Pocster
    29
Everything posted by Pocster
  1. Zigbee dimmer 8 quid from land of the rising sun . Just saying ….
  2. Hmmmmmm Now then ! I used a recommend installer on here to setup my manifold with uvc etc . They said no blending required as that would be for different requirements e.g ufh and radiators . That statement will cause blood to boil ! Anyway ! If you stick self regulating actuators on those valves the delta is 7 degrees I believe . I have these . Linked to a simple off the shelf control box then through z wave / zigbee switches . Controlled via HA with multi sensors in each ceiling . Contrary to what people think … SWMBO requires bathroom to be hotter than bedroom . Mistress requires her bedroom to be cooler . So whilst ‘ multi zone pointless - heat it as one ‘ - you can satisfy everyone ; and I’m not just on about the heating 😉
  3. Yeah yeah - we will see 😎
  4. I’ve done both methods - I think I prefer timber . Metal was ok ; as others have said every piece is dead straight . Always feels a bit rattley . Sometimes I bolt the steel to the wall and then osb it for a ( perceived ) better fixing . Timber more sturdy imho ( appreciate if you install metal all the time you might disagree ). Speed wise ; I’m slow on either ! Also with timber ; off cuts I find a use for . Metal less so . For walls ! - ceilings - metal if you can 👍 ( not a dig at @Thorfun )
  5. Ok . Looks like the frame sits on or in whatever you want . Certainly worth a punt for 35 quid - cheers 👍
  6. Guess I’d better go to a BM and look
  7. Yeah but doesn’t the frame sit in the chamber ?
  8. Lid in . It’s too low .
  9. I know . But they sit ‘in’ the chamber . I want the lid to sit ‘on’ the decking . So I kind of want recessed but supported off the decking rather than the chamber extension . Probably not explaining that very well 🤣
  10. This type of thing ? https://pipetek.co.uk/products/a15-iron-cover-frame?variant=31311628107894 Looks like it sits ‘proud ‘ ; I assume something flush was better …
  11. Bit of an engineering project just doing the decking . The access chamber is below the finished decking level . Rather than attempt to get it mm perfect I went looking for a hatch that perhaps has a flange , I.e sits on the surrounding decking rather than in it . Couldn’t find anything … ; does it even exist ?
  12. That’s not fair on the gold (brown) fish . It needs a fighting chance .
  13. Must admit I was confused by this . If I do a 💩 - does it hit the gold fish ?
  14. Yeah . I’ll fill the web space for me . Gripfill timbers in ( done that before - rock solid ) . Bit of tile backer board on face - then a few tiles . At the moment I don’t want to do it because ( in another thread ) I want to make sure stair company fix directly to the steel .
  15. Brushed sbr on the exposed gaps . Chucked a bit in the cement mix , also added some fibres . Looks fine - no chance of slumping . Doesn’t need to be perfect . This area is where the staircase apron will fit and associated balustrade
  16. @Thorfun you’d better not be trying to save 4 quid by using the same blade you’ve had for 15 years !
  17. Care = false if (Care) then do_something(); else do_feck_off();
  18. @Onoff this one’s for you https://fb.watch/kW_hYMP1fl/
  19. Try changing the f ing blade 😉
  20. There’s your issue . Non professional using non professional tool . 👍😎
  21. Thanks for the hidden tag . As a professional I would suggest you man up and use a multi tool . The black n gold ones are best . Boom 🤯
  22. Bit by bit then ? Build it up ?
  23. Should I keep going back to it if it slumps and ‘ push’ it back in ? . Or is the objective to do it once and leave it ?
  24. Shuttered this . Went pretty well - but some gaps where concrete didn’t slump enough . Did ‘chop’ it with a trowel . Best way to fill these and not slump and fall out ? Just a stiff concrete mix ???
