Russdl
    6
Everything posted by Russdl
  1. Speak to a planning consultant?
  2. I can see your concern there from the photo. I’m guessing there will be door’s/stud wall to hide the gubbins? If so, I would route a channel through the wood floor where the doors/wall will go and then waterproof seal the gap between the two sections of floor (which would be hidden by doors/wall) and then install a tiny flood barrier so if the worst did happen it wouldn’t affect the whole floor.
  3. We have two steel spine staircase, designed on the mighty Sketchup and fabricated by the local metal fabricator. The main staircase is relatively easy going and then there is a smaller, steeper one up to the accessible loft storage space.
  4. I’m not entirely sure I understand the question but if I have got the right end of the stick: We used spray paint that was suitable for plastic on several external power outlets to turn them from grey to black and they remain very black four or so years later. No sign of flaking.
  5. I guess it would make completion of that roof joint a whole lot easier if no one can see it.
  6. Supplementary question. What is the wooden thingy? I presume it's a fake ventilation thingy. I'm guessing it serves no purpose, the house is around 25 years old in a cul-de-sac of similar looking buildings with similar wooden things on their garage roofs.
  7. @Andehh I initially thought they wouldn't be suitable to work off but having a look at some maybe they would. I found one nearby that seems to have plenty of reach.
  8. It seems that what I did was correct and last night it worked as required, my problem would appear to be solved.
  9. My son has been asked to quote for a job repairing a purely decorative wooden thingy on top of a garage which has a pyramid hipped roof. It's not immediately obvious in the photo below but the ridge joining the house to the garage is a good couple of feet lower than the top of the pyramid roof. He asked me what would be the best way to access the wooden thingy in order to work on it. I stared at him blankly. So, over to the hive mind if I may. What would be the best way to access and work on the wooden thingy? Is there a better option than full scaffolding? Thanks in advance 👍
  10. I have an Intelligent Octopus Go / Zappi question. I’m trying to reduce the rate* at which the Zappi charges the car overnight from the standard 7kW to around 4kW. To do this I changed the ‘Device Limit’ in the Installer Settings from the default 31.8A to 15.0A as research indicated that would do the trick. Turns out it didn’t do anything and the car is still charging at around 7kW. Does anyone know whether this is because IO Go overrides the Zappi settings? Or have I got something wrong here. *My main fuse is 80A and if everything electric is on overnight at the same time I believe it’ll go pop. Clearly with the IOG tariff I want everything electric to be on during the 6hr cheap rate but I can’t decide when the car will charge during those 6hrs.
  11. Ah, I misread, soz. So the principal elevation is most likely still facing ‘Highway B’. I found the Gov guidance useful but don’t recall enough detail to advise. Have you read this?
  12. Before you go too much further it looks like you need to firmly establish what your principal elevation is. The elevation facing ‘Highway B’ clearly used to be the principal elevation but moving the drive to ‘Highway A’ and the porch addition facing ‘Highway A’ may well have made that the principal elevation.
  13. That can’t be legal!!! Let me just check the BuildHub T’s&C’s…
  14. Just watched it. I’m completely puzzled as to why planning decided it should short of replicate a building that wasn’t there and, by the looks of it, hadn’t been there for very many years. You obviously satisfied that seemingly weird request and produced a beautiful house. Quiet frankly I wish my wife hadn’t watched that Grand Designs! I’ve been fending off numerous questions tonight regarding how you did it so quickly, so well, and so under budget. Thanks!
  15. Isn’t that always the way!
  16. I was snapped as a 3 lane 40 mph limit expanded to a 4 lane 30 mph limit. Definitely no pedestrians or even footpath close by. I was doing 34 mph, I didn’t see the 30 mph sign. Too much street furniture? Or maybe I wasn’t paying enough attention, either way nothing but my pride and wallet were hurt and who knows this thread may may slow some down by 1 mph or more and prevent a them hitting a car/bike/person in a future scenario. I’m not preaching here, I have a Speed Triple that doesn’t really do ‘slow’ very well.
  17. That, I guess, was the point they were trying to make. It resonated with me, especially the 1 mph extra resulting in 8 mph extra at point ‘X’ which could be where the car/bike/person etc is. I was baffled by the 1 mph becoming 8 mph so thanks @garrymartin for confirming that bit of weirdness is a reality.
  18. @garrymartin I got lost in the maths there but it would seem they were telling truths. They weren’t talking about stopping distances per se more about how fast you would still be going at the point the ‘compliant’ car had stopped. I was quite surprised. What about the speed of a car at point ‘X’ if it’s doing 35 mph, that’ll be significant I suspect? it sounds like I’m a convert but it is my second course so they haven’t fixed me yet 😔
  19. I’ve just been on one of those course you are invited to take instead of 3 points on your driving licence (I was innocent! So were the other 20 people on the course). One element of the course explained that with two identical cars, one doing 30 mph one doing 31 mph braking at exactly the same time the car doing 30mph would stop at point ‘X’. The car doing 31 mph would still be doing 8 mph at point ‘X’. I couldn’t argue that because I don’t know where to start on the maths. Can one of you boffins show me the ‘workings’ of such a sum?
  20. I made a pre-filter using tights as the filter element. Catches all the big crud before the air gets to the MVHR filters. Works well. There is a pig farm not too far from where we live and on occasions it stinks to high heaven. To date we’ve never smelt it indoors with the standard MVHR filters (and tights!)
  21. If your installation permits I would recommend you commission the MVHR without the extra filters and see if the wood burner smell is a problem before going to the expense and hassle of adding additional filters.
  22. Or hire a Burco Boiler.
  23. Is that MBC? We had a similar requirement in our contract and provided hot water through an instantaneous hot water tap. The frame erectors could not have been less impressed or interested and it was never used once. Provide a camping gas hob and a kettle, that will partially satisfy the requirement I should think and will never be used for anything other than making a brew. I don’t suspect they will ‘down tools’ because the hot water isn’t running.
  24. Certainly looks like it 😁
