Everything posted by JohnMo
flashing over windows and doors - timber cladding
JohnMo replied to marmic's topic in Building Materials
A slightly more advanced photo with more of the battens in place, you will insect mesh as well to wasps out etc. -
Daikin Altherma 3M heat pump no longer starts the compressor
JohnMo replied to AL Ken's topic in Air Source Heat Pumps (ASHP)
Is the menu saying you have external thermostat(s), if so are there calling for heat? -
Multi-point tankless water heaters
JohnMo replied to Invader75's topic in New House & Self Build Design
Basically as they are direct electric the efficiency will be exactly the same heating water. Storage losses may be smaller with a single bigger cylinder if the surface area in the combined cylinder is smaller. But if you already have 2 the cost pay back from improving efficiency, to pay for a 3rd bigger unit, would several life times. -
Ubbink - what are they like?
JohnMo replied to lizzieuk1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Heating at passive house flow rates is limited to about 10W per m² of floor area. So heating is possible to fully heat a passivhaus or knock the cold off a more normal house. I would just do a single heat bank water coil upstream of the manifold. Then add something like this for £500 https://bpcventilation.com/products/cold-water-duct-cooler-range?variant=53736023261510&country=GB¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=22309731029&gbraid=0AAAAADpzxaVuRiJvI1F3wJ3DAy6JrgNmt&gclid=Cj0KCQjwmYzIBhC6ARIsAHA3IkR7VeYyluH-E6sPvQvoP7NgX-nTx-8L6YP-l9OAvZNbuLjgrusSh0QaAtYIEALw_wcB This has the capability to cool and heat as it has condensation drains etc. But this is all you need to heat, depending on dT between coil and air for kW output. To cool you would need an oversized MVHR unit and in cooling mode it would be wired to run full speed. Still won't be great cooling due to UK humidity. -
You to look at the exact flow rates and temperature required to get that output. Just checked the datasheet and outputs when you compute them are based on 45 to 55% humidity outside air - not sure we get that very often in the UK? Plus you need a massive flow rate. So science hasn't changed just the prices of equipment - Titon unit is only £8k -
24 panels on a new build roof. 2 strings of 12, or 3 strings of 8?
JohnMo replied to jimseng's topic in Photovoltaics (PV)
Doesn't make the answer correct! Which it isn't. There is an over panelling allowance in the total Watts you can generate, but you still need to stay within the specified amps and volts limits. -
That isn't really correct, you have a single string which is a series-parallel array. So in this case voltage 9x a single panel and amps is 2x a single panel. So question, is the amperage within limits of the inverter? Possibly not a concern at this time of year but could be in summer, could be where you may exceed the 26A MTTP limit. -
Sounds like you need to step back a little. Plan exactly what you want to achieve, put some realistic numbers to the costs. Write It all down. Get a big note pad use It as brain dump, scribble pad. Put it by your bed and instead of rotating a thought around your head write it down. The process is pretty simple, but gets overwhelming because there are many parts that need to be done in a specific order. Plans are good they keep focus, a snagging list needs to to be added to the plan at every stage so things are out of your head and on paper. I am saying on paper for good reason, it quick and easy, it doesn't crash and doesn't need power or internet. I really found this forum useful at the start and planning stage, but once I started the build I didn't want the noise of a 101 opinions of a forum, I had a plan, a design and stuck to rigidly. It shouldn't be an overwhelming process, steep learning curve - yes. Why two properties? Do you need two, why not just one? Why semi detached, that means you really need to do two properties at the same time? Do you have suitable funding in place?
Downdraft Extractor Ducting Route
JohnMo replied to carson321's topic in Kitchen & Household Appliances
For me I would Do in recirculated mode and come out at the kickboards below your kitchen units. Then install a dMEV (with automated humidity control) fan in kitchen plus all other wetrooms. Undercut all internal doors and have humidity activated trickle vents on all dry room windows or through their walls. Have a proper ventilation strategy. -
No gave up in the end and bypassed it, mine was in a summer house, installed a fan coil instead. Without a screed or biscuit mix to get good around contact with the pipes, UFH is pretty pants from my experience. The other way around it, is to throw huge temperatures at it - but that's not in my comfort zone.
Sounds like the heat is circulating, but not being absorbed very well. So not being transferred to the floor. I had a similar issue with an overlay system in theory should have performed great in practice was pretty similar to what you are seeing. Low dT and very poor output, for a given flow temperature.
What did your build cost come out at 2024/25!
JohnMo replied to PSC88's topic in Costing & Estimating
Yes, full kitchen, 3 bathrooms, decking patio, solar, heating etc all floor coverings, basically house ready to use and passed final inspection. -
No too many variables our plot is 2 acres in Scotland not comparable to London. Our ground work other than foundation, isn't included either. We are on the side of hill had to carve out a road etc. The point of a well designed self build, it isn't anything like a developer house, so price wise not comparable either. -
Warm or cold roof design for our flat roof?
JohnMo replied to Great_scot_selfbuild's topic in Flat Roofs
If you do option A you need insulation above the outside wall insulation to join the wall to roof insulation - otherwise it will leak like a seize. But I would just do option B, but add a 50mm service void to the ceiling with a vapour airtight membrane on bottom of rafter and service batten below then normal plasterboard. -
Are you sure you don't have an air lock? Do you have a call for heat? Is this from anything external? -
There are 2 or 3 port designs. I use one between heating and DHW. They come up.on ebay from time time pretty cheap https://esbe.eu/group/products/diverting-valves/mba130
SAP Completion and other bits and pieces needed
JohnMo replied to mickeych's topic in Building Regulations
And a home owners manual -
Why not just use a simple diverter. I would look to use a MoMo diverter these use a live signal to move valve between positions and then draw zero Watts once there at either end of the positions. Something like an ESBE MBA. Then upstream of valve have a pipe temp sensor set to switch at 20 degs, anything above 20 is assumed as heating and below is cooling. Use the sensor to switch between the two positions. Use something like this to do the switching - nice simple and cheap plus easy to replace. https://www.toolstation.com/corgi-pcs-dual-pipe-cylinder-thermostat/p68281?store=LJ&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&gad_source=1&gad_campaignid=17808658009&gbraid=0AAAAAD-vLcX0JQPMjDufZ6UOJnzMg2icv&gclid=Cj0KCQjw9obIBhCAARIsAGHm1mSOycvA4DBwLfJ2NQYEJQUeyqdHr4w7n_OiVbj7YKg3ZkM4cP9y4ikaAs_kEALw_wcB
Have a good read up on that, then you will change your mind and keep a few grand in your pocket. Its useless in the UK. -
Normal wood shrinkage cracks - nothing to worry over.
- 1 reply
- 3
Means I would double my money - 💰 in the bank. I built during COVID the most expensive time you could build. Very limited people allowed on site one trade at a time. Material in short supply and a sellers market. Really depends if your self builder or just paying a builder or where you sit anywhere in-between to the final bill for the build. As mentioned previously, spec and how you buy has a huge impact on costs, but overall how you source has biggest impact. I sourced everything for our build except the cables and fittings supplied by the electrician, and roof was an agreed fixed cost. -
You airtightness after second fix for building control. You also need an as built SAP completed. -
Wouldn't the constant temperature controller try to mix flows to get a required temp, so may stay at mid point especially between heat pump compressor running cycles? How does your heat pump change between heat and cool? Is it an external switch and dry contacts or software via the controller?
Don't get too hung up on it, if the are not massive. My Passivhaus certified Roof-Maker ones have a Uw of 1.0. I spent more effort to get a thermal bridge free install, thought that was way more important.
