all made ground and this way we take all of that uncertainty over what is underneath out of the equation. It also means we can add/move blockwork walls with carefree abandon in the future if we were so inclined. We're just coming up to floor level now and doing the last bit of oversite preparation before putting the blinding and DPM down. One more question, where should I be aiming to bring the shower waste up - how close to our proposed shower location? I'm guessing we will run a shallow fall of pipework from this to the shower trap itself within the screed?
  9. All plans have been passed by BC, but TBH they are light on detail with regards the drainage. I spoke to BC two days ago and they were, typically, fairly non-commital.
  10. Massive thanks for the replies, all is very much appreciated. Sorry for the delay in getting back, bit of a crazy day yesterday. Haven't finalised other floor finishes but some rooms will be tiled, others wood and bedrooms carpets - so 20-30mm I guess. I just figured pouring the slab in these areas to take in to account these differences would be too big an ask - easier to do it with a screed at the end. We're not pwerfloating the screed Peter, we'll be doing this to the slab in the other half of the build. OK, have done the best I can with the children's felt tip pens! And also a diagram of what I think would be better than everything in the insulation: the 110mm passing through the DPM into the ground. The wastes from showers can T in to the vertical 110mm and travel through the insulation. The toilets can T in above floor level and be boxed in. Does this look reasonable?
  11. It's' a long story.... well not that long actually. We have a suspended slab over the whole build and in the main living area are having this powerfloated and polished as the finished floor surface. In the rest of the build we have the slab but will be having other floor coverings but it was too much of as ask to get the builders to sort the levels out for different floor finishes, shower tray formers etc, figured it would be just simpler to add a screed. I don't have a section drawing unfortunately!
  12. Thanks mate. Is it an experiment? I got the impression from the builder that it would be normal to do. The pipes would be in the insulation, at worst resting on the DPM/oversite and the concrete slab above is suspended rather than ground bearing, so the weight would not be taken by the insulation/pipes.
  13. Bueller?
  14. My (proposed) floor make up is: ground - blinding-DPM/radon-300mm EPS70-200mm concrete- 75mm screed and my builder wants to run the 110mm drainage runs through the EPS layer rather punching through the DPM and running through the ground. Is this acceptable? I guess I'm worried about the loss of insulation in these areas (albeit less than half of the 300mm thickness). He is also saying we need to do the same for the narrower drainage pipes from showers and basins and T in to the 110mm in the insulation layer. Again, is this what's done? Seems to me too many joins with potential leaks somewhere I will be able to do naff all about once the slab in poured. I'm rapidly losing faith in my builder - not least as we have yet to get above floor level and he has already managed to pour one ICF wall in the wrong place. Not a good week this week ?
  15. ?thanks Moonshine
  16. Tom
    AONB Barn
    If it's in an AONB then Class Q PD rights don't exist - any application will fail. It'll be one of the first things the planning officer will look at!
  17. ?thanks. Ours is coming direct from the factory I believe, so guess no stock issues. Reassuring to hear you got your money back.
  18. Hmmm, kinda. Tried to call just now but apparently it's a religious holiday today and tomorrow - was hoping for delivery end of this week. Seems legit website, trustpilot, checked companies house etc.
  19. Has anyone got any experience of Tzur steel? Paid them a lot of money for mesh rebar last week...
  20. I was just thinking that if tied to the bottom mesh we can bolt braces down anywhere without worrying. I can see this would affect responsiveness, but is that too much of a concern? For the main living area we are having the powerfloat as the final finish (albeit polished a bit and sealed etc), and one of the contractors said having the UFH pipes attached to the upper mesh would be a nightmare with moving the hose around, damage from boots etc etc. He recommended having it on the lower mesh. This slab would be going in after the ICF walls so no issues with bracing or anything though.
  21. Thanks Russell, will send him a PM. So, hypothetically speaking, if you were given a choice between: 200mm slab with two layers of mesh with UFH tied to LOWER mesh (i.e 150mm from surface) + 20mm for tiles or carpet etc OR 200mm slab, UFH on the top covered with 75mm screed + 20mm for tiles or carpet etc which would you go for? Both would have 300mm EPS below the slab. I'm thinking relative cost, floor heating responsiveness (big deal in a near passive house?), ability to "store" heat etc
  22. ...though would we still need a screed for a final/level finish, even if we plan tiles/carpet/wood flooring in various areas?
  23. Thanks Nick. The issue is we need something to brace our ICF walls off while they're poured, and would need to bolt in to the slab for these, so having the UFH pipes in there would cause problems. Our slab is 200mm thick with two layers of mesh. It was initially spec'd as having the UFH pipes attached to the top layer of mesh, hence the issues with the ICF braces and thinking we could just take the pipes out and put in a screed over the top bwhen the walls are done. Tbh can see no reason why they can't be tied to the lower layer of mesh in the first place which would keep them out of the way of any bolts/screws.
  24. Yep, clip rails or the castellated panels, either way UFH pipes on the slab then screed over the top.
  25. I'm not bothered about response times tbh, I quite like the idea of having essentially a big storage heater! I'm sure I can't be the only one looking to put pipes directly on to a slab and screed over the top? Would the pipes fail due to differential movement or something?
