Oz07
Everything posted by Oz07
Yes it was always planned to change. I replied to the consultation and commented on here previously. However now they have actually given us a likely date it will commence. Think it requires some new legislation so hopefully this comes in time.
🤣 Magic soil theory incoming 🤣 sorry I couldn't help myself
Biodiversity Net Gain. Another one of these eco loon schemes. Completely shafted the SME and self builders submitting planning for small schemes getting whacked with 14k off site contributions plus the cost of a BNG metric report. Luckily for us it was the vendor who went through all that aggro and the purchase price reflected the 14k
Unsure if this has been discussed here or not? I've not logged on for a while due to the off topic discussions taking over! Anyway there is a proposed date of 31 of July to exempt all sites under .2 hectares! I think it's not set in stone yet but looking pretty good. We have bought a site with a near on 14k off site bng contribution conditioned as part of the permission. I always intended to change the planning and tick the self build box to gain the exemption. This would still have required me to sign a unilateral undertaking with the LA with can cost a grand or 2. It will now be a lot simpler to submit after the changes now. I may even go down the route of a s73 ammendment if after 31 July this would be considered a 'new' permission and not require the BNG. There will be no restrictions on occupancy, UU costs or silly BNG metrics to submit. Happy days looks like sense has prevailed.
Drain in wrong place. Can this be fixed somehow ?
Oz07 replied to Spinny's topic in Waste & Sewerage
I'd keep it trapped if on a foul system -
Till you pull it all out you won't really know if you can make the bend to fit the gully to the ic. It looks tight. If it's only rainwater and softened water going in you could use a back inlet gully. Connect that one to the ic, maybe even where you want your softener, then connect some 110mm into the back of that gully and run it to the corner where you want this downpipe to finish. Might be even easier to keep gully where it is then used some dished channel drainage or similar and put a shoe on the bottom of downpipe -
Once its mist coated it will show the imperfections and cracks easier. I'd do all the filling or caulking after that. I wouldn't be dremelling any cracks to make wider. A wet easi fill mix is pretty fine seems to get in cracks ok.
1 or 2 mvhr units?
Oz07 replied to lizzieuk1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
The units are very expensive for what they are aren't they? I'd be trying to keep it to 1. -
With much difficulty, d4 glue getting everywhere and swearing. Does the stud come right up into the first floor too? 1m is quite a wide staircase. Maybe you should be looking to have it made at 850, 900mm?
I think mandating a charger is going beyond their remit. Ill be fitting a dummy or spares and repairs to my next place unless we have an EV. If the bco turns up and there's one on the wall id imagine they would be happy. Anyway what happened to the granny charger leads that could be a charging point with an outside socket
The made to order cavity closers are much better quality than the ones bought in loose lengths. Even come with plastic ties which get set into mortar.
Shocking Snagging Inspection Finds at NEW BUILD HOMES....
Oz07 replied to MAB's topic in Housing Politics
Fancy planners dictating window colours on a development like that. It's hardly likely the builder would do anything crazy anyway, they want to be able to sell them. One reason of many this country is knackered some office jobsworth dictating window colours. -
Did they roll with spiked roller? Looks a bit gash. Remind me whats going ontop?
Whats the specific issue with the planings?
If your not confident marking and cutting for the underside. Just use your jigsaw with a downwards cutting blade and take your time. It won't be a perfectly straight cut but as above the edge of the sink will hide a lot
Is this a reasonable cost for plumbing first fix?
Oz07 replied to Great_scot_selfbuild's topic in General Plumbing
Does it take you a long time to draw off hot at basins then?
