Everything posted by worldwidewebs
Ducting Suppliers
worldwidewebs replied to worldwidewebs's topic in General Self Build & DIY Discussion
110mm was just what he quoted. Happy to use smaller if acceptable though -
I need about 50m of 110mm ducting for electrical cable - SP Energy have quoted me £93.24 including VAT. Who have you guys used?
Site worker facilities -caravan?
worldwidewebs replied to curlewhouse's topic in General Construction Issues
I did look at getting a caravan but most I saw were pretty crap and certainly insecure if you wanted to part use them as storage. In the end I'm getting a 50/50 office/storage container for 25+vat/week - decent space for the guys and secure storage for some gear. Delivery is 125 each way -
Traffic lights!
Attached is a photo of the road - our plot is just on the right. You can see the electric pole which is just past the end of the plot and the trench just has to come along the pavement. As you can see, it's a very busy road FPLane.tif -
Traffic lights!
No, there's no road crossing at all - just along a footpath! Bloody stupid. I think I'll give SP Energy a call on Tuesday and see why it's been requested -
Just finalising the electric supply from my DNO and they've now written to me saying that the council want manually-controlled 2-way traffic lights installed for a period of 3 days at a cost of £1000! From the pole to the plot is only about 8m so I can't believe it will take more than half a day to sort out. And they can park on my site. It's not even a busy road. Anyone else had this and is there a way of reducing the costs?
All a professional is is someone that gets paid for doing 'a thing' - it has absolutely no bearing on whether they are good or not. So far, pretty much everyone I've worked with has been great - but I've also pulled every one of them up on more than one thing that I'd consider pretty basic stuff that either they should have brought to my attention first, or that should have just been dealt with without my intervention. The only comfort in all this is that I know there is more of this to come so I just try and be as prepared as possible
Why am I now worrying...?
How Much would you pay for expert advice?
worldwidewebs replied to Ferdinand's topic in Surveyors & Architects
I think you'd be looking at £50-£100 per hour, depending on skills and location, plus travel expenses- 11 replies
- expert
- second viewing
(and 2 more)
I'm in the same boat too. I did ask the question in the last week or so as Internorm suggested around a 45mm recess and I did get an answer, but I think I need to re-ask to ensure there aren't any expensive mistakes. I'm sure it's pretty straight forward really
Who was your dealer? I'm just about to put a deposit on some Internorm windows!
Ah, sorry. Mine was pretty straight forward and our council seem a lot more switched on than most (all) I've come across so it was all easy peasy. However, I know from talking to my architect that generally anything on the rear of the property or where it has no impact to the frontage or neighbours is no problem. Removing windows wouldn't be an issue either. Looking over what you want to do I would just bullet point it all out and highlight what you are reducing and that it has the support of the neighbours. I can't see anything contentious in what you're looking to do
Get your architect to do it - it's something they do all the time
Well these are cheaper than I was expecting! I wonder if Openreach will be happy terminating a new line at one and then move it myself later on...
BT/Openreach New Connection
Thank you -
Can anyone confirm if this is the right form? I've taken a look through it seems to be targeted at developers (companies) rather than self-build - this may or may not be a problem! It's also asking about things like lift-lines - any idea what these are? -
Sioo is excellent stuff and Sansin isn't far behind. Have a word with Silva Timber - they'll be able to advise what would be best.
No probs. Re-reminders are always appreciated
Wastes are sorted!
Cool. That's a lot better than I was expecting! We're going to have extra cabling for internet, TV etc but not a massive amount, so hopefully a few 50-85mm holes will have us sorted
Dave, you're my hero Assuming the plumber is taking one of the 90mm holes, is just the other one generally sufficient for what you need or are you having to re-route some?
I need a bit of help! I'm a complete novice with wiring so apologies if I'm asking stupid questions... I've got the timber frame drawings ready for me to sign off but before I do I need to make sure that the routing for wiring (and to a lesser extent the plumbing) will be ok - and both my electrician and plumber have just gone on holiday! The issue I have is that there are quite a few steel and timber beams in the construction due to a large open plan area and I don't know whether the few holes the designer has put in the beams will actually be sufficient. So, what I'd like to understand is what the regs do and don't allow with routing the wiring. Ideally I'd like to go up to the joists from the plant room (where the consumer unit will be) and just route where needed but there are some areas that are more of a challenge. If I can't fully route through the joists could I take some of the wiring through the service cavities, either just above the floor/skirting or just below the joists? What are the rules about routing from ground to first floor? The designer has offered up the possibility of a couple of 85mm holes in each beam (although accepts that this isn't really an area that he understands) but is this really sufficient? I realise this is a tough one to answer without seeing the plans (which I'm happy to share) but as a general rule, is there a mass of wiring everywhere or is it a case of 2 or 3 wires in a loop?
This is about the only area I'm 100% confident on! My dad was a decorator and I spent many an hour/day/weekend/week/month from about 8 years old working with him. The key is to get at least a first coat on everywhere as soon as possible, or earlier if you can! If you do this then cutting in on the final coat is a lot easier
Nooooooooooooooooooooooooo....
