Mr Punter
Posi joist - This install feels rubbish, thoughts?
Mr Punter replied to boxrick's topic in Roofing, Tiling & Slating
I am no expert on these things, but from the photos, the welding is awful, some of the bearings look off centre but may be within tolerances and the top end of the pozis are awaiting some angled hangers to correctly secure them. Get your SE to look at this and give their professional opinion. -
What you have done looks OK. The downpipe could be straighter and the gutters could be up a bit nearer the tiles and not tilting forward, but you are governed by the fascia.
Insuring unoccupied buildings subject to works is expensive as the risk is higher than a completed and occupied building. Sometimes you may not get all the cover you would like at a reasonable cost. I have a contractors all risk policy but it may not be suitable for your circumstances. Talk to a broker.
The raking section does not have to be belt and braces as it is protected by the eaves and gutter. You could use some self adhesive lead replacement covering right up to behind the fascia and down onto your new roof. Cut the whole thing carefully before you remove the backing paper.
I would stick with your original plan of stone cladding and render. Make sure the render is done correctly and the stone cladding is protected while render is being done. The stone may need some remedial work - like brick acid and / or pressure washer. I would avoid more timber as it is flammable and it can discolour.
Week 8 - And pause... or not.
Mr Punter commented on Benpointer's blog entry in Contemporary build in north Dorset
It is quite surprising just how much a layer of 9mm OSB can stiffen and strengthen a stud wall. -
If you have MVHR ducting, bear in mind that to feed in the ducts one end of the run must be clear of walls, so they sometimes need to be fed in before the walls progress. Strongboys and steels can get in the way as well, as can solid timber beams and flitch beams.
Box profile metal sheet maximum unsupported overhang?
Mr Punter replied to Dunc's topic in Roofing, Tiling & Slating
If the metal roof manufacturer is not willing to assist you may just need to make an educated guess. @saveasteading and @Gus Potter may give you a steer. -
+1 I have used the cheaper Heritage range for a replacement at the rear in a conservation area. They look very good.
Non-Compliant Upper Floor Windows (Low Sill Height)
Mr Punter replied to tg77's topic in Building Regulations
You are quite right. There is no minimum cill height for escape windows, just maximum. The windows would fail down on part K if you were making an application for Building Regs but if they have restrictors or a barrier they would be OK. WTF is this guy on about? Pathetic. In the past I have both added and removed door closers and added and removed window locks to satisfy Building Regs. Meanwhile at Grenfell it was considered fine to add a load of highly flammable material to the exterior of an otherwise fire resistant high rise block. -
I can't see an issue here at all. Once the plaster is made good and the architrave on it will be fine.
Any gap would just be there for maintenance or ease of construction. You don't need 2 walls.
I would consider just treating it as a crawl space, closed off from the floor above. You could maybe put in a hatch for access.
What you have done looks fine. I give you my consent to stop digging.
- 1 reply
Get in touch with the developer. They may help.
Fire Regs for Steel - Fireboard thickness
Mr Punter replied to Spinny's topic in Building Regulations
Yes, 12.5 will give 30 mins. -
Drilling hole through existing foundation
Mr Punter replied to LSB's topic in General Construction Issues
The guys that did the Hatton Garden heist managed. I would do some slots with a petrol disc cutter with a hose attached for dust and break out between them with a kango. Keep going until you achieve the right depth. -
If I was a wheelchair user an outward opening front door would be a pain. It is also bad for visitors as it opens onto them.
Just keep shopping round. This firm https://www.kiteleys.co.uk/conveyancing-costs looks less than a grand.
You can have some transition pieces or a shallow ramp. What is the floor finish? Are you having a mat well?
Using PIR boards to backfill garden path
Mr Punter replied to miike's topic in General Self Build & DIY Discussion
I have known the foam to break down into a powder. EPS is OK but PIR I am less sure. Put them free to collector? -
200+ metre utility connection
Mr Punter replied to Oz07's topic in General Self Build & DIY Discussion
+1 and the DNO do not allow you to run electric through sewer pipe or non approved ducting. -
Rear extension and nasty neighbours!
Mr Punter replied to Millymu's topic in House Extensions & Conservatories
Your solicitors gave you good advice. Party Wall award will happen anyway, as will planning consent. I don't know how the freeholder consent works when you have a share in it, but they are often "not to be unreasonably withheld" or some such. Try to let it wash over you and do not deal with the neighbours directly or react to their provocations. Avoid words like "lies", "hate" and "nasty" as they are not helpful. -
dimensions on planning as opposed to reality?
Mr Punter replied to mjc55's topic in Planning Permission
You will probably not get pulled up on this. They often allow a maximum 100mm leeway to work in with brickwork. If it already built you don't have much option. If not, just do as @DevilDamo suggests.
