Everything posted by worldwidewebs
Ventilation Boost switches
worldwidewebs replied to Stones's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Many thanks Hugh -
Thanks Do you have a boost function in all locations that have an extract or just the bathrooms? -
Doing first fix wiring now and working out how best to control MVHR boost. How are you finding it working off the PIR and light switches? As an aside, when in boost mode, is the system any noisier in the rooms with inlets? Thinking specifically of bedrooms -
No chance!
I'm about to put a 4x4 matrix in. This one: http://store.aclasstechnology.com/essentials-4x4-hdbaset-matrix-with-4-receivers---4k2k-version-1670-p.asp I'll be routing 3 cat6 plus 2 co-ax to each TV point. 1 cat6 for HDMI, 1 cat6 for smart TV and 1 cat6 as a spare. The coax will allow a direct aerial/satellite signal to be sent, if ever needed. The HMDI Cat 6 will go direct to the matrix whereas the other 2 will go to a patch panel and then on to a switch
The one in the picture is the Bora Basic, bottom of the range. Those aren't £3k though. I think the Classic is about that price though
BT/Openreach New Connection
worldwidewebs replied to worldwidewebs's topic in General Self Build & DIY Discussion
I tried that a while back, but with no joy -
Progress!!! An Openreach surveyor came out this morning to check out the site. The long and short of it is that they can't go direct to the house above ground from the pole on the opposite side of the road as there are electrical cables in the way. As they can only go under, not over, these electric cables (apparently) and they would then be too low, then the only option is underground (result!). It might take 4-8 weeks to get connected but it looks like I've got what I wanted at zero cost - quite some difference to the £7k they originally wanted So the moral of the story appears to be don't go direct to OR but instead get your house address registered and then get an order in with BT for them to provide you with a line/service -
I'm sure this has been asked before but despite searching I haven't found what I'm looking for, so apologies if I'm repeating a theme What I want to know is how others have protected the EPS plinth on their MBC slab. Our house will be rendered to DPC level (or thereabouts) but I'm unsure about what to do below that or when it should be done (before or after render). Our house is modern rather than traditional, if that makes a difference
The Elica is not a patch on the Bora
We are getting a Bora. Seen them in action and they are brilliant things. The Basic is about £2200 and the Classic another £1800-2000
I've just bought some Dukkaboard ones from here: http://www.tilingsuppliesdirect.co.uk/product/dukkaboard-channel-drain-shower-tray I think they go up to 1650 x 1000.
Well I'm trying another approach now. I registered our house name a while back so it now appears on (most of) BT's systems. I called up the FTTP team on 0800 587 4787 and placed an order for a new connection, although I may have slightly over-stated how close we were to moving in... I was supposed to be getting a call from an (OR) engineer to book in a survey but after 4 days hadn't had one so I called back to be told that the 'install' is due in just over a week. Ok, "but what if it's not quite ready?", I asked. The essence of the reply was that they'd just assess the job and get the works booked in. Now I might have the same battle as before but I think it is now slightly different. Initially, when speaking with OR I was just looking for a new line, but now I'm actually looking for someone (BT) to provide a service and this subtle difference apparently makes a huge difference. I'll keep the thread updated on what actually happens -
Cheers, Terry. I've never had UFH (nor lived in an efficient house!) so it's a bit of a leap into the unknown for me. The bigger worry is spending £20k on a floor and finding it fails due to the heat
Thanks for the replies chaps. Out of interest, do you take readings in areas where you may have a concentration of UFH pipework (such as doorway into the plant room for example)? I wondered whether it was possible to see significantly higher readings there.
Looking at engineered wood flooring options and the spec sheets give a maximum allowable surface temperature of the slab. What would be considered normal or high? It's an MBC slab if that makes a difference
2 pack epoxy. A mate has just done this in a 100m2 garage for about £900 and it looks great. He runs a bodyshop and is always working on cars so wouldn't put something down that wasn't up to the job
Ah, no none at all
I know Darren has had better recently. He thought we'd get about 0.4 and we were all pretty amazed at the result, especially as we know the doors are leaking and need sorting out. I can't really comment on the amount of taping as I don't know what 'normal' might look like. I know I didn't do any extra work that I was planning on doing though
Well, the air-test was performed this afternoon and we achieved 0.27 air-changes per hour. BOOM!
Internal wall and floor insulation
worldwidewebs replied to worldwidewebs's topic in Sound Insulation
I'll take another look at them but previously they seemed quite expensive Thats's what I seem to read. I looked at the RWA45 but they only do it in 600mm widths -
Doing a bit of planning ahead (although I might actually put some in now) I wondered what others had used for the acoustic insulation in internal walls and floors (MBC build for the record). I was thinking of 400mm wide x 100mm thick (both floors and walls) and saw Rockwool Flexi-slab at 12.33 + vat from Insulation Superstore (2.88m2) last night (although POA tonight!). This seemed to be as good a price as I could find it, but are there any other options I should consider? Obviously there is a trade-off between cost, performance and ease of handling but only 1 of those 3 seem easy to compare!!!
We were approached a few times to appear on Building The Dream. Would have gone ahead with it too but we were too far down the line to make it worth it. We have agreed to be one of their 'inspirational homes' in the future though
Slate prices have shot up in the past 2 months. Unfortunately I timed it as bad as I could have! £1.55/slate doesn't sound too bad tbh - what make of slate is it? There is good and bad grade 1 We ended up with Cupa R12 which the roofer was quite impressed with. Aside from the quality of the slate itself they were also flat - it would appear from speaking with him that this isn't always the case and it's quite common to end up with many that are curved, leading to a poor job. We did have some like this, but they formed part of our 'wastage' In case you need it, here is a link to the required headlap http://www.sigaslate.co.uk/wp-content/uploads/2014/07/Minimum-Recommended-Headlaps-For-England.pdf
I'm going to be first fixing the MVHR ducting this week - well, that's the plan anyway! I'm using the Quiet-Vent ducting which was supplied by BPC (and great service from those guys I have to say) Anyway, I have a few plenums that will be located within stud walls as we don't have normal flat ceilings in the bedrooms. The studs are 89mm (I think) CLS (MBC house) and the plenums just about fit in the void. What I'd like to know is whether anyone else has done the same and if so, how did you secure the plenum within the wall?
