MPH243
Everything posted by MPH243
I used the same stuff as @jack, within 2 or 3 days it had all gone. I bought this sprayer https://www.buyaparcel.com/matabi-81847-berry-7-sprayer-5-litre-mtb81847/ with the 5.4m extension https://www.zoro.co.uk/shop/maintenance-and-outdoor/lawn-and-garden-sprayers/telescopic-lance-5-4m/p/ZT2594450S The extension works OK but it is a bit whippy when fully extended, and the locking system is friction only so does undo a bit to easy. It is definitely worth it as no ladders needed to reach the top of my gables.
I-joists pre notched for support beams?
MPH243 replied to Moonshine's topic in General Construction Issues
I was given distance from end,hole size and other specs from the manufacturer for ours. But that is a very neat cut for on site almost looks like its been routered out -
When Can We Move In?
MPH243 replied to MortarThePoint's topic in General Self Build & DIY Discussion
We moved in before sign off, but we had kitchen, 1 en-suite and 3 bedrooms finished. The stairs were just finished. The electrics were not signed off but we're tested. I got the Bco to come out and he said he was not worried, but offered a letter if insurance company wanted it. I did have to get separate contents insurance. -
Removing tree ear marked for retention
MPH243 replied to flanagaj's topic in General Self Build & DIY Discussion
Cut it down now otherwise they might put restrictions on it. If they ask say it was damaged in the last storm. -
Where to lap DPM with Marmox with split floor level?
MPH243 replied to lookseehear's topic in Brick & Block
I had this inside our front door and just finished the blocks 2 layers lower for the opening and ran the pir out to the step. If the opening is going up two less rows of block won't make any difference unless I have missed anything? If you need to do it your way I would do the bottom one as less chance of damaging it. -
Thoughts on warranty claim for a defective roof
MPH243 replied to Paene Finitur's topic in New House & Structural Warranties
Is it the water hitting the outside of the gutter and splashing back onto the facia and rafter ends, it looks like a big roof into a small section of gutter but might be the camera view? -
Vat claim and sign off
MPH243 replied to nod's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
It changed when it went online and not having to send all the invoices, they just ask for a few to check I think. There was something about it on here the other day? -
We were in 23 months before sign off and a further 2 1/2months for VAT reclaim, they paid everything with the old system. I think they have changed it to 6 months after building control sign off not move in date. -
I just realised the oak was joined, the pine stairs to the basement is 1 piece I can see the oak plugs in the stringer.
Stairbox supplies there quarter landing stairs with a dogleg cut from single piece so should be able to do what you want. You can just about see next to the carpet.
If your house is near passive it will be small. Don't bother to individual zone just one. We have a 8.5kw and 260sqm, better than the old building regulations for insulation just under 2 for air tightness. It has easily coped with our heating demand in mid Devon. I need to get mine to cool as overheating in summer is not so nice. Don't bother trying to get your mvhr to cool.
Slate Verge, Nudura and no Barge Boards
MPH243 replied to WiltshireLink's topic in Roofing, Tiling & Slating
I agree the Klober looks tidy and not bulky. -
We have this one it is fine just get a couple of out riggers which I think the tall ones come with. Even at nearly 5m it is fairly stable and simple to put together.
Have you tried any local sawmills, Facebook might be worth a look we have quite a few advertised but we are mid Devon so a bit different. I think as soon as you go over 1.2m it is charged for 2 pallets.
You could try solid oak Scotia mold and make a template of the radius and try to steam it and bend. Or cut them at angles as @Chriswills suggested and join but use the real wood as the wood coloured paper will probably come off the mdf ones.
In England you can move in when you like, I made sure it was all safe for the kids and signed off nearly 2 years after moving in.
FC1 filler caulk is supposed to work to 25mm and non slumping, it did work and non slumping but I don't know if it cracks in the long term.
I have fitted them 14inch in 2 customer houses. One house had 4, 3 flexi tube and 1 rigid, the rigid is a lot brighter than flexi so I would go with the 10inch rigid in the middle. If it has no windows now, even a small amount of light will make a huge difference.
Sorry, I did not mean to sound silly but I meant the connectors. I had a set and it was a one way valve that got connected in the wrong direction, I got fedup and changed to Hozelock it was cheaper to buy a set on offer than individually. And they are colour coded for the waterstop one. https://www.toolstation.com/hozelock-hose-fitting-starter-set/p90177
Try turning the hose around, I had one that only worked in one direction.
I used SAS pro rend, they are based in Cheriton Bishop, but supplied through RGB.
Took me a couple of minutes to find that. Does not look like the pier at the other end is tied in as well. At least they have put in the flashing for the roof.
You could try MGA Consultancy in Exeter his tester lives near Bristol and travels the south west, I don't know how much he charges now but I payed £225+vat in 2021.
