Bonner
Everything posted by Bonner
Torque requirements for power and lighting switches?
Bonner replied to Ben100's topic in Power Circuits
Remember righty tighty, lefty loosey -
Have they done a survey? My first quote came in similar to that, after a survey they added another £1200 for the road crossing. Connection cost is normally just tie to a main within 3m. Road crossing or other works would appear as another line on the quote.
There is a shortage of everything at the moment. The rush to catch RHI along with surging gas prices has increased demand for heat pumps. It seems that self builders will probably qualify for the boiler replacement scheme, according the the draft legislation.
Haynes Self Build Manual is not a bad place to start. Then start researching details on here and other on line resources.
- 15 replies
The application was for a Temporary Building Supply through Anglian Water ‘Development Services’ department [email protected]
Not standard practice, our temporary building supply is full flow and pressure. And not been billed for it since connection nearly a year ago ?
I got a new supply from Anglian after much faffing about. The people in the office are mostly planners/administrators, I found the technicians very helpful once you get them on site. As mentioned, report it as a fault or even better, a suspect leak ...
I always carry one of those for little emergencies ?
How the hell do you get the damn thing off!
Bonner replied to canalsiderenovation's topic in Bathrooms, Ensuites & Wetrooms
Another channel fitted the the wall first. Clearly a different system -
With great difficulty! In mine, the frame was pre-fitted to the screen and it would take a lot of force to remove it, probably damaging the channel or shattering the glass. Why do the you think this is the problem? When I had a leak, I found that the installer had sealed the inside of the channel which you shouldn’t do. The idea is that the frame needs to drain into the shower because it can fill with water no matter how well you try to seal it. -
You could try sticking acoustic foam on the inside of the cupboard doors, overlapping the gap. If it works make something more permanent or, if you are like me, leave it until you have finished everything else.....
Does concrete cast furniture need to be monolithic
Bonner replied to Adsibob's topic in General Structural Issues
It is a thin layer of concrete which will probably crack but not really a problem. Just make sure the new concrete is keyed into the existing and the steel plate is free to expand and contract. Suggest you sit the plate on a thin bed of mortar as well to ensure it is fully supported. -
Just to clarify, the regulation is still in draft so I am waiting before deciding which way to go ...
I am chasing the RHI but will very likely miss the deadline. The boiler upgrade scheme is not as generous overall (RHI calculated payment for me would be £11,000 over 7 years) but I will take the MCS route if self builders qualify. If not, I will self install once things calm down. The relevant bit was mentioned earlier in this thread before we expanded the topic ? 7. A property meets the requirements in this regulation where— (a) any building that forms part of that property was built principally with the use of the labour or resources of the first owner (including where the resource was a loan which the first owner was liable to repay), and (b) the property has not, while the building was built or at any subsequent time been owned wholly or partly by a person who is not an individual.
My structural engineer was going to do a PCC for mine but he disappeared. CMLC have taken over from wall plate without additional cost. Hopefully their warranty will enable mortgage lending if needed in the future but I have no expectation of a payout from a claim.
We have been competing for our brickies all year. No incentive would pull them off their developer’s job, which I understand. Fortunately the masonry is all done now but I fear the same with other trades.
Estimators online at around £180, has proven quite accurate. You do need a set of drawings first though.
I have got a quote from Grant for a similar system, how is yours working now? Any problems? Is the volumizer a form of buffer?
Bathroom Furniture/Suite Supplier Recommendations
Bonner replied to Matt60's topic in Bathrooms, Ensuites & Wetrooms
Also struggling with bathrooms sourcing, @tonyshouse, please can you share. Cheers -
Excellent, well done! I wouldn’t like to think of you in that caravan for another winter ?
How to fix timber wall plate to heavy duty steel lintels
Bonner replied to WWilts's topic in RSJs, Lintels & Steelwork
I had a similar issue recently, found that the lintels should have one course of blocks before wall plate. These lintels are not designed to carry the wall plate directly (or take any fixings). -
Mvhr ducting damage
Bonner replied to Dunny1234's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I would do all of the above, just to make sure ? -
+2 taking an axe to the logs is my release after a stressful day at work
- 40 replies
Just for my understanding, where is the border?
- 131 replies
- triple glazing
- condensation
(and 3 more)
