bassanclan
Everything posted by bassanclan
Have thermal stores had their day?
bassanclan replied to Workerbee's topic in Boilers & Hot Water Tanks
660l TS, provides plenty heat for radiators and ufh. Hot water for 5 showers. Allows it to be heated from solar (via Immersion) or wood burning stove or gas. What's not to like? -
I've put in antislip shower trays. They have a texture a bit like sandpaper. They take some keeping clean, but better a dirty shower tray than a broken leg...
It is 100mm cavity build, hence my concern about whether the lean mix might have expanded and pushed out those few courses. Some blocks are below the blues because they won't be seen after surrounding path it built. They are dense 7n blocks, some are laid flat, to make up for a bit of unevennesses of mass concrete footings. Different soil levels around the site mean there is 10 course of blue engineering in some areas and only 4 in others.
Yes the building inspector did inspect the trenches, he missed his initial appointment meaning the concrete pour had to be cancelled and another slot was booked, so the trenches left open for 4/5 days. I wasn't there when it was poured, so I don't know how soggy it was underfoot, but there is no cracking in the foundation concrete
I'm building a garage. The foundations were 1.5-2m deep mass fill gen3 concrete, no trees nearby. Left hand wall outside course has significant cracking appeared since Christmas. The wall below dpc has also bellied out. No cracks on the inside course, or visible foundation concrete I've got two theories, One being that water is undermining it causing one side to drop or slide away. (This area is very wet with a lot of standing water having to be pumped off) The other being that the lean mix cavity fill has expanded and pushed out the brickwork. (The mix was full of all sorts of rubbish and old cement, slc, dot and dab adhesive, skim etc) My thought is to try and fix it with helical bar and replace the worst of the broken blue bricks?
Looks like real slate. You need to know the measurement of the required slate before you can go ahead and buy replacements.
If you are wanting to put the exact same flooring throughout then A. If you are using different flooring in bedroom to landing you could make an argument for B/C, but it might look too busy
I will have a look and see how far out it is
Does anyone have a recent copy of pdf SPONS they could let me have? I have one from a few years ago, but prices of labour and materials have changed a lot, especially in the past year
It took me a while to realise that it is my job as the builder to prove to the building inspector that my work complied with building regs, rather than assuming that the inspector can see that the work meets the regs.
Depth of Hearth in front of Wood Burning Stove
bassanclan replied to benben5555's topic in Stoves, Fires & Fireplaces
Just to addthat even if you can get away with 225, you need the depth of the fully open door as a minimum, just for practicalities -
Some lenders won't lend on properties with flying freeholds. Therefore they may ask you to repay the loan in a worst case scenario. If you are keeping the properties for the long term and are happy to renew the mortgage deal with Birmingham Midshires then you probably don't need to rock the boat until you are financially able to repay the loan if required
Who ultimately decides and how can I know upfront?
bassanclan replied to flanagaj's topic in Planning Permission
I got a book " The planning game" by Ken Djyksmann (spelling?) out the library, it is very helpful -
Proposed fence behind retaining wall
bassanclan replied to planningffs's topic in Planning Permission
Is the block wall on your property? If so that may make a difference. Start by asking the neighbors they might appreciate the privacy and then you could just go ahead without worrying about planning permission -
Convert UK driveway to garage?
bassanclan replied to Benjamin Whitehouse's topic in House Extensions & Conservatories
Roof lights or sun pipes into the living room might help -
@Nickfromwales
Guttering on a party wall....advice please...
bassanclan replied to Tarquin1980's topic in Garage & Cellar Conversions
Your neighbour is 100% right. You should deal with the water coming off your own roof with guttering on your own land. The advice of a good roofer should help -
Brick bond at window reveals for non metric sized openings?
bassanclan replied to ruggers's topic in Brick & Block
What size brick are you actually using?
