Dave Jones
    11
Everything posted by Dave Jones
  1. dont worry about airtightness in the loft, you actually want the reverse. You need to seal up the ceiling and walls below. If you have dabbed plasterboard on the external walls go up in the loft and foam the tops all the way round. If you have downlighters put airtight hoods on them all. rubber seals on loft hatch etc. then leave the roof alone.
  2. personally i would clad the whole place in external wall insulation and render. Couple benefits, wont lose room space, help fixing air tightness and covers up that miserable depressing grey stone. some nice new windows, fitted and taped well and you will have no problem keeping it warm cheap with an ASHP.
  3. forget about MVHR for cooling there is nowhere near enough air flow. Think of your air con working via trickle vents. we have the zehnder cooling/heating battery ont he mvhr intake(£2k) and it makes no noticeable difference to cooling. We had it purely for winter use. Wouldn't bother again though.
  4. its all relative. wouldnt put them in a council house or a legoland estate house but a nice self build ?
  5. we have butler sink also, its possible - just- to fit the whole quooker setup (we have hot, fizzy, cold and filtered) under it with a little bit of butchery along with a waste disposal unit. Just dont look too hard at the cost .... Saves wasting a nice corner unit pull out.
  6. cant put in in skips either. right pain
  7. morning with a 5 ton digger, burn the lot and fish out the metal for scrap after.
  8. sbr and cement IS the slurry. lay them on a 50mm bed of conc made from sharp sand 5-1 mix
  9. https://www.bpcventilation.com/panasonic-fan-coil-unit
  10. SBR and cement. make a mix with it. Obviously you cant just drop them on dirt like the photo, you need 100mm type1 compacted and at least 50mm of conc.
  11. you wont be able to store anything in the loft unless it has had legs fitted to raise the boards above the insulation.
  12. if all you got is stud wall the wall plate is least of your issues.
  13. look a lot better with some oak sikkens cetol on it.
  14. are you external walls really just stud ? option 1 is perfectly fine as long as the cavity insulation and loft insulation overlap.
  15. there is no black hole ? Like saying there is a 100bn black hole for holidays next year.
  16. you could allways sister them up with OSB cuts each side with screws and expanding D4 glue.
  17. Just make EPC D and below houses unmortgage able from 2035. Make any spend on insulation materials and fitting costs vat free and reclaimable against personal tax allowance. Those who can afford these modest costs should be in rented anyway. No excuses then.
  18. As long as there are lead soakers under it all the way up both sides it should be ok
  19. simple answer is no chance. The fantasy build costs you get here are full of free labour so have to be taken with large pinch of salt. Just get your plans professionally QS'd and you will know to the penny the real cost.
  20. the idea is you want the cavity insualtion to be continuos with the window so as much of the window as possible set back into the cavity. a bare min of 65mm back from outside. Make sure you insist on straps for installing the windows not the cowboy method of smashing screws through the frames into 10mm of brickwork.
  21. same method as we use to stop next door sucking on our solar. flux megajoule 4.
  22. your right to be concerned, id say the builder did it deliberately as it would have been a lot cheaper method. Dew point will definitely now be inside the timbers. Easy fix though, remove covering and just add another 150mm insulation on top then re-cover.
  23. one of the best decisions we made on our build. Was a roll of dice as couldn't find any 'official' advice on using fancoils for cooling. They consume virtually no power as its the fan is a small pc type one, keeping our bedrooms at 20/21 with a 15/16c flow temp with outside temps 30c. If you do go down this route make sure the flow and return is insulated everywhere, inside stud etc as it will get condensation on it if you want air con levels of cooling.
  24. everyone with a standard roof as there is no need.
  25. stop! Use fancoils in the bedrooms, they are much smaller footprint as they have a heat exchanger in them. Biggest plus as they are close to air-con in the summer when you turn your heat pump into cooling mode.
