Mr Punter
I would rather see the cost of electricity reduced by scrapping green levies, high standing charges and reduce the link to wholesale gas price.
Agree just leave them although with hindsight the bottle gullies with the plugs would have been easier to rod.
With the integrated fittings, if they are discontinued or you alter the kitchen you may not be able to get the right lengths. Make sure they are able to switch from the same place as the rest of the lighting.
- 13 replies
- led lighting
- led strip
(and 3 more)
SE specified C24 6.1m * 47 * 225mm for garage roof
Mr Punter replied to flanagaj's topic in Flat Roofs
I have seen these where they are bolted together on site. One of the lintels has some tube / chs welded and the 2 are bolted together. Needs SE design. If the cavity is 150mm or less you can use the HiTherm lintels. Expensive and long lead time on some, but good psi / thermal bridging characteristics. -
Is £188k a realistic budget for a 4,446 sq ft refurb?
Mr Punter replied to PedanticBuilder's topic in Costing & Estimating
Skirtings, architrave, flooring, plumbing, wiring, heating, ventilation. It is a huge house and a massive amount of work. Make sure you have not missed anything and you are not wishful thinking. How long do you think it will take you? -
I doubt you will find longer than 6.0m. Can you break the span with a steel or flitch beam? -
I suggest you tie a cord around the bung and secure it to a stake so it doesn't disappear down the drain under pressure when your side is full of water. I speak from bitter experience.
What is the paint?
Painting a new external glulam post - now or in spring?
Mr Punter replied to dwtowner's topic in General Construction Issues
The breather membrane is a good call. If you attach it with stainless staples it will give very good protection. -
You could just use some self level compound over the adhesive to create a smooth surface. The LVT installers would do this in any case.
Yes that is a standard condition ("construct according to the submitted plans") and it allows you to apply for changes just with a variation of condition, without them needing to amend or replace the existing consent.
It looks like a bitch of a job. Have you considered just taking up the tiles and fitting LVT flooring? It will feel far less cold underfoot and they do a great range. With the lack of underfloor insulation - which should be 150mm thick minimum for UFH - you won't get a perfect solution. You may be able to incorporate some radiators for the problem areas.
We have had timber frame fire spread engineering a while ago. Stuart Milne - no longer trading - did the frame and Fire-Q did the fire stuff. It cost about £1000 10 years ago, for a 4 storey terraced housing project about 1200m2. The fire spread risk is mainly during construction. Once it is plasterboarded and finished externally it is far safer. You can mitigate open plan layouts with sprinklers.6293 Fire-Q FSRA Falcon Wharf Rev 02 FINAL 20062016.pdf
Grand designs - the wood house
Mr Punter replied to Great_scot_selfbuild's topic in Property TV Programmes
I vaguely remember that Building regs do not specify minimum stair widths. -
That is a very well designed and executed car port which looks like it will stand the test of time, as well as the Scottish climate. Nice job.
Discount Offers of the Week
Mr Punter replied to Ferdinand's topic in General Self Build & DIY Discussion
Screwfix have a Trade pack of Torx screws on offer at 60% discount. 1400 screws for £19.49. https://www.screwfix.com/p/turbo-tx-tx-double-countersunk-multi-purpose-screw-trade-pack-1400-pieces/771vv I think @ToughButterCup is a fan of Torx. -
Easifill is a good filler /jointing compound. Sandpaper to finish. Some joint compound goes off very hard and is difficult to sand.
I think the cause was linked to a tree in a neighbours garden. Neighbour not cooperative.
If this is a rental you could just fill the cracks and redecorate. If the roof is letting in water you will need to get it sorted. My mum has a rental in Swindon with subsidence cracks. Five years on and not much progress with the insurers.
Aco drain to take water away from dining room wall
Mr Punter replied to AdamD's topic in Rainwater, Guttering & SuDS
You can either rip it out or just leave it. You may be able to leave it for ages without it being an issue. As an interim measure, you could aco round the edges as you don't want any water build up in that corner. You can get cheap stuff at about £12/m and dear stuff at £40/m. Easy to fit. -
There are a few on that bottom row that are not sitting nicely. That is quite a kick up.
Is the earth under the joists damp? It needs to be completely dry. Is there any ventilation to outside? Ideally there should be airbricks either side and a crossflow of fresh air. Can you rip out the timber floor, insulation and screed, or is that too disruptive?
