Everything posted by Onoff
What ever possessed me to accept a second hand 10'x8' wooden shed off of my brother and then spend a small fortune trying to make it something it'll never be? My only excuse is I hadn't found eBuild then. If I had I'd have done it all so different. Did I learn? I've also got a 2nd hand freebie 10'x12' in need of some repair sitting stacked flat under a tarp. Should have saved my money and bought a wood burning stove!
Should have stuck wheels and a tow hitch on 2) then you could have escaped 1)! Talking of buying women drinks my lucky escape I guess was from the brandy and Babysham drinker! Not good on apprentice's money! My missus is getting back into Pernod & black 30 years after she stopped drinking it. Young barmaid the other night had been working in the pub 18 months and hadn't been asked for it once. Managed to find a dust covered bottle at the back of a shelf. Missus was complaining Pernod was £19 a bottle in I think Tesco. So I bought her an £12 bottle of Ouzo from Lidl.
Marriage license.....
PMSL! Only been at the bathroom 18 months! Just pulled a bit of the PIR out and am running a length of flexible conduit down. Knew these old clips would come in handy one day if I kept them long enough!
Ta. We're trying door less to start with but with strong studs positioned to add doors or glass "wings" later. So you completed the square internal corner first then added the angled face.
Barsteward! Just showed the wife and she said "Perfect, that's just what I want! Except.....she wants recesses both sides, doesn't like the "twiddly" bits (aka controls) nor the "drainy" bit being in the middle. So, got to mod the corner studwork to give a 45deg strip.
It's looking like I might shortly get to having what I've coined a "B'halfroom". That is working bath and sink along one wall. As much as anything a peacekeeping exercise! That'll leave the wc and wet room corner on the opposite wall to do. Posing as many questions as usual like can I lay just a few floor tiles under the sink and finish the rest "later" or should I maybe go for a half height pedestal then I could forget about the tiles? -
I'll have you know I'm on the way to collect the Aquapanel now and I pick up the moisture resistant plasterboard on Tuesday.....quite how long it'll sit there once I get it..... -
.....I can feel some heat shrink coming on! -
Rubber Roof Ladder (Or was it a dream?)
Onoff replied to Barney12's topic in Roofing, Tiling & Slating
As a kid I used to watch a Japanese (I think) cartoon called "Marine Boy", underwater adventure type thing. Searching for that in the now internet age brought up a whole lot of images I wish I hadn't seen! -
Thank God for silver tape! Presumably then (and I have) it's a GOOD idea to keep aluminium foil tape from touching copper pipes because of potential electrolytic reaction? -
Looking for low profile, side mount deck valves to work with a bath overflow filler. Like this shape wise but without the shower function. So just one for hot and one for cold. Any ideas as to where I might get them as I'm getting nowhere! Cheers. http://www.bathstore.com/products/thermostatic-deck-mounted-bath-and-shower-valve-triple-function.html
Looking at these "new fangled" (to me at least) 12V waterproof LED gel strip lights that you cut to length, for the long alcove alongside the bath, the multi coloured type with the remote control. I've a cunning plan for effective, ambient back lighting that won't be in your face glaring whilst lying in the bath. Anyone got any recommendations? I was looking at this supplier from the plethora on eBay. Planning to extend and take the cabling up into the loft and use my own transformer. Might look to light the shower alcoves too - TBA. http://www.ebay.co.uk/itm/1M-2M-3M-4M-5M-5050-IP65-RGB-SMD-LED-Strip-44-Keys-Remote-Controller-Connector-/291361247328?var=&hash=item43d67bd060:m:mgP1Dg-izAkZ0uFI-8ytNDA And can you get spare remotes as I can see one "going swimming"? Guessing if I ordered two sets then one remote would control all which I could live with happily. Where, btw is the sensor for the remote? Cheers (This from a man who's only ever really fitted "proper" downlighters, trannies and florries! )
UFH spare run to non-existent room - and cooling?
Onoff replied to readiescards's topic in Underfloor Heating
You just run ducting (and a draw string(s) if I were you) from the manifold stopping adjacent to where your new room will / may be. This is what I'm doing.....Nick said.....he is a God! 1&2 - Wait for Nick! -
Needed to reinstate the 50mm PIR on the cavity wall where the pipes are. Figured as above to V the PIR which I did on the table saw after marking with a bevel gauge to clear the 15mm copper. Just got to infill it now: The V meets at the back. Can't decide whether to just gun foam the Vs and trim off later or stick back in the removed sections (trimmed for depth)with low expansion foam, At least then the Celotex writing would be back in place! Can't see that "burying" these pipes is an issue on the basis there are no joints in them whatsoever just offsets and bends. -
Considering using these "double" pipe clips up in the loft: http://www.screwfix.com/p/talon-15mm-double-hinge-clip-white-50-pack/20167 The runs will be in what is a potentially cold roof space ( in the nom 1' gap above the ground floor ceiling joists and below the dormer floor joists), at least in the short term. I'd want to anyway insulate all of my pipes. If I were to use these double clips to run a hot and cold 15mm side by side, then insulated over the whole lot, would I not risk masses of condensation between the two?
I reckon you're right. Seems at least one is a Swiss built plane now registered in Norway: http://www.eastbourneairshow.com/flying.aspx -
Gave up to sit in the garden to read this and drink the other. Absolute scorcher and then two De Havilland Vampires fly up the valley and very low over the house! Maybe an airshow on nearby? Biggin Hill? -
That's it, it's staying like this. Duct tape around the pipes, old screw holes taped over. Now got to fit the PIR around these pipes. Was thinking to maybe "V" the PIR so it comes in from each side then foam fill the gap? sans the dwarf wall: dwarf wall in place: Valves just sitting on there for effect, might crank these ends down a few degrees with the spring: -
One of the MANY reasons I could never work for myself. They use me at work for retro fit solutions quite often. When it's gotten to the point the customer is so peed off with repeat breakdown charges on something which was never really fit for purpose anyway & can't be milked anymore I get the job to go in & fix it with cost the secondary issue. Often faced with a very unhappy customer. I'm tenacious and keep at it and get to indulge my quirks and produce a first class solution. I've gotten to play with some MIL spec stuff on the back of it too. The shame is I've often thought the design was crap at the design stage but been over ruled by management and the designers with degrees. The irony is that we've then lost some contracts as the client is that fed up by then. Mates at other companies who now do them tell me my retro fit details carry on trouble free. -
I was considering to drop a separate hot for the bath tbh. It means drilling another hole. The main thing for me and it might seem a bit (a lot?) anal is that it upsets the symmetry of the pipework. At the mo there's 3 equi-spaced pipes and a fourth would throw it all out and make it look ill considered. That's how I think, I get stuck in a loop etc. Sad I know! I'll have to get over it! I've just been in to stare at it all again and decided it's not the biggest issue! The alternative being to redo it all and I think I've peaked on that front. Saying that I am getting to enjoy the bending. Yep the upstairs bathroom sink is fed off the cws tank. This is a tiny 25 gallon one that sits above the upstairs ceiling. The hot is from a copper hot water cylinder above the downstairs ceiling. Think I mentioned back on eBuild that since fitting the tap style below, upstairs we periodically have the cold from the cws get slower and slower till it stops. I then have to bleed the cws run from that 22 mm grey Hep2O stop end you can see in the loft pics above. It's only been an issue since fitting this type of tap. Plan is to change over to mains cold. -
Cold bath feed bent, cranked and in. Tbh wish I'd made it a bit nearer over to the multi-tool! I'll go from here to a bit of that Hep2O PB to the bath filler /taps. Might put an access panel on the end of the bath to get to these connections. Next, the last one, the bath hot to figure off of the sink feed. Will re-position the clips too here and there: EDIT: Debating re-doing the hot feed to the sink so I can more neatly incorporate a tee off for the bath. And again might re-do the cold to the bath so it's further over to the right. I feel like I'm getting somewhere though! -
Is there an issue with having the hot feed 15mm copper to the bathroom basin physically touching the cold (mains) feed? It theoretically shouldn't according to the CAD but with my bending etc. Thinking noise potential and condensation. Option to wrap in Denso where they pass thru the dwarf stud wall or sleeve with something. Cheers, Actually I will have to have a soldered joint somewhere, I've got to tee off of that hot feed for the bath..... -
