Everything posted by Onoff
I've a number of old 18V cordless tools, different makes, bought years ago. Generally Nicad batteries that won't hold much of a charge any longer. Grinder Jigsaw Circular saw Hedge trimmer Recip saw (might be 24V?) To be fair some just keep on going BUT the tools other than the hedge trimmer don't get used as the 3,5 or even 8hr charge times are a pain. For instance this circular saw. Bought for £24 c/w two batteries when Do It All / Focus closed down locally and became Wickes. Lightweight and actually pretty useful: The batteries, no doubt Chinese in origin at first glance all appear the same but there's subtle differences at best. If the + and - terminals are the same and the tower section with the orientation rib fits it might be the locking clips don't quite line up. In some cases the battery will fit but the terminals are opposed. So I got to thinking. Buy some of these Makita USB adapters from China for about £9ea. Then remove the insertable bit from the Nicad battery and graft to the Makita adapter possibly with the belt clip cut off. Happy days, use with abandon with Makita Li-ion batteries. https://m.ebay.co.uk/itm/Dual-Usb-Power-Charger-Adapter-Converter-W-belt-Clip-For-Makita-Adp05-Lxt-Li-ion/123089332675?hash=item1ca8b229c3:g:GQIAAOSwoT1a2eS- I reckon it'll work but is there something about Li-ion tools whereby some intelligent circuitry in the tool stops the battery being completely discharged and thus protecting the battery?
Bank Holiday fun: the cherry on the cake!
Onoff replied to Dreadnaught's topic in General Self Build & DIY Discussion
Actually it's got to be the Super King size bed I made from a standard double bed base. When then I'm asleep I can forget about everything else for a bit. -
Erm...read this earlier. Couldn't think of anything. Re-read just now and still nada. I'd change everything if I had the £. -
Ta. Using an old 12V /1A BT Home Hub 3 psu. Right plug & seems to be doing the trick.
Hi, I trying to find out if mdpe pipe inserts are universal
Onoff replied to rob dayglo's topic in General Plumbing
25mm MDPE to brass stopcock. Tbh first off it weeped but after advice on here I redid with a smear of Jet Blue Plus and sorted! This joint is at about 8bar as well. I've two different insert makes and both fit the S'fix MDPE. -
Anyone got one of these? It's not obvious what charger it needs from the label. Hoping if someone has the same one that they can take a pic of the label and I might have something that'll match in the box of assorted wall watts. Cheers
If something's marked + and - then it's DC or cheap crap marked wrong! There is no positive and negative coming out of an AC transformer, it's alternating current. Pictures pls and close ups of anything written on the lights or connectors.
@Roundtuit, there is another way... You need to find the noise frequency first. Then build (buy?) an anti-noise emitter/amp at the same frequency & amplitude but inverted phase of the nuisance sound. Ideally adjustable to fine tune it. Active noise reduction basically. Like this but guessing lower frequency: http://cambridgesound.com/products/qt-emitters/ Maybe a cheap "try", some acoustic tiles in there? Like this: https://www.studiospares.com/Studio-Gear/Acoustic-Tiles/Acousticheck-30-Absorption-Foam-Tile-100mm_465500.htm? I bought a few second hand off eBay to hopefully quieten my concealed wc. Test flushing and it is very, very quiet but that might be as much to do with the way the "box" round it is close fitting and sealed at the joints. I think more noise will come from the Richards hurtling down the soil pipe in the wall that's only encased in gun foam! Off the wall but it's not a transformer breaking down somewhere but if it's a mains trannie I'd guess about 100Hz.
https://www.nhbs.com/magenta-bat-5-bat-detector? :)
Me and plumbing...nah! Started late tonight, playing Dad's taxi etc. Flexis will transfer to the two lengths of 15mm. A quick bend in copper should sort the valve to the ensuite shower cold and get rid of the white push fits. Probably have to do a saddle to sort the feed to the hot: Down lower where the feeds go off to the downstairs shower. I'll need to joint them: Poxy original waste : -
How did I miss this...it's that big! Edinburgh Airport gets second runway...
Come on baby, light my fire!
Onoff replied to vivienz's topic in General Self Build & DIY Discussion
The only thing with a bonfire is I always think how much water it could be heating! I've often thought a scaled up BioLite or Tegstove to produce leccy would be good.- 27 replies
There's something quite mesmerising about a bonfire. After first "upgrading" to an incinerator I pulled up a chair, cracked open a beer and sat intent on enjoying the evening on the premise that I needed to keep an eye on the fire. Well, if the constantly shifting smoke didn't get me the gnats did! Time I think to empty it of all it's lodgers that have no doubt taken up residence and have another go.- 27 replies
I'm not happy with the symmetry in that last picture Going to mirror the hot so it matches the cold. The whole board will probably have to drop later anyway as the upstairs en suite mixer is way too high up the wall in the enclosure. Also has a naff BLUE plastic tray about 6" high which will be replaced...along with the Artex ceiling, non P5, "ordinary" chipboard floor, 3/8" pb walls etc -
What would a "proper" plumber do? Solder the joints in situ or off the backing board then clip back on? (It's marine ply btw). I don't want to burn the wood. Got my protective mat, random sheets of metal etc. Figure if I lose the pipe clips nearest the elbow/T/elbow I won't melt them! Obviously I've to add short lengths up for the supply and the long drops of the bottom valves. -
Something similar to this maybe? https://www.victorianplumbing.co.uk/acrylic-anti-slip-treatment-m069? Nick will be along shortly!
Thanks. I see want you mean now. Tbh though, like toilet paper I'm on a roll! SWMBO happy enough to have one shower going at a time for now. There's not the cws or hot cylinder capacity anyway for two simultaneous showers. -
Poxy stud on the left wasn't noggined / dwanged properly! I'd like to try and twist it straight but the other side of this pb wall is the tiled shower enclosure. Granted that it will all eventually be redone but it's already twisted away from the pb: It's 350mm between faces of studs but more 355/360 at the front: Luckily I have BEER! -
I am mate! -
Soft, southern shandy drinker me! -
Is that that cloudy wheat beer stuff? Can't get on with it. -
The wispy bits from silver birch bark makes for a superb firestarter to get your kindling going. Handy if hiking...or your plane crashes in the Andes...- 27 replies
If you build a bonfire pile and leave it for a while before lighting it can become a haven for wildlife. From hedgehogs making nests to slow worms under the rotting base. Worth giving things a shake up and bit of a pull apart before you light it...unless you're partial to a bit of roast hedgehog... Apples bake up nice as well. If you want to do sausages on sticks then a green stick won't burn so quick. Same with toast and marshmallows. Man made boards can give off noxious fumes!- 27 replies
One of my neigbours was smoking (a lot of) weed at the weekend. It was really quite unpleasant with it drifting across our garden. Imagine that going into your mvhr intake!
Why not get a garden incinerator and do it a bit at a time? Much safer and controllable! Pouring petrol on is asking for trouble! Usually start mine with the MAPP torch or barbecue coals. Best if the stuff is dry or it'll smoke like a b'stard! https://www.screwfix.com/p/galvanised-incinerator-bin-90ltr/51344?- 27 replies
