Mr Punter
    27
  1. I went paragliding with Tim who did the first GD build. He didn't seem too traumatised by it.
  2. You can get the rockwool in plastic type which can be stapled to the sheathing. What, if anything, has been specified?
  3. What has been specified as cavity barriers and where are they to go? A while ago it was acceptable just to run some 2x2 around openings.
  4. Is that a gap between the plasterboard and the trim? Maybe a zoomed out photo would help, but my feeling would be not to plaster over it or add a second board layer.
  5. I don't think it is. Get a main contractor, demo and prelim costs, overheads and profit and it may be fairly close.
  6. I doubt the people checking the cil liabilities look at the plans, just the answers you put on the form.
  7. What's it to you?
  8. Dust sheets and sheets of ply or protection boards. Wash off any cement splashes before they cure.
  9. You often see brackets used to mount windows. The location in relation to the existing is part personal choice. They would probably be best as per original. If they are weighted box sash they need a bit of space at the sides. Use insulated plasterboard for the reveals and insulation under the cill.
  10. You could just use 25mm Celotex type insulation over the studs before you fit the plasterboard with 50mm screws.
  11. Sorry your post was missed. You will be fine fully filling with the Kingspan. No gap needed. If you have room you could also use insulated plasterboard internally and this will help lower the bridging through the studs.
  12. It may look good with stone up to the top of the windows and painted rendered blockwork above. It will look less sheddy.
  13. It is the fire service who will say what they require. They should be consulted by the planners but you can approach them directly for guidance.
  14. They can be quite expensive. I have used Bison ones before, where they were also doing hollowcore plank first floors. It is nice to have stairs and first floor in early on for safety and access. You need to consider what the finishes and floor heights are going to be.
  15. Another decent design by @ETC. There is still scope to make main living / kitchen / dining area more generous if you went with the larger ground floor and make any other tweaks, but I think it is looking good.
  16. I have a the paslode 350 but have seen a fair few battery only framing guns being used on sites.
  17. The piling firm we used a rubber duck excavator with an auger. No piling mat or crane. Someone welded bent rebar to the steels so they could be picked up and lowered by an excavator.
  18. They will often agree to extend the determination date if you suggest it.
  19. I have done a basement on a tight site and used a combination of semi contiguous auger piles and king posts with sleepers for the temporary works. A lot of this is down to soil type. Can you get your SE to design this, or suggest someone who is experienced at this?
  20. I have used https://www.screwfix.com/p/spax-tx-countersunk-self-drilling-flooring-screws-4-5mm-x-60mm-300-pack/88716. Glue and lay the boards a few rows at a time, then chuck in a few screws.
  21. Regarding the proposed use, the PD guide says "A purpose incidental to a house would not, however, cover normal residential uses, such as separate self-contained accommodation or the use of an outbuilding for primary living accommodation such as a bedroom, bathroom, or kitchen."
  22. Can you ask the staircase firm what engineer to use? It sounds like they do a fair few of these for developers so they must have worked out the simplest and most cost effective solutions. Give them a bell.
  23. Why would anyone sell good spec functioning windows? You may get a few one-off mis measures but not a house worth. Another option could be new housing that has been condemned e.g. substandard mortar or foundations and the houses get binned and rebuilt.
  24. You may need building regs for this, and that could dictate insulation etc. You may need to do the floor and ceiling.
  25. You have about a mile of pipe in the floor. I don't like it when the runs back to manifold are tightly spaced. Can any of the pipes go under the walls?
