Pocster
    29
Everything posted by Pocster
  1. Today though due to wank pot algorithm it’s not doing what I want . Really would like a “ (expletive deleted) off just do it button “ . For 1 hour I exported just excess solar ; why ? ; who knows ! Anyway ! Changed it now my flux ‘peak’ export starts from 15h not 16h ; also I bang the SolarEdge battery into export mode from 16h until 19h . Want to max out my export at peak rate !
  2. Enjoying flux 35p ( ish ) for 52kwh = £ 18.20 When you factor in the ‘earnings ‘ , the fact it’s powering your house , charging an EV ( only 4000 miles per yr ) . ROI ( as some of you are obsessed with that ) gets considerably better .
  3. Seriously . With correct lighting ( not office style ) it looks ok . You get use to it and tend not to look at the ceiling anymore than you would in any house . Lots of positives; visuals no , not the best .
  4. Suspended ceiling benefits : Lightweight Easy to install No plastering No painting Access to pipes/cables Easy to add sound proofing Easy to add and move lighting Easy to add ceiling speakers etc. Probably cheaper than ‘traditional’ ceiling What’s your problem ?
  5. @Thorfun you know what I’m going to say ….
  6. Get kids and misses to piss in bucket and empty once a day - super water efficient. You still trying to save 25 quid ?
  7. Rubbish website
  8. You can (expletive deleted) a mother up her (expletive deleted) whilst eating a strawberry wank pot
  9. I’ve said it before I’ll say it again … If I can do it any (expletive deleted)er can do it
  10. Agree 100% and it’s not easy getting away with murder
  11. 🙄🙄🙄🙄🙄 true in SO many ways
  12. I know . A ‘budget’ and a ‘time scale ‘ are pigs . My advice . Forget time scale and take 10 yrs like me Budget matters less then because you’ve got 10yrs of extra income to fund it . Oh yeah ; I believe divorce is expensive 🙄 Still ; pretty much a win I’d say .
  13. You can do all the wiring yourself ( apart from CU and some specifics ) You can do all the plumbing yourself and drains You can build all the stud walls and plasterboard yourself You can paint / tile yourself You can install kitchens and bathrooms yourself You can build the entire house pretty much yourself and save £100k ‘s - it might take a bit longer though …. 🙄
  14. You are mr. Speedy ! . I am the slowest worker ! ( I said wORker )
  15. Tbh - if I saw that ; I’d assume the gutter was overflowing
  16. Decided to swap to flux especially with another 9.7kw of storage on the way . Once winter begins can swap to go again perhaps ( though will be a higher rate than I pay now ) . 35p kw export is too good to miss . Also with ( once installed ) 30kw of storage I should be able to weather the odd cloudy day in summer
  17. Think I might make that statement my tag line
  18. Be careful with vat . Vat is zero rated at point of single order for pv or pv with battery . A battery later will attract vat . Tbh there are ways to mitigate that 😉
  19. Girls say that too me also
  20. Yes ; sorry - you are correct . Because as you state in effect it does that on the PW side no issue .
  21. Because if I set SE to discharge it won’t charge from PV . It’s one or the other . As I said there are ways to reduce this . The main reason is I wish to top up the pw as this is what feeds the house directly . The neat way to reduce this is set SE to charge only from clipped . That way SE and PW can potentially charge simultaneously . As the sun is out by end of day ( when pv is minimal ) I get SE to discharge . As PW will be full or near full that goes to the grid . Rinse and repeat ( until winter ) Currently SE and PW are set to never charge from grid - been like that for 2 weeks now . 😎 Admittedly it is like managing a mini power station ; dealing with varying demands . SWMBO is WfH today so it’s a trickier test !
  22. Another option ( you won’t like it ) . Mask the universe out and spray it . You’ll get even cover with no brush / roller marks . But you will cry a lot .
  23. DNO’s can vary on their attitude . Looks like you take the whip from your DNO like I did . Get that g99 in and see what happens .
