Eric
Everything posted by Eric
  1. I worked on the demob of Strangford.
  2. Always nice to get a before & after photo, looks very impressive! We have to be finished this year, gearing up for a final push but I think it’s actually harder now than ever…
  3. I use the multitool to notch the plasterboard where the brackets/hangers are.
  4. You wouldn’t see them then though…… 👀
  5. Your approved drawings will state what is required for fire regs, for other walls as above just plasterboard or osb/ply then plasterboard means there is always material behind the plasterboard for fixing items in the future.
  6. Is it possible to get a closer picture where the pitched roof meets the neighbours extension? it may need a better valley made against the extension, possibly with fall to keep the water moving. Others will chime in
  7. Hammer 🔨😬
  8. You could get a job as a narrator for The Curse Of Oak Island, they drone on about finding mysterious bits of wood and nails.
  9. I think the lampshade is the problem, it’s too heavy causing the cracking 😉
  10. I am looking for a supplier for 180mm dia plastic duct - just for the through the wall section on my MVHR install. Does anyone know of a company that sells 180mm, can find everything apart from that size 🤔
  11. Are you going to look for the treasure in the Rockies?
  12. Wowzer! That is efficient. Hopefully we will be submitting ours in a years time. Good luck with the op and enjoy the time off 🙂
  13. WTAF! I would be have them uninstall them 😳
  14. We have all seen that look 👀😬 Just my opinion but wallpaper should stay in the 80’s
  15. I have used SDS drill bits in a Makita hammer drill, not ideal but any port in the storm.
  16. Don’t be afraid of contacting them, they are there to give guidance. If partitions aren’t required by regulations would it be beneficial to fit them just to reduce noise transfer etc?
  17. I would view it as a service void which wouldn’t need to be plasterboard. I would call or email BCO just to confirm.
  18. Welcome to the forum. What does it show on your building warrant drawings? That’s what I would be using for reference, Scotframe would also be aware and would provide the necessary materials.
  19. I had multiple brackets on JJI joists so I made cut outs in the plasterboard with the multi tool.
  20. Where does the ASHP drain go to 👀
  21. Might be better with something like this then
  22. That is a grease trap / gully, meant for kitchen / utility. Just a rain head & elbow is all you need.
  23. Eric
    Hi
    Welcome to the forum, you are in good company 😬
  24. 40 grit sandpaper 😉 I thought this house was actually finished…?
