JohnMo
    200
Everything posted by JohnMo
  1. Almost all currently available heat pumps do this out the box - you only need one mixer for the lowest flow temp zone. Shouldn't need a volumiser either, unless you over sized the heat pump. Basically work on the basis of 20L per kW minimum output, system volume, if you achieve this no volumiser is needed. Complexity - a temp probe down stream of mixer, connected to heat pump control/wiring centre. 3 wires to mixer from same control/wiring centre. Set controller to two zones, set the two WC curves, job done.
  2. Or let the ASHP controller do the work, two zones, so two WC curves, controller can use an electronic mixer, such a an ESBE, the ASHP controls flow temp to coolest flow temp, no buffer needed, no temperature distortion, no additional pumps. Just run as fully open system with two flow temps, one unmixed and one mixed.
  3. Here are couple of documents to get you started UFH-System-Design.pdf UFH output calculation.pdf
  4. Simple answer you ASHP company should do this for you. They need to do a room by heat loss calculation anyway. They will know the UFH design, because you will pass it over to them. They will then be able to state at design temp the flow temp. Flow temp required will also vary with a screed depth and floor make up insulation etc and floor covering. So a little fine tuning may be needed.
  5. Deep sand, doesn't give very good grass, as the nutrients and water just bleed away very quickly.
  6. Top soil by the lorry load is around £35 tonne, if you are doing garden just do top soil. Any other purposes recycled concrete etc. or similar to bulk fill then hardcore all compacted.
  7. Dodgy temperature reading to me, or you have the wrong identity assigned to each gauge? So rubbish in, rubbish out. You seem to making an issue from reading from a £1 gauge.
  8. The other way to it, is borrow ideas for the Adia system and simplify. Have heat pump on its own loop, CCT and additional pump for secondary loop, flow rate and match flow rate with secondary pump. Choose pump with enough head to go through existing pipes as required. Use flow setters on the existing rads at a dT to suit room and flow temps. Heat pump will modulate as needed to meet the heat extracted from the primary loop. Primary pump pulling almost zero Watts as no real head is needed. Whether you actually need to include the CCT is questionable, you just install an additional pump on the piping to produce the additional head required on fixed duty (then there is no fight with 2x modulating pumps), to push though the existing pipes. Then do what you normally do to the system.
  9. And domestic cats kill way more - every year. But no-one complains about that. Don't here any slogans "stop the wind farm and neuter/ban all cats"
  10. Are you not just arguing for the sake if it? No one one says (well maybe a few some ill informed are) that we must stick with hydrocarbon energy sources. NIMBY's are complaining about anything and everything, even if happens 20 miles from them. If we can get all our energy from renewables (which doesn't include nuclear) let's fill our boots. Distribution of said electric needs to happen, more NIMBY action there. In the time to bring renewables on line oil/gas needs to back fill. All very simple.
  11. Panasonic, Daikin, I'm using a Myson iVector. You need one with adjustable water flow temp fan start permission. Some only really designed for gas boiler so have a fan start permission of say 45 degs - which is no good. These fit in the none adjustable fan permission category, in most and are designed to allow cooling.
  12. Think it's there to cover all bases. Use the installed pump of the ASHP to overcome heat exchanger and piping to house. The secondary pump is there to push though micro bore if you need to. It's a one box to cover a lot of situations. Still not seen anything on how it works with UFH. It says one flow temperature systems including UFH are doable. But not seen any details.
  13. They can't, almost no country can, it's a global market. It's what I mentioned previously, it shouldn't be a binary gate, each fuel, renewable or hydrocarbon has a part to play. Trouble is the environmental activists, demonstrate, with their plastic tents, plastic drinks bottles, fleece jackets, nylon ropes, and don't understand all that vanishes with no oil. The point should be what mix of fuel and energy sources leads to best self reliance. A grown up discussion needs to be had, but British politics, the press and the money, will never let that happen. You need people power to revolt and standup, but most couldn't give a stuff or cannot or not interested enough to understand the issues or possibly solutions. In the round renewables is the way forward, but for a long time hydrocarbons will have a big part to play, especially in England, Scotland way less so.
  14. It's sold on the basis that no radiator or piping changes are needed. After a few weeks of capturing data, the home owners gets the options - stay as you are, and possibly upgrade radiators, for a given cost v cost saving on running cost. Suppose the idea is for £4k plus a day or two labour you get a heat pump. If you have a cylinder already they can use that as well.
  15. I installed two units in our house, self installed, well under £2k all in. Ebay can be your friend - if you accept warranty is unlikely. But in the UK you don't need pre heat or enthalpy heat exchangers, you don't need CO2 sensors and really once setup, and running, you don't even need boost very often - we last had boost on (manually) over a year ago, auto boost just isn't activated. Manual boost outside bathrooms and in kitchen, or manual boost in kitchen and humidity activated elsewhere.
  16. I've seen that way of doing things mentioned several times and the real world a lot of building could get away without much in the way of radiator changes. VAT, include a contingency (deposit) to return assess and make x pre priced changes - fully refundable, less second visit service charge? Explain you could remove that charge, but full VAT, plus any grant funding, that was too have been included, would be payable for the second visit.
  17. Keep it all simple and functions separate First ventilation is ventilation, it isn't heating/cooling. Separate the ventilation keep it a stand alone item. Cooling via MVHR is an expensive folly and in the round doesn't work as flow rates are too low. Why oversize the heat pump - bad for SCoP due to cycling. Plus Vaillant don't do cooling out the box and cost way too much So is that 3kW or less? if so heating bey direct electric isn't going to be cheap - 3 x 24 hrs is 72kWh. Direct cylinder are fine, not sure I would pay the premium for an OSO A rated one. Slightly oversize for house and heat to 50 degs. Low tariff charge not from battery, use battery for other stuff, not worth the round trip losses when you can charge direct, without going via battery. I would do Decent no frills MVHR, if you want a Passivhaus certified one, fine, but leave all the optional extras on the shelf Stand alone small heat pump - A Haier 4kW is £2100 from Wolseley incl VAT (you can reclaim) Telford Tempest 250L direct cylinder £610 UFH to ground floor, £1k - fully open system, no room stats or actuators, flow direct from ASHP circulation pump Or direct cylinder and a good quality A2A heat pump for heating and cooling Option 1 - no Option 2 - no, almost but not quite - £10k for MVHR are you mad? Options 3 - no
  18. Get manufacturer and industry (BBA/BRE) test certs and see what it is approved for.
  19. Just found a price, £1500, smart but... if offsetting getting new radiators, new plumbing and paying for an engineer to optimise your system, then small beer. New build where you should know exactly wall, floor and roof buildup and get heat losses quite accurate and your installing new piping and radiators anyway, not really needed. But would idiot proof a lot of installs, assuming heat pump is massively oversized.
  20. Wrote that incorrectly. They allow vapour out, but air in and out and keep water out should you have issues with your tiles or slates
  21. Choose a product specifically with certification for what you want. Kingspan Nilvent comes to mind, but plenty of other available. Look at the certificates and approvals. Doesn't Allow two way humidity movement as it's a smart membrane? If so not sure you want unventilated roof space, but with correct roof membrane you still get plenty of air movement as they are vapour closed and air permeable. Get you ducks in row and the BBA certificates, then you should have no issues
  22. That's an interesting bit of kit A video here https://youtu.be/9sHmHa5ha_4?si=mir2dQesUXf0Aqgn
  23. It does external and assumes 20 deg internal.
  24. Everything relevant via Heatpumpmonitor So plot of all the data so far, included hybrid running, ashp on it own in heating and cooling modes. I can go in to each day and see a 20 sec resolution on all the datapoints, instantaneous CoP, flow rate, flow temp, return temp, electrical input, heat output etc
  25. Certainly does, out the box I would suspect a sound SCoP of 3.5 to 4.0. Without monitoring gear, no-one would see the modulation that was going on in the background, not even the installer. I am fully expecting a SCoP in the 5s
