wozza
Personal Information
Location
Shropshire
3333 profile views
wozza's Achievements
Regular Member (4/5)
110
Wash and spin your roller sleeves before use - you will be surprised how much rubbish comes out of them. Mix your paint well, and mix again if using a few hours later or the next day and store at room temperature - always clean off the lid and rim. I have had good results with and like Wickes own brand washable emulsion - but limited color choices. Recently used some Dulux Heritage emulsion on a feature wall and imho it is fantastic paint. I have used Tikkurila Anti Reflex 2 on all of my ceilings and will continue to do so until I find something better.
Photos? What type of grease?
B and Q Valspar could not accurately match a dark blue cupboard door for me - the scan was miles off - 3 attempts later and 3 wasted match pots that I refused to pay for, I matched it using the charts and it is pretty much bang on - so my advice would get them to do a match pot to test before you commit. I used Tikkurila Anti Reflex 2 on all of my ceilings and I cannot recommend it highly enough. I have also recently used some of the Wickes own brand tough and washable paint - it is very good and great value.
Sorry haven't read through the whole post, so may be repeating other comments. I wouldn't be surprised if your Fridge Freezer doors hit the oven handles - a lot of people under estimate the amount of space the doors require to open fully.
Hi @Susie It worked fine, but make sure your measurements are bang on. Wozza.
Vaillant Gas Boiler - Rads and UFH - Expansion Tank
wozza replied to wozza's topic in Underfloor Heating
Turns out that is was the expansion tank (only a small leak though as there wasn't much water in it), and the pressure switch was sticking - both replaced and working like it should. -
Hi All, We had UFH fitted to our existing heating system around three years ago. AT the time I asked the installer if we needed an expansion vessel and he said nope you should be ok - I questioned him again a few times to be told no, it should be fine - so we never fitted one, even though lots of people on here said we should have one. 3 years later and all has been fine until today. I fired up the heating for the first time since March - everything was working ok - Rads got warm, UFH all working and warm - I then checked the boiler and we had suffered a small leak of water from inside the boiler - I estimate around a cup full, and no more has leaked out - heating still working fine. I then noticed that the system was running at 2.1 bar - it used to run at around 1.6 to 1.7. So I drained off some water to reduce the pressure but anything lower than 1.9 bar and the boiler stops working and displays an F75 fault. I have topped the system back up to 2.1 bar the the fault has reset and everything works great. The boiler is a Vaillant Ecotec Plus 831 and it was fitted in 2010 and it has never missed a beat - we have 9 rads and 6 UFH loops - I have an engineer booked to come and look but thought I would ask the brainiacs here if a few questions so I could be better armed. Do you think the boilers expansion tank is knackered? Do I need an extra expansion tank? If so then how do I size it and can it be fitted anywhere on the return? If I do need an expansion tank, does anyone have any suggestions for a wall mounted one Thanks all, Wozza.
Can you turn the socket 90 degrees? how is it mounted - pattress / drywall box?
Screw Pops - Ceiling worse than before decorator started
wozza replied to canalsiderenovation's topic in Decorating
The Screw pops will be due to movement (expansion / contraction) or impact - what do you think that the decorator could have possibly done to make previously un popped screws pop? -
As others have said it nigh on impossible to get perfect but I also highly rate Tikkurila Anti Reflex 2 - I have used it on all my celings.
Cant comment on that door. I spoke to these people about an unfinished Oak Bifold door to fit a 820 mm opening, but have yet to do anything else. Made to Measure Oak Mexicano Bifold Door | Savoy Timber
We have 1200 x 1200 x 7mm - two people required to lay them. We laid ours on Ditra. Normal suction lifters may not work if tiles have a texture. Expansion joints in every doorway and across a large opening due to the size of the area. Definitely use a levelling system. We also used the tiles as skirting.
Retrofitting Velux Integra Auto-opener to roof windows
wozza replied to Rob99's topic in Skylights & Roof Windows
I have fitted one, takes about 15 to 20 mins, really easy to do, works fine.- 1 reply
What spacing are your joists - 18mm is fine for 450mm or less, 22mm if wider or if you want a more solid feel.
I have wifi 6, should I wait for wifi 6 speakers?
wozza replied to Adsibob's topic in Networks, AV, Security & Automation
Sonos stuff wont connect to wifi repeaters and it will only connect to 2.4ghz networks As has already been said - Richer Sounds and Smart Home Sounds are usually the best two retailers for Sonos, I have purchased from both without issues. The Arc sounds great with a pair of ones and a sub.
