Mr Punter
If they are being plastered that should suffice.
100mm rockwool vs Insulated plasterboards on Brick wall
Mr Punter replied to Bentley's topic in General Construction Issues
Rockwool is about half as thermally efficient as PIR, so would you need twice the thickness for the same insulation. Insulated plasterboard has either PIR or EPS. The EPS is between rockwool and PIR for performance. If you have space you can build a new timber wall and insulate it. -
Yes a bit odd. It is fire and acoustic rated. Maybe the octagon made it a bit stronger?
I have only seen them used for external render. The OP is doing tape and fill plasterboard.
I have just done a small bit with the metal reinforced paper tape on some boxing. It was not too bad. If I was doing it on price we would be hungry!
I have had these fitted in some flats. They are quite clever. If you wire in a switched live they also look at how long the light is on to work out the overrun needed. Cheap too.
I have a 100A single phase supply and use it for the house and to supply a twin EV charge point that will supply 2 sockets up to 7.4kW each. Some of the plug in hybrids have a very small battery / electric range so they may not be optimised for quicker home charging.
So internally insulated block cavity wall. Are the internal walls mostly timber stud (other than the brick one)? Do they go up after the insulation / battens? BTW if you want someone to see you have mentioned them, type "@" and then pick their name from the drop down list @Gary Martin.
Notching and noggins fitted tightly between the joists is quick and easy.
Yes it looks fine to do. There may not even be a lintel above the door, but better to put a new one in as you are altering the opening and the making good will be easier.
It is perforated gas duct.
I would hoover out as much crap as I could then slide some pipe insulation down as far as it will go. That will stop the condensation. A bit naughty using gas ducting but it could be worse.
It depends on temperature, airflow and screed type. Allow 1mm per day as a guide.
I can't see the images.
Toilet in porch extension?
Mr Punter replied to Brian0782's topic in House Extensions & Conservatories
I don't know. I saw it on Rightmove. At a guess the projecting part is 2.3m wide x 1.3m deep externally keeping it below the pd limit. I guess the inside bit could be 2.2m x 1.5m. -
SAP Completion and other bits and pieces needed
Mr Punter replied to mickeych's topic in Building Regulations
I am doing one of these at the moment. A fair amount of paperwork but just be methodical. Best to do in one lot if you can. -
You are beginning to sound like @Pocster
They normally fill the holes as part of the install. They use mortar.
It looks like you have enough space under the first floor windows for a pitched hipped roof. The design you have is destined to fail.
Often planning conditions require agreement in writing from the planners, where this one only requires that you submit verification, which you have, via your invoice.
After the pipe crosses the foundation it can immediately drop down, so unless your external finish level is on the foundation you should be able to accommodate this. At this stage it is not too late to create a channel in the foundation and run the pipework a bit lower.
The long radius horizontal is a no-no. There are no inspection chambers. Why not take the pipework outside from the bathroom and run around the building? That way you can add proper access for inspection and rodding.
