Sandybay
Everything posted by Sandybay
Myself
I have found There are very few icf builders in Scotland with experience, Beware of Econeckt unless you have deep pockets.
Blocks delivered and we're up to the first floor
Sandybay commented on Simon R's blog entry in South coast ICF build
Ok thanks, that sounds great, liked hearing about your roof too,basically looking to build a bungalow to a similar spec as your build, struggling to get an experienced ICF builder near me though. -
Hi,What was your overall wall width? Blocks look good, is the external side wider for extra insulation saving fitting ewi? -
Hi Has anyone heard of JO Blox? Would it be an equivalent to icf? http://structuralinsulatedblocks.com/technical/
Front garden excavation for drive
Sandybay replied to Margaret dailey's topic in Landscaping, Decking & Patios
Hi Margaret, I realise from reading your posts there are things you can't afford in this proposed project, but you also CAN NOT AFFORD TO IGNORE THE ADVICE! If you do not go about this project correctly you will wish you had never thought of the idea. -
Hi, Had an old Westwood ride on myself a few years ago, the deck was on adjustable bars at the front like the one you have, and had a steel wires across the top of the deck at the back, over time the wires stretched with the weight of the deck, and I changed the bolt position on the front two bars to raise it a little.
Thanks for the replies, will look at a 12 volt immersion,and solar pv system.
Hi, Just finishing off my Nissen Hut, have sink with cold water, was wondering if it would be possible to have a solar thermal system providing hot water when possible for washing hands etc, Is this possible, what sort of storage tank / system, would be required? Thanks
Securing PV panels to shipping container
Sandybay replied to NWGEAR's topic in General Self Build & DIY Discussion
Buy yourself a large amount of marine silicone, wait for a dry sunny day, job done? -
Hi,good information on your build and good progress, Could I ask why you choose the isotex blocks instead of the Eps ones like amvic, are they any better? Hoping to start my own icf build this year, liking your insulated foundation, was there much cost difference between a strip foundation with insulation board? Thanks.
Thanks, block price doesn't seem too bad, getting an experienced contractor to complete just ICF part of the build for a manageable price seems to be a problem, especially in the Highlands.
Hi, Does anyone know the current price of amvic or nudura icf blocks per sqm? Thanks.
Hi, Just changed tracks on a three ton takutchi, remove grease nut or greaser, Then put an old pice of fence post or something around that size into the track above the sprocket and drive the track forward and back,that helps bring the idler forward, once you have enough slack in the track, use a bar to ease it off idler whilst slowly turning the track. Once you remove track clean any debris from idler track and hit it with wood and a sledge hammer to make sure it's fully in,that makes fitting new track easier?
Hi, Yes these log holders are very good as long as logs aren't too big in diameter, My brother does a bit of welding and made one quickly using 2x2 box section steel, basically you can cut the whole log in to discs without any hands near it?
ICF versus wooden frame icynene filled. Was set on ICF build, but builder quote to w and w stage is high, and not sure on completion cost, have a better idea of costing on a block built timber frame icynene sprayed build, are the two a comparable products? Thanks.
Today's delight: making holes in concrete
Sandybay replied to ToughButterCup's topic in General Construction Issues
Hi, Would anyone know the potential cost of rebar in an ICF bungalow, raft foundation, 150 sqm, 45 sqm of glass? Thanks. -
Hi, Does anyone know of problems with kastrup 3g Alu clad windows from ecohaus internorm, or a better alternative brand? Have been told by builder that rationel are difficult to seal in ICF? And sils not deep enough? He is an agent for ecohaus though ? Thanks.
Hi, Could anyone tell me is there much difference between rationel and kastrup Alu clad windows? Quality price etc. Thanks.
Thanks very much for all the information, much appreciated, Alexander.
Hi, Thanks for your your responses, So basically you could have ASHP and storage tank, then solar pv system with a Sunamp, would the two systems work together ok? Or would you recommend any different combinations to run DHW systems in a 150 sqm bungalow?
Hi, Thanks for the reply, so I see the Sunamp needs a heat input, but has its own element of sorts which a solar panel or mains electricity would run? I wonder how it's running costs would compare to an ASHP?
Hi, Had never heard of a Sunamp before, watched a YouTube video, looks very good, I am hoping to build a well insulated ICF next year,was planning an air source heat pump to run under floor and hot water system, would a Sunamp do the same job and do away with hot water storage tank? I would like to fit solar panels, but would Sunamp cost more to run in the winter than asap? Would appreciate any advice, Thanks Alexander.
Hi, Thanks for the reply, would you know how they compare cost wise with other ICF blocks?
Hi, Has anyone used Izodom 2000 ICF blocks?
