FarmerN
Everything posted by FarmerN
Crushed recycled varies a lot between suppliers, in my experence. Had some really good some awful , get a sample and check first load when delivered
My wife say’s, therefore right,- ours are spoilt by the grout which is a light colour , not dark as the gaps between floor boards would be. They were also laid at a standard tile spacing , which again is wider than floor board spacing would be, no idea if they can be laid with a narrower spacing. The tiles do look very realistic but the grouting does detract from that. If I was doing more I would have a look at some laid ones in showrooms.
It would be interesting to know the outcome.
We did an expensive SUDS compliant block paving drive way, took a fair bit of time and care doing it. Two years in and it's an awful lot less permeable than it was , guess is in 5 years it won’t be permeable at all. Mud from car wheel arches and muddy boots from gardening and walking soon fills the permeable cracks, being in a rural area there is plenty of mud around.. Fortunately it doesn’t matter, to us.
This sounds interesting. Can you tell me more please. How does this work exactly? See Thread Wiring for freestanding lights?
We have been in our new build for 2 years. Wiring I wish we had done different. External lighting done with the wrong cable for PIR lights ( 2core used should have been 3core ? ) Only got rear external sockets , used a lot but should have had one at front as well, perhaps by EV charger. Wiring for towel rail did not allow for timer. Things I like. 2 consumer units only one supported by battery in event of outage, so heat pump and towel rails do not drain battery. Because of automatic gateway often do not realise we have a power cut. 5 amp lighting sockets for side lights in lounge , hall and kitchen family room, switched by door. We put high level sockets for extra bathroom heat, been here 2 winters and not used them, but who knows when I’m 90 ( a bit too close for comfort) Put small distribution box in Garage, so easy to take an extra feed to greenhouse or summer house etc.
Our dish washer is connected above the U bend below the sink and can smell. Every 3 months I have to unscrew dishwasher waste connection, clean and reconnect. Problem solved for me. Running a cleaning cycle in the dishwasher doesn’t sort it. It’s just a badly designed waste connection, that allows a build up of crud. The washing machine connection in the utility is identical and also requires the occasional clean but not as often.
From a conversation I had last night about gardens in new builds , they are lucky compacted clay is the problem rather that compacted bricks and rubble. Advice all sounds good. My approach would be to try to aid aeration by loosening clay with a long fork and spreading sharp sand ( concreating sand, not fine building sand) as well as organic matter. A modern fork will probably bend a 50 year old one probably won’t. Builders and developers do need to think about looking after the future gardens more. Top soil screening buckets are now readily available for diggers to clear a site of large rubble pieces and can be very effective. Our digger drivers idea of levelling the site was to track everything in and track back and too until level ! Soon stopped that.
Is this a reasonable cost for plumbing first fix?
FarmerN replied to Great_scot_selfbuild's topic in General Plumbing
1st half of the pipe length is in 22mm before going down to 15 mm. -
Our kitchen sink is far corner of house to DHW cylinder, half run in 22mm pipe, can nearly fill a washing up bowl before hot arrives. Manifold system sounds good to me. -
Our builder brought the plumber in for fist fix without sorting where everything else was to be sited, only had to change pipe layout into plant room twice ! So my experience would suggest you need a clear plan of what is to go is to go in plant room and where it can be sited. As with everything compromises have to be made, nothing is ever quite perfect. So coming into our plant room in ducts through floor – Water , broadband, mains electric, duct back to garage for EV charger and battery, drain for MVHR and spare duct to outhouse for future use. Only 7 points needing varying degrees of access! Sited in plant room GSHP, DHW, MVHR, meter, consumer units, battery control box , two expansion vessels, one UFH manifold, etc etc.
Whilst it might clutter the house ,could you put an additional door in the back hall? This would separate the bedroom area from living and give a little more privacy to the bathroom. It already has garage one side and on suite the other so hard to improve on that. Perhaps move door from front hall.
MVHR vs Air Con - if you had to pick one?
FarmerN replied to Indy's topic in Mechanical Ventilation with Heat Recovery (MVHR)
In my opinion , how much glass you have will make a massive difference. Overheating is not a problem for us with windows, two neighbours with glass walls complain about over heating. Any chance of Velux window in vaulted ceiling to let heat out, cool bedroom at night. We have MVHR and like it, have a friend with hay fever who says it’s always better when staying with us, also bathrooms dry quickly and plant room serves as drying room, -
Anyone had a Danwood build without an MVHR?
FarmerN replied to worldwidewebs's topic in General Self Build & DIY Discussion
See Your in Cheshire A factory built house went up last summer which I think was Danwood, but may be wrong. I t was built on a raft foundation and was bolted together and roofed in less than a week. I have no idea if it had MVHR or other tech. It’s on the west side of the A49 in the 30 mph zone of Spurstow , Bunbury . -
Our 110cm Range cooker is rated at 17 kW . Interesting as our transformer is rated at 15 Kw ! The other wiring we put in which my wife likes is a 5amp socket circuit for side lights switched at door separate to main lights. Make sure you make provision for a car charger, even if you have no intention of getting one yet.
Googleing "log burner stove polish" brings up a range of products. Back in the days, I'm sure we had "Stove Black" no idea what it was.
We have similar room , it's fine for me but my wife complains all the time at noisy room, “ like an Italian Restaurant” Floor tiles ceramic work tops etc. Wife put carpet off cut on top of all tall cupboards and wall units. Curtains / Roman blinds help a bit in winter when closed, and large rug in seating area.
Proposed changes to Permitted Development rights for small wind turbine
FarmerN replied to FarmerN's topic in Wind Generation
Thought House was limited to 11.5 M -
Proposed changes to Permitted Development rights for small wind turbine from Department for Energy Security& Net Zero I have no idea if this is strictly limited to commercial sites or not “New government proposals today (Wednesday 18 March) would allow businesses and public sector organisations to install one turbine up to 30 metres – no bigger than an oak tree – without submitting planning proposals, making it faster and cheaper to generate clean power on site.” https://www.gov.uk/government/news/lower-bills-for-farmers-schools-and-factories Also Open consultation Permitted development rights for onshore wind turbines in England: consultation document (accessible webpage) Published 18 March 2026 https://www.gov.uk/government/consultations/permitted-development-rights-for-onshore-wind-turbines-in-england/permitted-development-rights-for-onshore-wind-turbines-in-england-consultation-document-accessible-webpage
Replacement heating for an Old Farmhouse
FarmerN replied to Iceverge's topic in Boilers & Hot Water Tanks
I have no idea how the economics would work out. But if only relatively short term would old fashioned night storage heaters have a place ? Run on Cosy or EV charging tariff.? Log burner is great for main living space. Moved after 50 years from very large, old draughty farm house 6+ bedrooms. We lived with Oil fired cooker , a wick burner so kept going in power cuts (4500 liters / year ). Log burner using 8 cu M logs a year and night storage heaters. The logs and electric were lost in the business. Our experience was you needed to keep the main living rooms warm, no matter how much heat you put in, if the fabric was cold , it felt cold. It was a healthy enviroment to bring kids up in, if a little bracing at times. -
We have just built a new Robinsons greenhouse. I’m amazed at how strong the glass is. It’s toughened glass. Would withstand acorns , but mature oak trees have a habit of shedding branches, that would be a different matter. I think, but am not sure, all greenhouses have to be toughened glass now. If under a tree keeping it clean could be an issue.
We had settings changed on MVHR extract vents changed , reducing flow to utility extract while increasing extract rate from plant room by same amount, helps with drying clothes. Air flow is through utility to plant room. My wife wishes our plant room was warmer to improve it as a drying room.
No mention of thermal bridging in this discussion of blocks Is it important , especially through foundations? Should different blocks be used in foundations? Our build was all masonry construction , and due to ground conditions ended up with a beam and block construction. This meant all masonry walls were thermal bridges, more so than on ordinary foundations. I keep meaning to get a thermal imaging camera to see just how bad it is, and compare internal to external walls.
On our new build we contacted Openreach or might have been BT, and they provided Grey Ducting 50 mm , an external manhole and cable etc FOC I think. We did all the work and dug it in back to pole. Left a rope in when we pulled cable through in case Fiber came past. This is all about 3-4 years ago. My memory may not be correct or things may have change
