Pocster
    29
Everything posted by Pocster
  1. In BM open a box to “ check “ they are the correct screws . Then take said box to counter to get a discount because they are open and some could be missing .
  2. Problem is this hub is powered from a poe hub already . Are you saying inject for the 2nd hub and effectively that connects to the original hub non poe ? . If that makes sense …
  3. Yeah that was my main concern . If the switch is powered poe then it must have a draw off the ‘master poe switch ‘ + what it is supplying ….
  4. I’m sure this is possible … Rather than get multiple cat5 cables outside ( and it will never be enough ) can I have 1 cable going to a hub that’s powered off the poe but equally is poe ? Presumably the limitation with be the combined pull of poe devices plugged into this hub and equally the current pull of the poe hub that itself is connected too . This correct ??
  5. You get all the shit jobs But what about the trans poo toilet ?
  6. Cctv in bathroom . Bit of image analysis based on “ time spent doing “ then you can regulate a fan off that .
  7. Possibly. I didn’t want to “ make it worse “ by scrapping it . I recall when the roof was done that the asphalt wasn’t necessary ( I insisted on it ) ; as it’s a protective layer to the mono block substrate thingy ( something like that ) . Will give it a brush and see …
  8. Interestingly the bit before the black ducting seems ok …..
  9. My flat roof is special; as you can drive on it ( but no one has or will drive on it! ). I saw this by chance today. Scuffed it with my shoe ; didn't want to brush it and make it worse. Not sure if the asphalt is flaking off or not? ( roof probably 4/5 years old ) Or is it just crud? ; this area does seem to hold water a bit....
  10. An extra space believe it or not - which you couldn't 'see' as the curl line was split. Things like this shouldn't exist in 2023. Like on a webpage where you must enter the date and then it complains you need to put spaces in ( no; your code should do that ). Seems to be a common thing with postcode enteries. Don't get it. Validate the input pad/remove spaces etc. - basic stuff ffs! Anyway! - did my curl and something else is a miss now ( I was told the device id was 2 ; but I reckon it's 6 ) - either way inching forward...
  11. Trying to import curl command in postman and the error is "2 options less arguments found, only 1 is supported (the URL)"
  12. Do you know . I can’t answer that . I’m following some German advice that I need to connect to a local physical advice to change configured from false to true . It’s insane how convoluted this is - and I’ve still not achieved it . I do appreciate all the help though ! BIT_SET(*(device,).configuration,TRUE); ( apologies if syntax a little rusty ! )
  13. Modern stuff is soooooo shite. Used postman with import to do curl and got error resource, /sensors/2/config, not available
  14. Tried that
  15. I thought ( after googling ) I had chrome postman add on. But can't see how I do a CURL in it ; just post/get etc.
  16. Mucking windows! > tried as you suggested get rescue/sensors/2, not available, "type 3" error now
  17. Better check I’ve got a json payload !
  18. It says it’s correct for a json payload …
  19. Yeah . Didn’t think of that . Certainly worth a shot !
  20. Jesus! - for the love of God just give me C and an assembler! I'm fighting here! ; simple to someone that knows curl - I'm on windows aswell so I'm even more annoyed than usual! Here's what I'm trying to achieve .... curl -H 'Content-Type: application/json' -X PUT -d '{"configured": true}' http://IP:PORT/api/APIKEY/sensors/ID/config ip:port my HA, APIKEY I got. It's which brackets of which type with which quotes where - that I can't get right. Googling is just adding fuel to the flames. One of you will be some modern sado web page type deal with this mess person ( and much appreciated I will be! )
  21. I get my sparky on a fixed day rate . I then have a zillion jobs he can’t possibly do in a day - so roll them to the next visit . I find this more economical than the price per job …
  22. 1 flush so you both go in harmony
  23. @Thorfun here’s the wc you need
  24. I’d do a new thread for each issue . Simpler for people to bitch then 😉
  25. Just sold a Wagner . when it works it’s great . When it blocks you swear . Would suggest just hiring
