Pocster
    29
Everything posted by Pocster
  1. @ToughButterCup no pressure now ! . But we are all expecting perfect holes and photos to prove it 😁. Failing that a photo of the (expletive deleted) up is just fine .
  2. In my experience they just want payment asap and sometimes even think they’ve done a good job when it plainly is shite .
  3. I’ve tried that a few times . Try to be super accurate with measurements on both sides . How far out could I be ? A few mm ?. Nah ; (expletive deleted)ing miles !
  4. What I really want is no ToU but all logic based . If SE.battery < 60% then SE.discharge () endif Or whatever shitty high level language numpty world is currently using .
  5. Actually- I thought about what you posted . It is success through failure . The biggest obstacle in life is yourself . Contrary to what others may believe from my posts I punish myself far more for errors or when something isn’t ā€œ quite good enough ā€œ ( but in fairness is better than most trades ) . It’s an attitude that one must take through life . Trying , failing, taking risk , failing ; sometimes success ! Must go and talk to my shrink now .
  6. You saying I’m an absolute failure ? šŸ˜¢šŸ˜‰
  7. I had no experience or knowledge. My architect had no experience or knowledge. Yet here I am 😊 You got this ! Plans please !!! šŸ‘
  8. It’s funny how something apparently relatively simple requires some over thinking . That’s not a criticism! . I can mull a ā€˜simple’ problem for hours /days/weeks/years . Then what tends to happen is either it was easier than I thought or I (expletive deleted) it up .
  9. My bad šŸ™„
  10. That work for me also ????
  11. As incredible as it sounds when I was a teenager I would go with my dad on jobs ( yes I learnt nothing ) . Once I recall at airbus we had to core a 3 metre hole ( tunnel more like ) at a specific angle through reinforced concrete . Rig bolted to wall . Drill back then was mofo heavy and needed 2 of us to get it up there . Took our time ( water pumped to the tip ) . Would have taken a few hours . But we took all day so my old man could charge 3k ! - that must of been 35 yrs ago . But no one else could achieve that and certainly not at that price . It was super specialised gear at the time . I got paid 30 quid šŸ™„šŸ¤£
  12. Might be ! Should be suitable for a Juliet balcony.
  13. My late father used to do diamond core drilling for a living many years ago . The jig comes with the drill . You bolt that to the wall ; insert the drill . Check it’s all level and off you go . It was ( of course ) hilti gear . https://www.hilti.co.uk/content/hilti/E1/GB/en/products/homepage-and-new-products/diamond-coring/diamond-drilling.html
  14. A diamond core drill fixed to the wall on a jig would achieve this kind of precision.
  15. You can set this with ToU . Better still if you add the mod bus interface ( 500 quid ish ) you can control it through HA . I only do it manually so I can adjust per day based on weather , SWMBO , EV charge etc etc . Its all part of the experiment!!
  16. Se and pw both have ā€˜self consumption’ modes I.e they will charge / discharge to suit demand .pw is in this mode ( don’t think you can disable it ) . Se can be manually set in this mode . If it is they can in certain circumstances’fight’ and steal from each other - this was my issue at the start of this thread . To avoid this we manually charge / discharge se . pw max output sustained is 5kw . More than that it takes from pv then if still not enough grid . If I set se to discharge then a sustained output of 8.6kwh is achieved by their combined outputs
  17. SE is charge / discharge on my command . PW meets my load requirements - if you see what I mean
  18. Pw meets any demand in the day . So we’re ok upto 5kwh . If demand exceeds that it will use as much PV as it needs . I can manually do all kinds of things like cope with a load of over 8kwh - but that’s rare
  19. I was the piss poor builder 🤣
  20. Afraid I can’t help you . My SE over spec’d our beam by 350% !! . I did go mental with him . I believe SE’s over spec massively on a regular basis . Of course this then creates issues like you have ( not to mention increased costs of course )
  21. All is very well in multi verse So! 00h to 11h SE is set to only charge from clipped solar ( anything over 3.68 ). So PW gets main pv generation 11h to 16h SE is set to charge off pv . Its max rate is 5kwh . So anything over that goes to PW . Effectively we’ve swapped the trickle At some point before 16h everything will be 100% full . We export at 25p kwH 16h to 19h Set SE to export ( it will supplement any pv ) . PW will at some point begin export as we are in flux peak time band Exporting at around 35p kwH After 19h . Exporting stops . SE will discharge into PW . Enough to get us through the night . Rinse and repeat . šŸ˜Ž
  22. Yes ! ā€œ Black n Gold all the way ! ā€œ Reminds me of a specialist film I watched once …
  23. @Thorfun - I will genuinely have 1 of these spare soon if you are interested https://www.alertelectrical.com/stephen-p-wales-1-20p-coin-token-meter-tim30.html?utm_source=google_shopping&gclid=CjwKCAjw36GjBhAkEiwAKwIWySaPWoTO9Ife9sOvMT8qya4_KT0czRLdoxlsOn3UTgSFxL-HmnfBmRoCxHAQAvD_BwE I know you want / need one
  24. You better put a timer on that shower - you know ; to save money
