Jml
Everything posted by Jml
KIt’s been a number of years since I have been on site, apart from a few days ago when I eventually remembered my password. When I was on before we were in the process of doing a bungalow extension. Well the extension still isn’t done, but we hope to change that shortly. In the meantime since we lost our two dogs, we have been doing some travelling, finding ourselves in Australia when Covid became an issue and making it back from there 2 days before Qantas temporarily stopped flying overseas, and 2 days after lockdown started here, after a number of flight cancellation and changes. A stressful time. Planning permission for the bungalow, lapses in about 3 months, so I need to get a build over agreement to Thames water ASAP. Below is the existing and proposed drainage designs. Finances are tight so the aim is to do it as economical as possible. The now internal manhole will be removed. I have moved the connection to the sewer forward as this seems easier given the island sink. Is this necessary or can it curl around backwards, with the rodding eye to the left of the building? The new store room, previously the bathroom has holes through the wall for the sink and bath outlets and through the floor for the toilet. Can these be reused? The door to the store room can be changed. I show the utility room will need multiple waste water outlets (I have shown 2 only ) joining to a stack, the same stack for all the new bathroom outlets . Is this possible? I did come across a fitting which allowed 5 inputs at the same level for a stack ( sorry can’t find it again, so don’t know it’s name). The rodding for this stack would have to be from an opening in the stack. Is this wise and is there an alternative.? I am very concerned about this as in a previous house we had an outside stack totally blocked at first floor level. Rodding from the loo and from the drain did nothing, so the plumber had to loosen off the mid joint of the stack, to remove the contents, it was not pleasant to say the least! The other manhole to the rhs, will need to have one of inputs removed, unless we use it for a new upstairs bathroom. All the pipes are 4”, new stacks as far as I understand are 110mm, will this be a problem? Can we easily block off this input if not reused? Sorry a bit long winded. Any help very gratefully received as I find understanding what is good and permitted very confusing, Jenny. existing drainage.PDF proposed drainage.PDF
Cutting down a TPO tree by mistake - Enzo's homes
Jml replied to Moonshine's topic in Planning Permission
If close to electic cables may be worth contacting electric company. A number if years ago we managed to get electric company to cut down group of overgrown fir trees, which were impinging on the cables, from our front garden at no cost to ourselves. -
Our council planners don’t like talking to mere householders, but may certainly be worth a try. Its an idea re: a minor change, which as you say can be done under a building notice. My concern is that these would be allowable under permitted development and therefore would they actually lock in the planning permission?
The only demoltion, other than knocking through when the extension is built, is of the so called summer house, which did appear on the planning permission plans. This is mearly an old large shed with windows and double doors to the front. I would have thought it unlikely that we would need a demolition order to remove it, therfore would that count as demolition for the start of plans?
We have planning permission which will run out in a couple of years, to modify our bungalow, adding an extension, removing a summer house (posh name for ugly shed) changing roof from flat to pitched, changing location of front door, moving stairs, adding skylights and new rooms within existing roof space. Due to personal circumstances we are unlikely to be able to start the works in any meaningful way before the planning permission expires. We wish to lock in the planning permission so that we can do it at a later date. The permission is exempt from CIL as under 100 m2. We could of course just reapply later, but if CIL changes or the councils allowable works change, that may not be possible. The extension is to be built over a mains sewer, hence digging foundations to lock in the planning is problematic as a build over agreement would be required and a full building regulations application would need to be submitted, with all the work that entails. Any easy ideas as to how to lock in planning would be much appreciated.
If manhole is part of a public sewer (i.e. sewage from a neighbouring property enters there) then you will not be able to build over it and it will have to be moved.
Avaliable a lot cheaper here https://www.planningportal.co.uk/homepage/4/buy_a_planning_map
Confused (again), in @JGB example at the beginning of this thread how would that work?
Many thanks, to all on this thread, think have actually understood how to do my drains at last! One last question (sorry about hijacked thread), can you rod an s shape i.e. 45 deg out of IC, then 45 deg into mains sewer?
I think i nearly understand, so in @JGB example that plastic chamber could be used but sealing off unwanted inlets?
So the main channel you describe, will be a short pipe (i.e less than 450) within the chamber which runs parallel to the mains sewer, to which the inlets enter and outlet leaves?
We will be having a similar layout. Will sewage be able to flow from new IC to mains sewage pipe, given the angle betwen entry and exit is at most 90 degrees?
When I did ours, a while ago now, need specify that structural beams needed fire protection i.e. 2 layers plasterboard or similar
We approached our neighbours re: an extension, but would not do so again. They were not happy with the roof pitch so we modified our design and showed them the revised design, to which the response was anything but friendly. Our planning was approved, but feel that it probably would have been even if we had not changed it. In the end we gained no benefit, had a worse design and probably annoyed the neighbours, not the outcome we had hoped for!
This may be of use https://www.moneysavingexpert.com/deals/grand-designs-live/
Still, lovely,. Very similar looking apart from size.
Hi. Is picture a Gordon? Fellow owner if so.
The tale of the sale of our old house
Jml replied to Jeremy Harris's topic in General Self Build & DIY Discussion
Have you discussed with your solicitor? Very surprised if this would stop things, usually only needed to ensure account is changed over on completion. -
Neighbour proposing Building over Lateral Sewer?
Jml replied to Ferdinand's topic in Waste & Sewerage
Certainly with Thames Water you are not allowed to build a new house over an existing sewer, so it has to be moved or the plans changed. Worthwhile checking in ST build over agreement application wether it has the same. Building over a sewer will also have to be agreed by Building Control. -
Foul sewer, Anglian water shrugs its shoulders
Jml replied to Dreadnaught's topic in Waste & Sewerage
Unless you will be at the far end of the sewer, it will be a public sewer as all sewers were adopted by the local water companies in 2011, whether or not they were mapped or are aware of them. -
We have bought and sold many houses over the years. Would recommend that you have 4 weeks to exchange and further 4 to complete, which tends to be standard if cash buyer, if not quicker. For those who are in a chain, who have a house under offer, this may not be posssible, as you may be held up by slowest in chain. Make sure you get a good solicitor working for you, one that specialises in conveyencing is best as they are not distracted by other things. We have an excellent one who has done many transactions for us, who knows that we chase continually, so we are always waiting on the other side. -
Advice needed for new build plans
Jml replied to AugieMarch's topic in New House & Self Build Design
Why not do (b) but where hot press and lower half of pantry is put wc, then square off study, with door half way up stair length to make lovely big room.
