Russdl
Everything posted by Russdl
Next time then. Straight to the Plumbing Supplies place and restore that God like feeling šš»šš»
Have you tried a Plumbing Supplies place instead of a BM? Thereās one near me who are incredibly helpful and without whom I would have been lost on many occasions doing the sort of thing youāre trying to do now. They have huge stock stuff and every size and shape and thread imaginable.
Why is the door set so far out? Itās going to protrude beyond the timber frame. Our detail involved threaded bar into the slab which allowed a GRP angle to be bolted to the slab that took the weight of the door. That puts the door further back in the frame. I can post some detail when I get home if youāre interested.
Have you got two RCBOās of the same rating? If so swap those around, thatāll test the RCBO.
Rookie with longshot dreams of building on old orchard in AONB
Russdl replied to ACF's topic in Planning Permission
Thatās got to be worth a chat with a planning consultant. Looks ideal from that image. -
Any ideas what is happening with my PV array
Russdl replied to Omnibuswoman's topic in Photovoltaics (PV)
I went for the rather more modestly priced Accur8 6in1 circa £120 (which seems to have morphed into a 7:1 for a few more bucks). -
Sounds like a Personal Weather Station for Christmas then šš» Highly recommend for weather/data watchers. -
@Lincolnshire Ian I suspect so. We had the same scenario and we had to submit the Section 80. That was 5+ years ago so itās possible itās changed but I would think unlikely.
@Omnibuswoman youāre orientation isnāt quite right unless your roof is a funny shape? Either way I guess your east facing array is slightly north of east and your west facing array is slightly south of west. That string of figures that Steamy posted show that at 10:00 the sun was circa 70-80 degrees off the east panels and 12.2 degrees above the horizon. At 14:00 the sun was circa 50-60 degrees off the west panels and 12.7 degrees above the horizon. Some 2 hours either side of midday the sun was close to the west panels and slightly higher so if the arrays are equal the west should have produced more at those times. As your west facing array is larger they should definitely have produced slightly more. Houston - I think you have a problem. -
@SteamyTea Ah, that explains it all. āļø -
We have a standing seam zinc roof with a loft space that is open to below. Itās a warm roof construction, so lots of insulation between the zinc and the loft space and we donāt hear the rain on the roof at all so if your loft is more standard and closed off to the rooms below I donāt think youāll hear a thing. I wouldnāt do zinc again because of how quickly the pigeons have made a mess of it that doesnāt wash off despite the endless rain. Probably most people donāt see it - I do. That really shouldnāt happen. There are numerous fittings to attach PV to standing seam roofs, Iād have flipped my lid if the solar dudes had tried to drill through our zinc roof.
- 12 replies
- standing seam roof
- standing seam metal roof
- (and 2 more)
They look clever/very simple and probably ideal for a low energy house. What are the negatives? Just the relatively low output?
Iāve got all sorts of different Shelly stuff dotted around the house and Iāve never had any real problem with any of it which is a minor miracle as that sort of stuff is way out of my comfort zone.
It wouldnāt be the crime of the century.
How do they compare when thereās no snow? I think vertical bifacial is the future if you have the unshaded space.
@Stones thanks for that update/great reminder. Apart from filter changes Iāve not opened mine up yet. Itās been on my āto doā list for a while, as have many things, Iāll put it top of the āthings to do when it get warmerā list. Weāre only 3 years in so hopefully no big horrors lurking inside.
Why not lower the threshold so that you donāt need the interior ramp?
The corner pieces overlap the straight fascia bits. One of the reasons I had them locally fabricated is that the corner in the picture below is not a standard 90 degree corner but 75 degrees. I designed mine to be fixed through the soffit element (which would be hidden by the EWI) and the top of the fascia element (that would be hidden by the PVC). The hidden fixing bit worked, Iām just disappointed in the finished look - however you donāt really see it unless itās pointed out so I should get over it eventually!
I got a local metal fabricator to make some for me for my garage roof. I screwed up though as we have an EPDM roof which is finished off with a PVC trim piece. I should have had the metal fascia the full height of the roof fascia with the PVC trim over the top of the metal but I stopped the metal short, pretty much level with the base of the PVC trim and it looks a bit rough. Iāll draw a picture to clarify the above if youād like.
How about a freestanding carport, half a meter or so away from the house so the MVHR isn't affected. Park the truck the other way round and have a slight fall front to back.
Donāt t discount that option, it brings many pluses. Not least being that the services will most likely be there. Getting services to a virgin plot can cost bucket loads. We were looking for a plot for decades and thatās finally what we found a bungalow that had reached itās ābest before, date. It wasnāt falling down but definitely had had its day and we got it for not much more than a virgin plot with planning permission would likely have cost. Good luck, itās definitely worth the not inconsiderable effort.
We have a fully electric house and could get close to blowing our 80 amp main fuse if everything was on at once, of course itās not - not normally but on the current Octopus smart tariff I want everything on from 23:30 at night. We use a Willis heater for the underfloor heating (with the ability to use 2 if itās really cold). If both of those came on at 23:30, plus the Sunamp and the house battery started charging plus the electric UFH and towel rails plus the dishwasher plus the washing machine plus the car started charging then the fuse would go. On the Octopus tariff I donāt have a huge amount of control over when the car starts charging so because of that Iāve restricted itās charge rate to 4kW (Iām probably starting to use the wrong units now but hopefully youāll understand). I know not to have everything come on at 23:30 but the next owner wonāt (unless they read the Haynes style owner manual Iām writing). In the winter months I probably couldnāt charge a second EV over night, I should have gone 3 phase but I didnāt understand all of this before I made that decision.
