Dave Jones
Everything posted by Dave Jones
sure its not the FFL level that is out/not accounted for ? Very very strange for even the roughest chippy to set 2 doors to 2 completely different heights.
Discount Offers of the Week
Dave Jones replied to Ferdinand's topic in General Self Build & DIY Discussion
we use a nuki lock, full apple integration. hey siri open door. same as garage door opener. -
unlikely. Does it include all the 2nd fix items ? Structure below DPC ? Steels ? All the fees (warranty, SE, SAP, Bio etcetc) ? Probably need to add a third again then another 20% of the lot as a contingency.
You will definitely be below market rates using free labour but if you need to borrow against the build to fund it you will need to get is QS'd real world which means £3-5k m2. Doesn't mean you have to spend all that but alarm bells will go off with the lenders if you start quoting fantasy m2 rates. plenty of cheap online QS services who will take your plans and price them to the nail. Bear in mind they exclude 2nd fix items, anything below DPC unless you provide them the spec, steels etc unless you give them a SE drawing. Also account for all the paperwork fees and there are a lot now, warranty, insurances, bio-diversity, SE, SAP, etc etc another £15-25k Plot sounds expensive for the area.
one of the many many advantages of using microinverters.
hope you put some footing under it as well! Doesnt have to be mega deep but id want at least 400mm below ground.
you want permanent scaffold on your roof ?
Finishing window reveal around brackets?
Dave Jones replied to BadgerBadger's topic in Windows & Glazing
cut all the foam off flush, air tightness tape frame to the INSIDE block. Then 25mm insulated plasterboard (not really needed but cheap) over the top and skim. Remember to fit window boards first. -
it gives an interference airtight fit as timber is rarely dead straight.
Replacement UPVC window damp/condensation issue
Dave Jones replied to Iggy's topic in Windows & Glazing
cold bridge and dew point in action. Not thats its any help to you, but its why new build regs windows have to be sat in the cavity at least 70% so they form part of the insulation envelope of the building and then issues like yours are moot. -
Best option for dropside van?
Dave Jones replied to Bancroft's topic in General Self Build & DIY Discussion
tipper. so much more useful than a panel van. can collect palleted goods, jumbo bags, muck aways, concrete, pilesof insulation etc etc etc -
Dimensional Tolerance for Setting Out of Electrical Outlets
Dave Jones replied to PLK-UK's topic in Electrics - Other
how far out are they to the drawing ? Did the drawing have measurements on it or did you scale ? -
if your boarding the joists you cant have any insulation ?
There really isnt much to an ASHP, a flow and return, 2 electric feeds and thats it. Much simpler and quicker to fit than a gas combi for example. You could DIY the lot for £5k tops, obvs get a sparky in for the hook up.
your paying a 50% MCS tax. Cheaper to do it without.
was all that osb on the floor covered in puddles just temporary ?
Heads up another octopus session today mid day, paid to use as much as you can. 16kw is the cap with everything on for us unfortunately. Was hoping for 20.
When the UFH flow Temp is <35C, dhw?
Dave Jones replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
our setup similar to johnmo, albeit we control all automation with home assistant. Heat pump is always on automatic 24x7 either for cooling or heating. hot water replenishes to 40 via ASHP immediately, then depending on the time of day (solar availability) it checks the 30min octopus price for cheapness and if its cheap it blasts to 55 after which the eddi (ASHP has no direct control of the immersion) takes it to 65. Took a bit of tuning to get setup but now its just set and forget.
