Oz07
    6
Everything posted by Oz07
  1. The problem i have with this is everyone who says it has spent thousands on an mvhr system. I had one in our last place, the air was a lot drier (too dry really) and it was nice cleaning the filters and seeing all the muck its taking out the air. I'm not sure it was worth the investment. @joe90 used to turn his off in summer, @ToughButterCup hadn't bothered with one last time I heard and serial self builder @nod never bothers, but then his motives might be different! They are a nice to have and I will probably have one again in next place but I think you'd enjoy the comfort an aircon provides a lot more. How much would it be to first fix the pipes for the mvhr then make the decision later, the unit is usually the big ticket item but probably not if your having to pay labour on the install.
  2. Yeh just had a look. They seem good. Thin bars, butt joints etc. 1.2 u value as well. What's the pricing like compared to timber?
  3. Am I the only one thinks that would be pretty cool?
  4. Are there any decent makes of sash windows in upvc with good u values? All that I've seen look too chunky. I would wonder how good the window performs with seals as well not having as much compression?
  5. I'd say its a bit too late if manufacturers and engineers have been consulted. In the real world this is what would happen though. You'd be pissed off with whoever did it mind.
  6. Yes on concrete / screed in an older house. SLC beforehand No it had a dpm, then an underlay and then the flooring. All the joints were glued so it just floats as one large floating floor.
  7. Presumably full fill too? You can buy those cavity sure trays if not now which give you a guaranteed 25mm or something clear cavity.
  8. The ones I did were floating on an underlay. It was just the joints that were glued to create a floating floor
  9. Won't work on concrete though. I've done floating timber with glued joints before now.
  10. I think timber frame and block cavity are easy with finance. You'd have to check with CML or uk finance whatever they're called now make sure the majority of lenders are happy
  11. Not as good for finance or future sales purposes I think?
  12. You can still full fill up there then? I thought it went on exposure zones? The stuff is deffo water repellent. An offcut can sit in a puddle for a week and is no heavier for it.
  13. Ive had pumped before and slabs. Id be interested as to what is better around cavity trays. Do pumped beads or dritherm work their way around all the folds and lintels? Pumped used to be cheaper at one point but then slabs became cheaper again. I find its easier to keep cavity clean of mortar with slabs. The compo just drops down onto last row of bats and clean it off. When you have an open cavity it drops right down to the bottom.
  14. @Gus Potter i think there are a lot of items in your list that get copied and pasted between jobs with tweaks. For instance design and access. Moving forward maybe AI will also cut the labour involved in design and access down too? I've never used an engineer to set out or survey and have built a few houses now, just use the OS maps. Even though I've never been quoted fees as a % it is relevant because in your example 9k on a half a million pound house is a lot different to half a million on a 2 million quid house. The uplift in plot value on the planning permission will be a lot more.
  15. Insured tree man. Like you say too built up around there. Ideally one with a stump grinder as well. Done and dusted in 1 day then.
  16. Didnt @tonyshouse try this with a borehole in his basement. Probably too late to do now as it heated the ground up under his house iirc
  17. Tbf im not really on about re building our network based on coal or running off 100% coal. All I'm saying is its been a choice to demolish our remaining working coal power stations. Will that be a good choice time will tell. I don't think it is. A lot here seem to be doing some impressive mental gymnastics to explain why China are building lots of new coal plants but it's ok for them.
  18. Before you pour is better, while the digger is still there.
  19. Sorry my reply wasn't aimed at you it was to the people who were telling me coal isn't secure.
  20. So coal has a place to help secure energy. Are we all paying attention now
  21. Say 200mm stone, 200mm insulation, 100mm slab. 500mm. Less full being 150mm above ground gets you to 350 reduced dig off ground height. Can reduce insulation with pir and prob go down to 150mm with stone
  22. I get the machine to scrape out before he digs the last wall. You just go to whatever depth you need to bottom of stone for slab or clearance for suspended floor. Are you sure its only 200mm below ffl at present? Did you not even scrape the topsoil off prior to trenches? Presumably your ffl is around 150mm above the existing ground before you started?
  23. The competition is who has the most energy not who has the cleanest. Look up how much coal China built in 2024 and 25. They ain't picky about where it comes from solar, nuclear, coal whatever works
