What controller arrangement do you have for the thermostats ?
You could have actuators per loop controlled by this . Then you can control each individually or if you wish have all on or all off I.e as though just 1 big zone .
Googling tells me β¦
Rodents will chew through expanding foam alone, so for rodent proofing this must be used in conjunction with wire wool, copper mesh etc.
pack hole with wire wool then foam ?
Cables / pipes all go through a low level opening to the outside world .
Was planning on just foaming this gap . But worried a rodent of some kind will just eat through it . Can access the outside but itβs not possible to put any effective mesh as plenty of pipe work ( ASHP and water ) to puncture .
Whatβs best to do here ?
I put pir between rafters ( I was led to believe itβs less heat loss than the equivalent depth of rock wool ) . Foamed any gaps . Then put 50mm pir over the lot . Foamed gaps and taped all joints .
Iβve no issue with my inverter .
But as most people new to pv / battery etc. find ; it can take time to swap .
e.g a sudden draw can cause it to go to the grid before using pv or battery .
Just wondering if anyone knows why this is so ? - for me it can be around 5 seconds or so . Is this just a limitation of current inverter technology ? . Bit like the ac to dc conversion costs 10%. When will these inefficiencies be fixed by more modern technologies?? π
Iβm certain you can get some lights very similar for well under 60 quid in the U.K. . Think I used downlighters.co.U.K. Or something like that . About 11 quid each - great quality too
I always buy lights in U.K. - had some interesting experiences with lights direct from China . Usually can find relatively inexpensive ( but nice looking ) lights here . Easy to return also .
Buying China stuff always a bit maybe / maybe not work . I always fit dimmers to all lights now ( controlled by HA ) then the issue of burning my retina not a problem.
I like buying stuff off AliExpress - always a bit β lucky dip β - but as so cheap - why not .
Yeah I figure weight would become an issue. I know there is porcelain-thin ( some as low as 4mm! - apparently just as strong ). But pricing for those is always "please call for a quote " - which of course means it is too expensive!
Guess I can manage 1000 x 1000 no more than 10mm on me tod . At that size only around 100 of them to lay ....πΆ
