Everything posted by ToughButterCup
Gluelam connectors
ToughButterCup replied to Russell griffiths's topic in General Self Build & DIY Discussion
I found this site to be a big help This was also a help... -
Concrete slump for icf
+ a million. Focuses minds just beautifully. -
Help: conduit duct into loft has condensation
ToughButterCup replied to j_s's topic in General Self Build & DIY Discussion
I expect there's a good reason not to use something like Illbruck airtight foam...... -
Durisol needs 'scotch broth'. Thats as technical as it got. The lad on the wagon and, by chance, the lad on the pump both knew of Durisol and the general requirements for slump. At first sight it's worryingly wet. Durisol technical guidance is available on their site -
Is that the question? How do I make sure there is no warm moist air in the conduit? -
The POSIs Picnic: a solution is in sight.
ToughButterCup replied to ToughButterCup's topic in General Construction Issues
Thanks Joe. The cheque is in the post...... I like the sound of the last bit... the diagram and .... easy to do. I like that a lot. -
Thanks folks. Here's a copy and paste from the manufacturer I spoke to the engineer who calculated the detail at Cullen and have had this response below. “Hi Steve, They are welcome to put blocks in above and below but they are not required. If they feel they want to do this it’s fine as long as the screws are in and the middle block is tight first. Regards,” So yes, if you want to fill the areas above and below then not a problem but it is not required for the floor performance. Best regards, Steve In other words, the top and bottom chords can be supported. One by one we're knocking them down............. Now then, how to handle the BCO? Advice please. If the manufacturer has designed and signed off a solution to the problem, has the BCO the authority to refuse to allow the modification? If he / she were to refuse (and in this case a refusal really would offend) surely it would have to be on the basis of reasoned argument? Put another way, this solution enables the BCO to argue that it's nothing to do with him (in this case it is a him). For the sake of completeness, I attach the relevant document for review. 104 18 - Cheshire Roof Truss_28-11-2018_R-104 18_RevA.pdf -
Some of you will be aware of this thread. It itemises a series of errors on my part. The wet-fish slap in my face was provided by @mvincentd. For which I am sincerely grateful. Cutting through the clutter of a five page thread and seeing the core of the problem is not easy. Thanks @mvincentd. POSIs ordered were 100mm or less too short. The thread explains how I made the error. It shows quite how much support you can muster on BH by making one simple post. At one stage I was resigned to re-ordering a new set and hawking the old set of POSIs on eBay. Many technically savvy people pitched in: it became very obvious how much experience is packed into this little Discussion Group. Technical resolutions to the problem were offered and, truth to be told, I didn't take much notice of them. Thats the problem with my German extraction: your instinct is to do it right or not at all. Perhaps because I'm old, with the supplier, I tried to apply the conflict resolution techniques I taught for so many years. I say tried because its a damn sight easier teaching others how to do it than to apply it to yourself. And, slowly the possibility of a technical solution became clearer in my disappointed brain. So this thread is about looking forward to a sensible way of solving this little problem. A series of people @PeterStarck , @scottishjohn, @joe90, @Russell griffiths, @Nickfromwales all supported the idea of lengthening the body of the joist. And when @JSHarris pitches in and supports those saying that I ought to consider the idea, I did what I should have done ages before. Picked up the phone. Steve Grice of Cheshire Roof Trusses has been dealing with my orders for joists. He's patient. Has to be.? He suggested he talk to Cullens the hanger manufacturer. And a certain Nicola Small came up with this idea In the way of things on BH, one idea - fifty opinions. Most pointed to the issue of unsupported top and bottom chords. Anyway, I read through them all and had a chat with Steve Grice (manufacturer) this morning. He agreed to talk to Nicola (Cullens, hanger manufacturer) to see if we could pack out the top and bottom chords. (The area immediately above and below the purple-shaded area above) Cant say I hadn't heard the exact same idea from @joe90 . Why he even supplied a diagram. Hey Joe! Did Nicola ring up yesterday and ask you ? ?
I can't say I wasn't warned........ Our wall-plates are up (and seem to be still there: surprised eh?). But, since we used Durisol blocks we had to make sure that the Thunderbolts Bolts are embedded in concrete. Not the wooden jacket which wraps the concrete. Tickety boo thus far. Staggered and roughly at 600 centers, concrete and rebar allowing. While waiting for my little local difficulty to be sorted out, I thought I'd lay out the joists at 400 mm centers just like the big man told me. Yep, you guessed it, occasionally the Thunderbolts get in the sodding way. And if they don't get in the way on one side , they will on the other. So common sense says move the mark to avoid the bolt and match the move on the other wall-plate. How on earth do I make sure the mark on the opposite wall is at right angles to the first mark? Measure? Do me a favour, the bloody place is as square as a jelly Buy another laser? Yeah yeah, yeah! Oh, hold on I need to buy more joists.. Damn.
The point made by the BCO is also important. Since POSI joists are engineered, and there are no guidelines similar to those operating for timber (only) joists - the TRADA Guidelines, then he has no guidance to follow. (See earlier post). Why a problem this time, and not last? They are different products, and different designs. One (the first), top hung (on top of the wall-plate) Easy Joists. The second is joist hanger hung, fitted between wall-plates, not on top of them. I didn't do enough research into the difference between the two If .... if.... if . If I can't take a joke, then I shouldn't have started.
Thanks everyone for your input. I appreciate your support and kindness. I really don't know what I (we) would have done without it. Especially thanks to @mvincentd for cutting through the haze and telling it like it is. I will be talking today to the manufacturers and let's hope something can come of it. I must say the manufacturer has been very professional. Cheshire Roof Trusses. (Robinson Manufacturing) Let's hope @PeterStarck that they can come up with something.
